Lalaisgongon Clutched September 25, 2010 Share September 25, 2010 anybody knows the difference btw keyless go vs keyless entry or do they come together. eg. the new PI e class, doesnt come with keyless go, but apparently comes with keyless entry. does keyless entry means just pull door handle to unlock? ↡ Advertisement Link to post Share on other sites More sharing options...
Coupecabriolet Clutched September 25, 2010 Share September 25, 2010 if im not wrong, keyless entry: enter door by pressing the small rubber button on the door handle to unlock (doesnt even require pressing of remote, only require remote in ur pocket or within a specific radius) keyless go: means push start button, if key is in ur pocket and u are in driver seat, push onto the brake pedal, press push start button to start engine. for mercedes benz new e-class, the remote is not the conventional key, its shaped weirdly but still can slot into a weirder keyhole in the car cabin, meaning no keyless go, still need to slot in key / remote and turn. but should have option for keyless go, probably higher variants, not sure Link to post Share on other sites More sharing options...
Limwilliam17 Neutral Newbie September 25, 2010 Share September 25, 2010 Keyless entry_Hold door handle to unlock and push little black rubber to lock.Remote in pocket and within 70cm near doors. Keyless go_Step on brake and push button to start.No need to insert key.Just leave it in your pocket. Link to post Share on other sites More sharing options...
ER-3682 Twincharged September 25, 2010 Share September 25, 2010 For Mercedes-Benz,if you see a silver button[starter] on the gearshift,this is keyless go,i think all new E class is equiped with it. Link to post Share on other sites More sharing options...
Minikong 1st Gear September 25, 2010 Share September 25, 2010 actually this techonology is miost suitable for ladies that put the key in tthe hand bag, the reason why they shape it so weidly, is 1stly because of looks, 2ndly did u notice that you put the car key in your pocket for long, it will damamge your pocket? 3rdly, 1 key cost over $300++ and if u lost it, the onyl way is to buy back from dealer haha. if your car dont have the start stop button, u will need to insert the key into the key hole, and cant just press start and go. Link to post Share on other sites More sharing options...
Xtrocious 1st Gear September 26, 2010 Share September 26, 2010 On 9/25/2010 at 11:37 AM, Minikong said: actually this techonology is miost suitable for ladies that put the key in tthe hand bag, the reason why they shape it so weidly, is 1stly because of looks, 2ndly did u notice that you put the car key in your pocket for long, it will damamge your pocket? 3rdly, 1 key cost over $300++ and if u lost it, the onyl way is to buy back from dealer haha. if your car dont have the start stop button, u will need to insert the key into the key hole, and cant just press start and go. Mercedes key cost S$700+ hor Plus got to wait 2 weeks for them to ship over from Germany Link to post Share on other sites More sharing options...
Jp66 5th Gear September 26, 2010 Share September 26, 2010 On 9/25/2010 at 11:21 AM, Coupecabriolet said: if im not wrong, keyless entry: enter door by pressing the small rubber button on the door handle to unlock (doesnt even require pressing of remote, only require remote in ur pocket or within a specific radius) except for KM, their definition of keyless entry means 'open the door without using the key, i.e. remote key, not rubber button on door handle' Link to post Share on other sites More sharing options...
Alechi 2nd Gear September 26, 2010 Share September 26, 2010 got high value ah ? keyless Link to post Share on other sites More sharing options...
SimonTan 2nd Gear September 26, 2010 Share September 26, 2010 Yes. My jazz also considered keyless entry. Meaning you hold the key in your hand, press the key black button to unlock the door. Open the door, insert the metal key, twist to start and go. What is so keyless about that. The true keyless is in Lexus and BMW. You just Hold the door handle and it unlocks! No need to press any black buttons. Then you step brake, and push start button to start engine. All the while the keys in your bag. Press button to stop engine, open and close door. Touch the handle again to lock the car before you walk away! Now that is true keyless! Of course there are aftermarket totally keyless retrofit as well. Where you just have the transponder in your pocket, the door wil unlock and lock when you walk near or walk away. Link to post Share on other sites More sharing options...
Tweakmax2 Neutral Newbie September 26, 2010 Share September 26, 2010 The true keyless is in Lexus and BMW. You just Hold the door handle and it unlocks! No need to press any black buttons. Then you step brake, and push start button to start engine. All the while the keys in your bag. Press button to stop engine, open and close door. Touch the handle again to lock the car before you walk away! Now that is true keyless! Same as Latio and Slphy Link to post Share on other sites More sharing options...
Minikong 1st Gear September 26, 2010 Share September 26, 2010 On 9/26/2010 at 10:26 AM, Tweakmax2 said: The true keyless is in Lexus and BMW. You just Hold the door handle and it unlocks! No need to press any black buttons. Then you step brake, and push start button to start engine. All the while the keys in your bag. Press button to stop engine, open and close door. Touch the handle again to lock the car before you walk away! Now that is true keyless! Same as Latio and Slphy seriously speaking thou my mini come with this technology, but i never use this, as you will have high tendancy to keep forgeting your key haha Link to post Share on other sites More sharing options...
Darthrevan Supercharged September 26, 2010 Share September 26, 2010 On 9/26/2010 at 10:29 AM, Minikong said: seriously speaking thou my mini come with this technology, but i never use this, as you will have high tendancy to keep forgeting your key haha not for me..i am so used to driving without using keys to unlock and not having to use keys to start the car..so blessed to have this technology Link to post Share on other sites More sharing options...
Minikong 1st Gear September 26, 2010 Share September 26, 2010 On 9/26/2010 at 10:39 AM, Darthrevan said: not for me..i am so used to driving without using keys to unlock and not having to use keys to start the car..so blessed to have this technology ya by the way around how long u can use the keyless before the battery run flat? ususally when will u charge your key? Link to post Share on other sites More sharing options...
Tansrb Neutral Newbie September 26, 2010 Share September 26, 2010 volvo uses keyless technology too. no need to press any buttons. just straight away go towards the door with the key and open it. Link to post Share on other sites More sharing options...
Darthkk Clutched September 26, 2010 Share September 26, 2010 On 9/26/2010 at 10:29 AM, Minikong said: seriously speaking thou my mini come with this technology, but i never use this, as you will have high tendancy to keep forgeting your key haha errrr.. why would you forget the key? the key is always in your bag or in your pocket if not you cannot unlock or start the car ma... But tendency to forget to lock the car is very high. Link to post Share on other sites More sharing options...
Darthrevan Supercharged September 26, 2010 Share September 26, 2010 On 9/26/2010 at 10:45 AM, Minikong said: ya by the way around how long u can use the keyless before the battery run flat? ususally when will u charge your key? slightly over 1 year..the battery won't totally run flat..just that the responsiveness is not there..and roughly u know time to change battery Link to post Share on other sites More sharing options...
Joseph22 Turbocharged September 26, 2010 Share September 26, 2010 On 9/26/2010 at 10:26 AM, Tweakmax2 said: The true keyless is in Lexus and BMW. You just Hold the door handle and it unlocks! No need to press any black buttons. Then you step brake, and push start button to start engine. All the while the keys in your bag. Press button to stop engine, open and close door. Touch the handle again to lock the car before you walk away! Now that is true keyless! Same as Latio and Slphy lancer EX too right? heard that Forte also. Link to post Share on other sites More sharing options...
Minikong 1st Gear September 26, 2010 Share September 26, 2010 On 9/26/2010 at 3:46 PM, Darthrevan said: slightly over 1 year..the battery won't totally run flat..just that the responsiveness is not there..and roughly u know time to change battery oooo hahahha kk. change battery? i touhght just put the key inside the key hole in your car and will charge up itself? ↡ Advertisement Link to post Share on other sites More sharing options...
McLaren entry level sports car, 570S and its related series
EPS car park gantry - no entry record
New VW still using key ignition
Free entry to Jurong Bird Park Sept. 6-15, 2019
Malaysia custom officer tore SG passport and denied entry
LTA reply letter on Vehicle Entry Permit pricing
The thing with keyless...
Push start button and keyless entry alrams
