Liquidh 1st Gear September 12, 2010 Share September 12, 2010 Hi, was wondering what type of plugs i should get for performance on 1NZ-FE engines. Was wondering if anyone tried "Energizers" on your spark plugs and if it really works? ↡ Advertisement Link to post Share on other sites More sharing options...
Mobile1 1st Gear September 12, 2010 Share September 12, 2010 I suppose they use 1K16 plugs... anyway.. 1NZFE not meant to perform.. keke :D Link to post Share on other sites More sharing options...
Keithchue 5th Gear September 12, 2010 Share September 12, 2010 a good oil and regular service will put the engine in good working condition Link to post Share on other sites More sharing options...
Kungfu Clutched September 12, 2010 Share September 12, 2010 1NZFE engine.......shld be Vios/Sienta.........these engine does not require very much attention. Regular oil chge and servicing will do. If yr air filter those after mkt.......remove once a while to wash/blow dry will do. Dun have to chge plugs that often......Denso iridium usually the stock type........can last quite long. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear September 12, 2010 Share September 12, 2010 On 9/12/2010 at 3:29 AM, Liquidh said: Hi, was wondering what type of plugs i should get for performance on 1NZ-FE engines. Was wondering if anyone tried "Energizers" on your spark plugs and if it really works? No harm to check with the AD office If the engine is in order, it is the driver that performs Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear September 12, 2010 Share September 12, 2010 On 9/12/2010 at 5:44 AM, Keithchue said: a good oil and regular service will put the engine in good working condition Those really helpful on FC Link to post Share on other sites More sharing options...
5936 1st Gear September 12, 2010 Share September 12, 2010 Stock iridum plugs can last 100K. I have used for 85K. ↡ Advertisement Link to post Share on other sites More sharing options...
Music Concerts
Music Concerts
Changing of Spark Plugs
Tool to change Spark Plug
2023 Mercedes-AMG C63 S E Performance
