Good-Carbuyer 1st Gear September 21, 2010 Share September 21, 2010 A brother of mine sent his second Sunny for CNG conversion since he drives quite a lot. Recently, with the engine warmed up, the car is having starting problem. AD workshop still not sure the cause(es) Anyone with similar exposure to share? ↡ Advertisement Link to post Share on other sites More sharing options...
Tianmo Hypersonic September 21, 2010 Share September 21, 2010 A brother of mine sent his second Sunny for CNG conversion since he drives quite a lot. Recently, with the engine warmed up, the car is having starting problem. AD workshop still not sure the cause(es) Anyone with similar exposure to share? I don't know if this will help, had some problem with my CNG also, but with the help of Genie47, now ok liao. likely a hardware issue, check the spark plugs and the plug cables, I changed the plug cables and gap down my plugs to 0.9mm, problem solve. you may want to let your brother know. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear September 22, 2010 Author Share September 22, 2010 I don't know if this will help, had some problem with my CNG also, but with the help of Genie47, now ok liao. likely a hardware issue, check the spark plugs and the plug cables, I changed the plug cables and gap down my plugs to 0.9mm, problem solve. you may want to let your brother know. Many thanks. I wonder what the AD workshop did for him all this while. AD workshop suggested dismantling the engine for research as they have no clue/trouble-shooting skill for this Link to post Share on other sites More sharing options...
Colin03 4th Gear September 22, 2010 Share September 22, 2010 Better not let the CNG staffs R&D your engine. My suggestion is also change to a better performance spark plugs and narrow the gap of the electrode. Changing the spark plug cable at a later stage if still cannot achieve your expectation. Spark plug cable - to have a booster would be much better. Just my thought. Link to post Share on other sites More sharing options...
Tianmo Hypersonic September 22, 2010 Share September 22, 2010 Many thanks. I wonder what the AD workshop did for him all this while. AD workshop suggested dismantling the engine for research as they have no clue/trouble-shooting skill for this I hate to say this, but AD ws kn next to nothing when it comes to CNG. When I send my ride to AD for the CNG problem, they just tell me is the software issue, when I told them it could be the plug cable, they insisted that no problem with hardware. But after I changed the plug cable problem solved. Link to post Share on other sites More sharing options...
Tianmo Hypersonic September 22, 2010 Share September 22, 2010 Better not let the CNG staffs R&D your engine. My suggestion is also change to a better performance spark plugs and narrow the gap of the electrode. Changing the spark plug cable at a later stage if still cannot achieve your expectation. Spark plug cable - to have a booster would be much better. Just my thought. yes, yes! I agree, better not let them R&D the engine, if not Bo d Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear September 22, 2010 Author Share September 22, 2010 Better not let the CNG staffs R&D your engine. My suggestion is also change to a better performance spark plugs and narrow the gap of the electrode. Changing the spark plug cable at a later stage if still cannot achieve your expectation. Spark plug cable - to have a booster would be much better. Just my thought. I check with my brother if his car warranty over, I DIY for him may be better than the AD workshop people with no clue (I believe AD workshop more familiar with servicing not trouble-shooting). If AD workshop people good in trouble-shooting, sure proached by others soon Link to post Share on other sites More sharing options...
Tianmo Hypersonic September 27, 2010 Share September 27, 2010 I check with my brother if his car warranty over, I DIY for him may be better than the AD workshop people with no clue (I believe AD workshop more familiar with servicing not trouble-shooting). If AD workshop people good in trouble-shooting, sure proached by others soon any updates? Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear September 27, 2010 Author Share September 27, 2010 any updates? Many thanks for your kindness. He may be de-commissioning the CNG installation like some others had already done so. I believe the Sunny engine compression ratio not fully compatible for sustainable CNG conversion (almost normal operation with petrol, about 60% power with CNG). Could be CNG overheated the engine/engine oil Link to post Share on other sites More sharing options...
Tianmo Hypersonic September 27, 2010 Share September 27, 2010 Many thanks for your kindness. He may be de-commissioning the CNG installation like some others had already done so. I believe the Sunny engine compression ratio not fully compatible for sustainable CNG conversion (almost normal operation with petrol, about 60% power with CNG). Could be CNG overheated the engine/engine oil so sad to hear this well, maintaining hardware in shape is very important for CNG cars, because of the heat, must pay attention to EO and battery, I check my battery every month and always have to top up water. did he try changing the plugs and cable? Link to post Share on other sites More sharing options...
Krado Clutched September 27, 2010 Share September 27, 2010 A brother of mine sent his second Sunny for CNG conversion since he drives quite a lot. Recently, with the engine warmed up, the car is having starting problem. AD workshop still not sure the cause(es) Anyone with similar exposure to share? CNG = Car No Good. Enough said. Link to post Share on other sites More sharing options...
Tianmo Hypersonic September 27, 2010 Share September 27, 2010 CNG = Car No Good. Enough said. can be Cheap N Good? Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear September 27, 2010 Author Share September 27, 2010 (edited) can be Cheap N Good? CNG was promoted without accurate information/data. So some motorists wasted money on conversion. Some workshop wasted money on facilities for conversion business. Now some motorists already de-commission the CNG installation for their cars Edited September 27, 2010 by Good-Carbuyer Link to post Share on other sites More sharing options...
Picanto 3rd Gear September 27, 2010 Share September 27, 2010 which shop do the CNG? Link to post Share on other sites More sharing options...
Krado Clutched September 27, 2010 Share September 27, 2010 can be Cheap N Good? There's a saying: Good, Not Cheap. Cheap, Not Good. Want cheap and good, wait long long. ↡ Advertisement Link to post Share on other sites More sharing options...
Encounters with tyre shop
