Help! How to calculate this amphere hour thingy?
Vroomtattat
I'm a noobie at electrical stuff and would be glad if any expert out there can help me with this.
6 small pc fans each rated at 12V 0.12A, connected in parallel to a 12V sealed lead-acid rechargeable battery (7.2Ah).
How long can the fans run? 7 hours?
And what is that measuring device which can measure voltage called? Volt meter? The one which technicians use to check for connectivity or something? Where can I get one and how much is it.
Heh hee . . . . sorry arhh, totally clueless when it comes to electrical. [:p]
Please advise. Thank you.
Try this website for info
http://www.windpowerunlimited.com/batteries/Amp_Hours.htm
should be 10 hrs...each draw 0.12A so 6 fan will draw 0.72A..the battery can provide 7.2A for one hr....which means drawing 0.72A....it will last 7.2/0.72 = 10 hrs...
the thing is call multi meter....Sim lim tower can get very cheap 1....nothing more than SGD15-20 for a simple 1 which can measure current...DC...AC...resistant...diode etc......
10 hrs is theoretical....according to tat website, actual hours will be less (see tat graph).
ya lar....if temperture etc etc etc all taken in....but i guess what TS need is on theory and he probably not interested up to the last seconds... :D:D
Wah the batt damn heavy man . . . [sweatdrop]
About the size of 5 ciggy packs thia . .
no problem...hope my little knowledge can help u... [:p] but as what bro Zztensor mention...it is in theory...so if you are doing something critical...do put in some safety factor..... :D
Don't frighten me leh brudder . . . [sweatdrop]
I doing this hare-brained car ventilation project . . . heh hee, jia pa boh dai ji zheo [laugh]
If you have a quality battery charger, don't worry as all have polarity protection switch. Since you are charging the battery at home ( not connected to the car system) which ever terminal you connect does not matter at all.
Good luck in yr DIY
Good luck in yr DIY
Okay bro, I'll try now in the office. [sweatdrop]
do show post your DIY to let us look look when done leh.... [:p]
See how first, if fei loh then I'll keep quiet. If it works, I will share with my MCF brudders.
Actually, anyone can DIY this lah, no big deal.
1.) Calculate impedance of each fan using input voltage = 12V and input current = 0.12A
Impedance is taken to be approximately the resistance of the fan
Thus R =V/I = 12V/0.12A = 100 ohm
2.) Total impedance/resistance of the 10 fans
Since fans are in series, we have to utilise the parallel addition rule.
1/(total resistance) = 1/(resistance of fan 1) + 1/(resistance of fan 2) + ... + 1/(resistance of fan 10)
Taking reciprocal, total resistance = 10 ohm
3.) Current flowing in parallel circuit (with all the fans connected)
Current I = V/R
I=1.2 Ampere
4.) Stamina of electrical setup
Time = Amperage hour / (current drawn)
= 7.2Ah/ 1.2A
= 6 hours
5.) We cannot assume that heat generation i.e. wastage is minimal thus you should expect the stamina time to be below 6 hours.
