Hulk 1st Gear October 4, 2010 Share October 4, 2010 Hi bros, Recently when I depress my brake padal, there is a "tock" sound heard. Serviced brake but sound still come back. I am driving a Toyota, heard that this is a known problem for Toyota that the "tock" sound come from the brake caliper. Any bro who have this problem before? The sound is so irritating that I feel want to replace the whole brake caliper. How much to get stock caliper? Which stockist to get? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Aaron_soh80 1st Gear October 4, 2010 Share October 4, 2010 Hi bros, Recently when I depress my brake padal, there is a "tock" sound heard. Serviced brake but sound still come back. I am driving a Toyota, heard that this is a known problem for Toyota that the "tock" sound come from the brake caliper. Any bro who have this problem before? The sound is so irritating that I feel want to replace the whole brake caliper. How much to get stock caliper? Which stockist to get? I aso face dis problem..when braking got sound..i thought is brake pad but change le still the same.. esp when braking on a down slope ..more louder.. me driving city ya.. 1 Link to post Share on other sites More sharing options...
Mini-itx Clutched October 4, 2010 Share October 4, 2010 Noise from brakes, sometimes its quite normal sometimes it may be warped rotor. Sometimes its due to the way the pistons compresses the pads onto the rotors. 1 Link to post Share on other sites More sharing options...
Hulk 1st Gear October 4, 2010 Author Share October 4, 2010 Noise from brakes, sometimes its quite normal sometimes it may be warped rotor. Sometimes its due to the way the pistons compresses the pads onto the rotors. Ya this is what I feel also is the piston problem. Link to post Share on other sites More sharing options...
Tiphoneas Neutral Newbie October 4, 2010 Share October 4, 2010 Ya this is what I feel also is the piston problem. i 2nd that. do a check at workshop and highlight this to them. some workshop can't diagnose the problem, and once you tell them where and what, they can check and mystery solved! 1 Link to post Share on other sites More sharing options...
R_aquarii 1st Gear October 4, 2010 Share October 4, 2010 my toyota vios also got this noise.. if the problem is with the piston is there any solution? 1 Link to post Share on other sites More sharing options...
Hulk 1st Gear October 5, 2010 Author Share October 5, 2010 my toyota vios also got this noise.. if the problem is with the piston is there any solution? I'm waiting to see a mechanic who work in agent, recommended by my colleague to see my brake "tock" sound problem now. If can replace piston I will do it, if can't I will replace the whole brake caliper system, don't mind spend little bit more as long can get rid of the irritating sound. Link to post Share on other sites More sharing options...
Yr1985 1st Gear November 22, 2012 Share November 22, 2012 (edited) long time ago thread, but my Vios have his problem now. Anyone can help? Hulk? Edited November 22, 2012 by Yr1985 Link to post Share on other sites More sharing options...
Rustyz 5th Gear November 22, 2012 Share November 22, 2012 (edited) long time ago thread, but my Vios have his problem now. Anyone can help? Hulk? Can try record the sound and upload. Word may not be the best describe it maybe diff sound diff solution. Can try use water spray the brake pad sometime is just dirty. Do it when the brake are cool. Edited November 22, 2012 by Rustyz Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 23, 2012 Share November 23, 2012 long time ago thread, but my Vios have his problem now. Anyone can help? Hulk? Tok sound likely some bolt is loose. Hv it throughly checked. If e nut or blot comes out u cud hv no brakes. Raise car up n stand below n rock car to see where sound us from. Link to post Share on other sites More sharing options...
Newdrive 1st Gear November 23, 2012 Share November 23, 2012 (edited) Hi bros, Recently when I depress my brake padal, there is a "tock" sound heard. Serviced brake but sound still come back. I am driving a Toyota, heard that this is a known problem for Toyota that the "tock" sound come from the brake caliper. Any bro who have this problem before? The sound is so irritating that I feel want to replace the whole brake caliper. How much to get stock caliper? Which stockist to get? not sure if the sound u getting same as mine. i am driving toyota vios though. WS tell me cause one of my rear brake caliper... there is 2 pin, one is missing and they cannot replace cos the hole is misaligned... hence need to replace the whole caliper! if u want, we can meet up... and listen to each other car's sound. it happens to me whenever i brake or reverse. Edited November 23, 2012 by Newdrive Link to post Share on other sites More sharing options...
Inlinefour Twincharged November 23, 2012 Share November 23, 2012 Might be small little sand on the brake pad then press onto rotor disc also got sound... Link to post Share on other sites More sharing options...
Yr1985 1st Gear November 23, 2012 Share November 23, 2012 not sure if the sound u getting same as mine. i am driving toyota vios though. WS tell me cause one of my rear brake caliper... there is 2 pin, one is missing and they cannot replace cos the hole is misaligned... hence need to replace the whole caliper! if u want, we can meet up... and listen to each other car's sound. it happens to me whenever i brake or reverse. Aku drive Vios too!! Now I am at BM, tech uncle said could be ABS actualator. They are now checking for me. Will update here later Link to post Share on other sites More sharing options...
Jphua Neutral Newbie November 25, 2012 Share November 25, 2012 Tok sound likely some bolt is loose. Hv it throughly checked. If e nut or blot comes out u cud hv no brakes. Raise car up n stand below n rock car to see where sound us from. tis could be a point. mine caliper's threaded hole is gone hence the bolt to to tighten the caliper is loose. so when brake is pressed, tock sound come out as the bolt is lossen. pls hoist up the car & check. refer to the pic attached. see the rusty bolt in the center of the pic. you'll see there is a gap between the bolt & the bracket. tis is my case. best advise to bro who heard sounds from braking, pls do send for a check. brake system don play play. Link to post Share on other sites More sharing options...
Newdrive 1st Gear November 25, 2012 Share November 25, 2012 (edited) tis could be a point. mine caliper's threaded hole is gone hence the bolt to to tighten the caliper is loose. so when brake is pressed, tock sound come out as the bolt is lossen. pls hoist up the car & check. refer to the pic attached. see the rusty bolt in the center of the pic. you'll see there is a gap between the bolt & the bracket. tis is my case. best advise to bro who heard sounds from braking, pls do send for a check. brake system don play play. looks like similar to me but mine is the hole that the 2 pins is holding on to. one of the hole already buang... so now left 1 pin to hold. i am still looking at scrap yards to look for a better condition to replace one of my rear brake caliper. Edited November 25, 2012 by Newdrive Link to post Share on other sites More sharing options...
Hondafit2008 Clutched November 25, 2012 Share November 25, 2012 tock sound is brake system got something loose, piston pot or pad catch or rotor. while braking got metal sound (eeeee) is cos pads change liao but rotor no skim so uneven rubbing. got is from other forum hope helps Link to post Share on other sites More sharing options...
Jphua Neutral Newbie November 26, 2012 Share November 26, 2012 looks like similar to me but mine is the hole that the 2 pins is holding on to. one of the hole already buang... so now left 1 pin to hold. i am still looking at scrap yards to look for a better condition to replace one of my rear brake caliper. do drive safely bro may i know wad caliper u r using rite now, stock or bbk? Link to post Share on other sites More sharing options...
Jphua Neutral Newbie November 27, 2012 Share November 27, 2012 this is not normal , this is rotor got problem , u can try to do disc skimming only $60-$80 if rotor is uneven, normally it will produce a screeching sounds rather than a tock tock sounds. tat's wad i think so... best is TS go check his brake be it caliper, rotor, any bolts connection better. ↡ Advertisement Link to post Share on other sites More sharing options...
Sound Proofing the car
Whole car sound proof
Whining sound : Lift off accelerator
Brake Pads
Brake Pads
Right side speakers no sound
