Celicar Turbocharged October 24, 2010 Share October 24, 2010 Unwittingly drove off without releasing the handbrake today. Leads me to wonder why the accelerator can override the handbrake, anyone knows? It seems to me it is safer if handbrake overrides accelerator. Makes me also a little worried that my car mechanism will be damaged if I make such mistakes or that the handbrake will one day fail after parking the car... ↡ Advertisement Link to post Share on other sites More sharing options...
SimonTan 2nd Gear October 24, 2010 Share October 24, 2010 If you pulled very hard on the handbrake, you will likely be able to overcome the engine power at low throttle position. The handbrake is only mostly on the rear wheels, also the design strength is not to stop a running car. But to prevent a stationary from moving on it's own weight and gravity! Link to post Share on other sites More sharing options...
XALmoN Neutral Newbie October 24, 2010 Share October 24, 2010 your handbrake drum shoes will be destroyed if you continue doing it. over some time, you might smell a burning smell. Link to post Share on other sites More sharing options...
Celicar Turbocharged October 24, 2010 Author Share October 24, 2010 your handbrake drum shoes will be destroyed if you continue doing it. over some time, you might smell a burning smell. I see. Is it easy to check at a typical servicing session or do I have to take apart some sections of the car before I can check the drum shoes? Link to post Share on other sites More sharing options...
Kopites Supersonic October 24, 2010 Share October 24, 2010 Your ride is a front wheel drive ? Correct me if i am wrong, your handbrake work on your rear wheel. Remember our driving lesson where we are always told to pull handbrake when on slope. Link to post Share on other sites More sharing options...
Kb27 Supersonic October 24, 2010 Share October 24, 2010 Handbrake is the only device that can stop your car from moving when it is parked and engine is off. It does not rely on hydraulics and vacuum which your main brake used. So the braking action is very limited and not meant for a moving car. But some people found it useful for drifting. Link to post Share on other sites More sharing options...
Kb27 Supersonic October 24, 2010 Share October 24, 2010 I see. Is it easy to check at a typical servicing session or do I have to take apart some sections of the car before I can check the drum shoes? The drum brake can be open during servicing by removing the rear tyre and probably a screw or bolt on the drum. Don't worry too much about the shoes. They can take quite a bit of abuse and still work ok. Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear October 24, 2010 Share October 24, 2010 Unwittingly drove off without releasing the handbrake today. Leads me to wonder why the accelerator can override the handbrake, anyone knows? It seems to me it is safer if handbrake overrides accelerator. Makes me also a little worried that my car mechanism will be damaged if I make such mistakes or that the handbrake will one day fail after parking the car... handbrake is somehow a mechanical stuff. if the handbrake is not pull upwards fully, car is still able to move if you step on the accelerator. i believe if handbrake is applied not fully, car will not move unless there is a slope. even so, you will notice the movement before you leave your car. there is now, electronic handbrake, which enables the brakes to fully engaged if you turn it on. most cars now are still using the mechanical braking. mine's a footbrake instead of handbrake and still a mechanical braking system. when i forgotten to release my footbrake and i applied my accelerator, my car will still move.~ but there will be a warning beeping sound and it will indicate "Release Foot Brake" infront of my screen. Link to post Share on other sites More sharing options...
Happily1986 5th Gear October 24, 2010 Share October 24, 2010 Am not confident of my handbrake. Normally at idle, the rpm will alternate sinusoidally cos maybe the alternator load as well as the a/c compressor fan keeps varying. Sometimes i can feel the car shudder as if it can creep forward. Sometimes it does. So now i just step on the normal brake pedal just in case. Link to post Share on other sites More sharing options...
questionedfish Clutched October 24, 2010 Share October 24, 2010 Unwittingly drove off without releasing the handbrake today. Leads me to wonder why the accelerator can override the handbrake, anyone knows? It seems to me it is safer if handbrake overrides accelerator. Makes me also a little worried that my car mechanism will be damaged if I make such mistakes or that the handbrake will one day fail after parking the car... i only know that by driving with handbrake on, your handbrake thingy (the mechanism inside etc) will be damaged and spoit Link to post Share on other sites More sharing options...
Nzy Twincharged October 24, 2010 Share October 24, 2010 I think the handbrake is good enough to hold ur car on slopes but not enough to prevent ur car from moving if u try to accelerate. Even on my car with 1.4l engine also can move off with handbrake if I want to. Link to post Share on other sites More sharing options...
Nf0rc3r 1st Gear October 24, 2010 Share October 24, 2010 I dun trust my handbrake. May "Pop out" anytime one. When parking I put into 1st Gear and its upslope and R when its downslope lol.. Link to post Share on other sites More sharing options...
Sohboonguan 1st Gear October 24, 2010 Share October 24, 2010 My car dun move... my front wheel spins... if i pull my hand brake all the way up... the front wheel tried to overcome the friction on the rear tyre... so if it does overcome the rear wheel friction? it will drag your car... either way... it is not good for both tyres and brakes... Link to post Share on other sites More sharing options...
GoodCar 4th Gear October 24, 2010 Share October 24, 2010 My car dun move... my front wheel spins... if i pull my hand brake all the way up... the front wheel tried to overcome the friction on the rear tyre... so if it does overcome the rear wheel friction? it will drag your car... either way... it is not good for both tyres and brakes... Hi Ah Guan, You punishing your car arh? wait the good car become no good car liao. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear October 24, 2010 Share October 24, 2010 Unwittingly drove off without releasing the handbrake today. Leads me to wonder why the accelerator can override the handbrake, anyone knows? It seems to me it is safer if handbrake overrides accelerator. Makes me also a little worried that my car mechanism will be damaged if I make such mistakes or that the handbrake will one day fail after parking the car... Handbrake needs attention/workshop service Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear October 24, 2010 Share October 24, 2010 If you pulled very hard on the handbrake, you will likely be able to overcome the engine power at low throttle position. The handbrake is only mostly on the rear wheels, also the design strength is not to stop a running car. But to prevent a stationary from moving on it's own weight and gravity! Your handbrake knowledge needs enlightenment (inadequate) Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear October 24, 2010 Share October 24, 2010 Handbrake is the only device that can stop your car from moving when it is parked and engine is off. It does not rely on hydraulics and vacuum which your main brake used. So the braking action is very limited and not meant for a moving car. But some people found it useful for drifting. You got the point. You are right. After some drifting wonder why the carcass failed? (laugh) Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear October 24, 2010 Share October 24, 2010 handbrake is somehow a mechanical stuff. if the handbrake is not pull upwards fully, car is still able to move if you step on the accelerator. i believe if handbrake is applied not fully, car will not move unless there is a slope. even so, you will notice the movement before you leave your car. there is now, electronic handbrake, which enables the brakes to fully engaged if you turn it on. most cars now are still using the mechanical braking. mine's a footbrake instead of handbrake and still a mechanical braking system. when i forgotten to release my footbrake and i applied my accelerator, my car will still move.~ but there will be a warning beeping sound and it will indicate "Release Foot Brake" infront of my screen. Can share with us what car you drive? No mechanical handbrake? ↡ Advertisement Link to post Share on other sites More sharing options...
Driving in Europe
Driving in Europe
Given the recent Scoot debacle would you still take Scoot?
Strange Mural at Holland Drive Food Center
