Lendevear 1st Gear September 25, 2010 Share September 25, 2010 Hi guys, my fuel meter just died. It constantly stays at the empty mark prompting the warning indicator lights on all the time. Anyone knows where and how much it takes to repair the meter? Appreciate your help! Car: Nissan Sunny stock 2006. ↡ Advertisement Link to post Share on other sites More sharing options...
Yeobh 4th Gear September 25, 2010 Share September 25, 2010 Looks like it's yr fuel level sensor that is out of order. Yr mech needs to remove the fuel pump complete assemble and replace with a new unit. Link to post Share on other sites More sharing options...
Lendevear 1st Gear September 25, 2010 Author Share September 25, 2010 That sounds really ex! Link to post Share on other sites More sharing options...
Kb27 Supersonic September 25, 2010 Share September 25, 2010 For my car, I would take out the connector and check the resistor reading. Fuel sender is just a mechanical float that would seemed impossible to spoil. What can go wrong maybe the connector or wire loose. Otherwise the next expensive item that can spoil would be the ecu itself. Link to post Share on other sites More sharing options...
Mini-itx Clutched September 25, 2010 Share September 25, 2010 On 9/25/2010 at 1:55 PM, Kb27 said: For my car, I would take out the connector and check the resistor reading. Fuel sender is just a mechanical float that would seemed impossible to spoil. What can go wrong maybe the connector or wire loose. Otherwise the next expensive item that can spoil would be the ecu itself. Its usually wiring fault. But very unlikely ECU. Cause fuel level is not wired to the ECU (maybe only highend cars do that), its wired to the cluster. Thus it would be cluster faulty rather than ECU. But somethings the mechanical float can spoil too. Cause its plastic. Sometimes, plastic crack and the float gets stuck or something. Link to post Share on other sites More sharing options...
C-K 2nd Gear September 25, 2010 Share September 25, 2010 why not just fix it @ 3/4 tank or almost full tank all the time and install another removable hidden gauge somewhere.. then u can go Jaybee pump petrol as and when you like.. less likely to kena caught also.. Link to post Share on other sites More sharing options...
Yeobh 4th Gear September 26, 2010 Share September 26, 2010 (edited) Here is a in tank fuel pump with float and level sensing device Edited September 26, 2010 by Yeobh Link to post Share on other sites More sharing options...
England90 Neutral Newbie September 29, 2010 Share September 29, 2010 You should go to a repair center of genuine and will ensure safe! Link to post Share on other sites More sharing options...
5936 1st Gear September 29, 2010 Share September 29, 2010 (edited) Possible to reverse it. ? E- means full F - means empty save alot of trouble with hidden switches. Unless driver forgot to interpret it in reverse. Edited September 29, 2010 by 5936 Link to post Share on other sites More sharing options...
5936 1st Gear September 29, 2010 Share September 29, 2010 (edited) Before you buy or remove the fuel pump/sensor assembly from the tank, you could test the fuel meter first by bridging the 2 terminals to the meter. Meter move to full means, problem in the fuel sensor. You could buy from stockist. DIY or ask wskp to replace lah. fuel pump, fuel filter, and some clips to trnsfaer to new sensor. Remember to get the intank fuel filter if it does not come along with the unit. Edited September 29, 2010 by 5936 Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 29, 2010 Share September 29, 2010 You need to get it fixed cos you dun want those customs guys fining you for having a faulty guage even if you drive in with more than 3/4 tank. Link to post Share on other sites More sharing options...
Yeobh 4th Gear September 29, 2010 Share September 29, 2010 I strongly don't recommend to car owners to DIY fuel gauge/pump unit. Gasoline fuel fume is very volatile, removing sender unit require special wrench and tools ( preferably non-spark tool), any spark generated can easily cause explosion. Also do not try to electrically simulate the sender unit when it is out of the tank, as there are still some fuel present in the pump. The sparks from the pump commutator will cause explosion. Pl take care. Link to post Share on other sites More sharing options...
5936 1st Gear September 29, 2010 Share September 29, 2010 Thanks for the safety advice. Keep away from ignition sources and static electricity. Gas vapour from petrol is to be handled with respect and knowledge. Spillage can also ruin upholsteries and paint works. Link to post Share on other sites More sharing options...
Mini-itx Clutched September 30, 2010 Share September 30, 2010 On 9/29/2010 at 8:34 AM, Jamesc said: You need to get it fixed cos you dun want those customs guys fining you for having a faulty guage even if you drive in with more than 3/4 tank. I agreed.... Thats why I can't go MY now because my fuel meter is spoilt :( Have yet to get it fixed. It always show empty even though its full..... I know it has to be some wiring problem because I tested my sender and I am getting resistance from it (not infinite or zero). Means its either the wire going to my cluster got problem or even my cluster itself. Need to spend time to trace wire and check cluster..... Tedious so don't really bother yet. Not going to WS to fix cause I feel its a waste of money. Rather DIY. ↡ Advertisement Link to post Share on other sites More sharing options...
Pope Francis RIP
Pope Francis RIP
Another doctor in trouble
RIP: Donald Sutherland
Calciphylaxis: An almost fatal disease.
Hydrogen cars could be headed to showroom near you
