Vroomtattat 2nd Gear September 17, 2010 Author Share September 17, 2010 On 9/17/2010 at 9:09 AM, Happily1986 said: 1.) Calculate impedance of each fan using input voltage = 12V and input current = 0.12A Impedance is taken to be approximately the resistance of the fan Thus R =V/I = 12V/0.12A = 100 ohm 2.) Total impedance/resistance of the 10 fans Since fans are in series, we have to utilise the parallel addition rule. 1/(total resistance) = 1/(resistance of fan 1) + 1/(resistance of fan 2) + ... + 1/(resistance of fan 10) Taking reciprocal, total resistance = 10 ohm 3.) Current flowing in parallel circuit (with all the fans connected) Current I = V/R I=1.2 Ampere 4.) Stamina of electrical setup Time = Amperage hour / (current drawn) = 7.2Ah/ 1.2A = 6 hours 5.) We cannot assume that heat generation i.e. wastage is minimal thus you should expect the stamina time to be below 6 hours. Bro, 6 fans thia . . . . can recalculate for me please? Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Happily1986 5th Gear September 18, 2010 Share September 18, 2010 1.) Calculate impedance of each fan using input voltage = 12V and input current = 0.12A Impedance is taken to be approximately the resistance of the fan Thus R =V/I = 12V/0.12A = 100 ohm 2.) Total impedance/resistance of the 10 fans Since fans are in series, we have to utilise the parallel addition rule. 1/(total resistance) = 1/(resistance of fan 1) + 1/(resistance of fan 2) + ... + 1/(resistance of fan 10) Taking reciprocal, total resistance = 16.67 ohm 3.) Current flowing in parallel circuit (with all the fans connected) Current I = V/R I=12V/16.67ohm =0.72 A 4.) Stamina of electrical setup Time = Amperage hour / (current drawn) = 7.2Ah/ 0.72A = 10 hours 5.) We cannot assume that heat generation i.e. wastage is minimal thus you should expect the stamina time to be below 10 hours. pai seh, earlier on bak chiu tah stamp thought is 10 fans LOL Link to post Share on other sites More sharing options...
Vroomtattat 2nd Gear September 18, 2010 Author Share September 18, 2010 (edited) Hey! Thanks bro. Went down to SL Tower on Friday and got my self the following :- 6 slim computer fans (25mm by 25mm each, rated 12V 0.12A) A sealed lead acid rechargeable battery, 12V 7.2Ah A *Super* brand battery charger for 6 & 12V batts Velcro tape, 3M double sided tape, a metre of wire and 2 clip connectors. Total costs : <$80 Taped 5 fans together in a row, wired them in parallel connection and doing a test run now to see how long they can continue running and oh boy! the fans are zipping along fine . . . . quite strong leh. WooHooo! Plan to leave a gap in the car window and hook it up with velcro to blow out the hot air. My CO say I seow Don't laugh at me, please. Edited September 18, 2010 by Vroomtattat Link to post Share on other sites More sharing options...
5936 1st Gear September 18, 2010 Share September 18, 2010 Boleh!!! LIVE YOUR DREAM, ON YOUR FAN 2010 Did you get a switch for it. Or yo intend to operate out from the terminals. Link to post Share on other sites More sharing options...
Vroomtattat 2nd Gear September 18, 2010 Author Share September 18, 2010 On 9/18/2010 at 3:27 PM, 5936 said: Boleh!!! LIVE YOUR DREAM, ON YOUR FAN 2010 Did you get a switch for it. Or yo intend to operate out from the terminals. Oh goober!! Forgot to buy the SWITCH! Back to SL Tower on Monday . . . Thanks for the reminder bro. Link to post Share on other sites More sharing options...
Rainman 1st Gear September 18, 2010 Share September 18, 2010 On 9/18/2010 at 1:57 PM, Vroomtattat said: Hey! Thanks bro. Went down to SL Tower on Friday and got my self the following :- 6 slim computer fans (25mm by 25mm each, rated 12V 0.12A) A sealed lead acid rechargeable battery, 12V 7.2Ah A *Super* brand battery charger for 6 & 12V batts Velcro tape, 3M double sided tape, a metre of wire and 2 clip connectors. Total costs : <$80 Taped 5 fans together in a row, wired them in parallel connection and doing a test run now to see how long they can continue running and oh boy! the fans are zipping along fine . . . . quite strong leh. WooHooo! Plan to leave a gap in the car window and hook it up with velcro to blow out the hot air. My CO say I seow Don't laugh at me, please. End of the day, u will find it very inconvenient as u need to recharge the battery, rem to leave a gap etc. Not to say ur 6 fans is unlikely to cool the car at all.... I say save ur 80 bucks and time..... Link to post Share on other sites More sharing options...
Caravan 5th Gear September 19, 2010 Share September 19, 2010 Why don't you connect to a solar panel, like what they are selling on ebay? Link to post Share on other sites More sharing options...
Karoon Turbocharged September 19, 2010 Share September 19, 2010 On 9/18/2010 at 1:57 PM, Vroomtattat said: Hey! Thanks bro. Went down to SL Tower on Friday and got my self the following :- 6 slim computer fans (25mm by 25mm each, rated 12V 0.12A) A sealed lead acid rechargeable battery, 12V 7.2Ah A *Super* brand battery charger for 6 & 12V batts Velcro tape, 3M double sided tape, a metre of wire and 2 clip connectors. Total costs : <$80 Taped 5 fans together in a row, wired them in parallel connection and doing a test run now to see how long they can continue running and oh boy! the fans are zipping along fine . . . . quite strong leh. WooHooo! Plan to leave a gap in the car window and hook it up with velcro to blow out the hot air. My CO say I seow Don't laugh at me, please. good idea. does it work? there are similar fans running on solar to cool the car before one goes in but they don't work. i mean the fans run but the effect on interior temperature is about 0.2DegC compared to without fan (some dude this an experiment in oz summer) http://www.shopwiki.co.uk/solar+car+fan Link to post Share on other sites More sharing options...
Saycheese78 Clutched September 19, 2010 Share September 19, 2010 To prevent accidents fro happening. I suggest tieing a fuse (1A, 2A, 3A also can) to the battery before connecting to the fans in parallel. if not, a short circuit fan will cause battery to catch fire! ↡ Advertisement Link to post Share on other sites More sharing options...
MyResponder app to call SCDF
Help with STA report remarks
Old WW2 Relic disposals
HELP! Upstairs neighbour causing sleepness nights
