Cloudywind Neutral Newbie August 31, 2010 Share August 31, 2010 hi bros, i'm looking for some tips from the regular autoglym users... I just started on the resin and gloss protection. It seems like I need to use quite a generous application of those resin and gloss protection. Is that the same for you too? Appreciate any helpful tips on these products. Cheers. just use abit will do. i'm using those cheapo wireless polisher, and i'll just use abt a 20c coin size portion for each panel. if u apply thinly, the srp is easy to buff off not sure abt the extra gloss though, nvr try bef ↡ Advertisement Link to post Share on other sites More sharing options...
GemLeo 1st Gear August 31, 2010 Share August 31, 2010 just use abit will do. i'm using those cheapo wireless polisher, and i'll just use abt a 20c coin size portion for each panel. if u apply thinly, the srp is easy to buff off not sure abt the extra gloss though, nvr try bef wah bro.. 20c coin per panel... think i go find a polisher.... you mean like the electric buffer kind of thingy... I use like 50c per rub.... I'll go circular.. swirl around a portion... then left right left right... no wonder so siong.. LOL... I saw the demo in youtube mah.... guess it's just a way to make us finish their products faster... Link to post Share on other sites More sharing options...
Booboon 1st Gear August 31, 2010 Share August 31, 2010 hi bro, do you mean you apply thin layer of both the resin and gloss protection? the resin is like a paste.. while the gloss protection is liquid... seems to evaporate or soak into my towel before I can apply properly... hmmm.. think I try doing it again... Thanks bro. U can get meguire foam applicator. I use it for my polishing n application of wax. Got a few last yr as ntuc having sales. Link to post Share on other sites More sharing options...
GemLeo 1st Gear August 31, 2010 Share August 31, 2010 ok bro.. you means that's what you use for applying SRP? alrighty.. will go check it out.. thanks! Link to post Share on other sites More sharing options...
Psdcrdsc Neutral Newbie September 19, 2010 Share September 19, 2010 guys, for those of you doing AG sealant, can you advise the steps and materials used? i would like to attempt DIY using AG sealant (is it SRP?) eg. 1. wash car 2. using turtle pad, apply SRP 1st? 3. do one panel at a time, leave SPR on for 5 min and wipe straight.... ..... TIA! Link to post Share on other sites More sharing options...
Maddriver 4th Gear September 20, 2010 Share September 20, 2010 guys, for those of you doing AG sealant, can you advise the steps and materials used? i would like to attempt DIY using AG sealant (is it SRP?) eg. 1. wash car 2. using turtle pad, apply SRP 1st? 3. do one panel at a time, leave SPR on for 5 min and wipe straight.... ..... TIA! 1. wash 2. wipe dry 3. apply srp 4. wipe off once haze 5. apply EGP 6. wipe off once haze Hope the above help Link to post Share on other sites More sharing options...
Firestorm_33 Neutral Newbie September 20, 2010 Share September 20, 2010 guys, for those of you doing AG sealant, can you advise the steps and materials used? i would like to attempt DIY using AG sealant (is it SRP?) eg. 1. wash car 2. using turtle pad, apply SRP 1st? 3. do one panel at a time, leave SPR on for 5 min and wipe straight.... ..... TIA! hmmm, i used to do the following steps... 1. wash with shampoo and clay 2. apply srp on whole car..... then remove....cos by the time u apply and polish whole car, the SRP dry liao.... 3. apply sealant and let it settle for about 30-45 min... 4. wipe off..... SRP is to remove all dirt while sealant is to protect the paintwork..... Link to post Share on other sites More sharing options...
Psdcrdsc Neutral Newbie September 20, 2010 Share September 20, 2010 thanks guys! Link to post Share on other sites More sharing options...
Darkblue 1st Gear September 20, 2010 Share September 20, 2010 SRP alot of dust leh... wah get inside the minor gaps, between window rubbers not nice. Might as well use sealant DG 101 or 501. Link to post Share on other sites More sharing options...
Vtec78 Neutral Newbie October 25, 2010 Share October 25, 2010 the trick is apply juz a thin amount, let it set for few min, wipe off. if u are getting powdery when wiping off, it means u apply too much. this is the same as spray painting. many thin layers will have better result than 1 thick layer. if wiping off is abit diff, try using QD. but if u apply a thin layer, it will come off easily. Link to post Share on other sites More sharing options...
Zenith_Mazda Clutched December 21, 2010 Share December 21, 2010 some how srp doesnt last long before its effect is gone leh..contemplating other products..maybe DG Link to post Share on other sites More sharing options...
Booboon 1st Gear December 21, 2010 Share December 21, 2010 Abt a month in local weather. Usually I will top up 476 after a polish. This can stretch to 8 to 10 weeks. In dec raining season, srp w no top up last abt 2 weeks max. Link to post Share on other sites More sharing options...
DingDang Neutral Newbie December 21, 2010 Share December 21, 2010 just use abit will do. i'm using those cheapo wireless polisher, and i'll just use abt a 20c coin size portion for each panel. if u apply thinly, the srp is easy to buff off not sure abt the extra gloss though, nvr try bef Hi Bro, Can share where u get e wireless polisher and how much? Thanx! Link to post Share on other sites More sharing options...
Mlee 1st Gear December 21, 2010 Share December 21, 2010 some how srp doesnt last long before its effect is gone leh..contemplating other products..maybe DG Poliseal also . Link to post Share on other sites More sharing options...
Mksoo Clutched December 22, 2010 Share December 22, 2010 Hi, used it last week .... first time polishing but i think it's good ... finish with seal protection. will check NTUC-TP .. thanks mk Link to post Share on other sites More sharing options...
Nzy Twincharged December 22, 2010 Share December 22, 2010 some how srp doesnt last long before its effect is gone leh..contemplating other products..maybe DG For me srp last about a week but if apply egp after srp can last around 2 months. Link to post Share on other sites More sharing options...
Jefferyl Neutral Newbie January 17, 2011 Share January 17, 2011 I always liked SRP since it is much easier to apply and buff off but the downside is that it doesn't last very long. At most 1-1.5 weeks? function wise, it is really good. My car looks really shiny after using it Link to post Share on other sites More sharing options...
Psdcrdsc Neutral Newbie January 22, 2011 Share January 22, 2011 whats the best cloth/applicator material for EGP? TIA! ↡ Advertisement Link to post Share on other sites More sharing options...
New Age Polish --> Volkswagen Portfolio
New Age Polish --> Mazda Portfolio
New Age Polish --> Lexus Portfolio
New Age Polish --> Hyundai Portfolio
New Age Polish --> Nissan Portfolio
WORKMANSHIP-->Paintwork Restoration & Correction (PORTFOLIO)
How will you refresh the paintwork on your car
