2BDriver Hypersonic October 26, 2010 Share October 26, 2010 Dear All, Any Denso Iridium Spark Plug Expert user can advice the differences with SK20 & IK20 ? I were told by Ric-Tat @ owen road that the IK20 is now out of stock, but SK20 is available, I'm wondering the same Heat Range numbered for "20" is for Hot Engine application. Kindly advice. ↡ Advertisement Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear October 26, 2010 Share October 26, 2010 The SK20 has 0.7mm electrode and is designed as a long life plug, while the IK20 has 0.4mm. Link Denso_Spark_plug.xls Link to post Share on other sites More sharing options...
2BDriver Hypersonic October 26, 2010 Author Share October 26, 2010 The SK20 has 0.7mm electrode and is designed as a long life plug, while the IK20 has 0.4mm. Link The gap of 0.7 to 0.4 is so wide, does it affect the application into Engine ? Link to post Share on other sites More sharing options...
Zuoom 1st Gear October 26, 2010 Share October 26, 2010 strange, normally SK series harder to find. at least that's what i encounter many years back. Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear October 26, 2010 Share October 26, 2010 The gap of 0.7 to 0.4 is so wide, does it affect the application into Engine ? 0.7mm will last longer; 0.4mm is finer and thus, better efficiency. if you ask me, i will opt for the typical copper spark plug and change every 10,000km. cheap and good. i think mine is using platinum spark plugs and come with stock. to each its own. Link to post Share on other sites More sharing options...
2BDriver Hypersonic October 26, 2010 Author Share October 26, 2010 strange, normally SK series harder to find. at least that's what i encounter many years back. FYI the unit price is cheaper than IK20 series, they quoted me SK20R11 for $14/pcs/Included GST. Link to post Share on other sites More sharing options...
Trex101 3rd Gear October 26, 2010 Share October 26, 2010 FYI the unit price is cheaper than IK20 series, they quoted me SK20R11 for $14/pcs/Included GST. Slightly cheaper then IK20 which is going for $15/pc. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear January 15, 2012 Share January 15, 2012 hi bros, Just to add on... for my ride if my owner manual says that the minimum gap os plus minus 0.8mm for spark plugs will it be possible to use a spark plug that is say 1.0mm in gap? please advise. very noob to this. Link to post Share on other sites More sharing options...
Escksu Clutched January 16, 2012 Share January 16, 2012 The gap of 0.7 to 0.4 is so wide, does it affect the application into Engine ? ITs not the gap. ITs the width of the center electrode. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear January 17, 2012 Share January 17, 2012 which is better? wider gap or narrow gap? Link to post Share on other sites More sharing options...
Escksu Clutched January 18, 2012 Share January 18, 2012 which is better? wider gap or narrow gap? Too small gap it may not properly ignite the fuel. Too wide it will misfire. It has to be optimum. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear January 18, 2012 Share January 18, 2012 Too small gap it may not properly ignite the fuel. Too wide it will misfire. It has to be optimum. Sorry am noob to this.. can advise how to know if its optimum? How to gage? ↡ Advertisement Link to post Share on other sites More sharing options...
Income tax Evasion
Income tax Evasion
Disputes between neighbours - A True story
Different front and rear tires
DENSO Singapore - Free Cleverin Treatment With No Purchase Required
Whats's the difference between rubbing compound and polishing compound?
Different version of 3M Clay Bar
Between Hyundai Elantra and Toyota Altis.....
Front and rear different tire size
