Kangadrool Supersonic August 28, 2016 Share August 28, 2016 Most of the chemicals used will cause the wiper rubber blades to harden prematurely causing more noise. Plain water no lubrication and doesn't clear away dirt, especially when sometimes got some white specks stuck to the windscreen. With washer fluid, one spray and wipers stop squeaking. Autobacs had offer so bought this to try, so far so good, cleans quite well. ↡ Advertisement Link to post Share on other sites More sharing options...
flashbang Turbocharged August 29, 2016 Share August 29, 2016 Most of the chemicals used will cause the wiper rubber blades to harden prematurely causing more noise.Normally how long can wiper use for? Link to post Share on other sites More sharing options...
inlinesix Hypersonic August 29, 2016 Share August 29, 2016 Most of the chemicals used will cause the wiper rubber blades to harden prematurely causing more noise. No diff from heat generated by windscreen. I replace my wiper every year. Link to post Share on other sites More sharing options...
Kurty Supercharged November 16, 2018 Share November 16, 2018 like to ask, is it ok to pour car shampoo into wiper reservoir as wiper fluid? Link to post Share on other sites More sharing options...
Genghiskt 2nd Gear November 16, 2018 Share November 16, 2018 Use this Pm me for contact. Link to post Share on other sites More sharing options...
Beregond Supersonic November 16, 2018 Share November 16, 2018 like to ask, is it ok to pour car shampoo into wiper reservoir as wiper fluid? can la. i use washing liquid for washing plates Link to post Share on other sites More sharing options...
Joelwong 2nd Gear November 16, 2018 Share November 16, 2018 Paranoid until like that meh....I see some using distilled water Link to post Share on other sites More sharing options...
Dafansu Turbocharged November 16, 2018 Share November 16, 2018 like to ask, is it ok to pour car shampoo into wiper reservoir as wiper fluid?Then will have a lot of bubbles right. Link to post Share on other sites More sharing options...
Kurty Supercharged November 16, 2018 Share November 16, 2018 Then will have a lot of bubbles right. yet to try out.. i have 2 bottles of car wash shampoo, thinking of re using as wiper fluid instead since i dont wash the car myself can la. i use washing liquid for washing plates ok, that's good. just like a Brother had mentioned, wont there be a lot of bubbles? Link to post Share on other sites More sharing options...
Beregond Supersonic November 16, 2018 Share November 16, 2018 yet to try out.. i have 2 bottles of car wash shampoo, thinking of re using as wiper fluid instead since i dont wash the car myself ok, that's good. just like a Brother had mentioned, wont there be a lot of bubbles? ya indeed have some bubble ontop of the tank. just over flow drain off , nvm 1. still want to spend 20 buks for washer fluid meh?? Link to post Share on other sites More sharing options...
Drumy Neutral Newbie March 13, 2019 Share March 13, 2019 I drove a Toyota Hylux for 2 years in the Middle East. Always used water. Despite all the sandstorms, no problem at all. In fact Toyota recommended water for regions without freezing temperature. Link to post Share on other sites More sharing options...
Dafansu Turbocharged March 13, 2019 Share March 13, 2019 I drove a Toyota Hylux for 2 years in the Middle East. Always used water. Despite all the sandstorms, no problem at all. In fact Toyota recommended water for regions without freezing temperature. I've been using water for past 13 years also. ↡ Advertisement Link to post Share on other sites More sharing options...
2 lanes turn right to 3 lanes - which lane to go?
Which brand of honey to buy?
Which airline is the best?
