Ken4555 1st Gear August 21, 2010 Share August 21, 2010 i've been wanting to ask this for a very long time liao keep forgetting... from my knowledge, wheel spacers are mainly to clear bigger calipers... those who are using it, any wheel vibrations at high speeds? SOME... only some cars look good with wheel spaces... i always believe a wider wheel base will make the car look better... but if your car is not designed to fit wider wheel base than the car will end up yucks... i am probably not making myself very clear... .... hmmm ok example... i feel lah... wheels to far out for these cars look yucks... 1st gen Mazda3, Estima, Avante.... its like there's no swallon wheel arc and the design of the car fenders just look bad with wheels out of the body... anyways just wanna know if you are using wheel spacers and WHY?... many thanks... ↡ Advertisement Link to post Share on other sites More sharing options...
Lectrosphere 1st Gear August 21, 2010 Share August 21, 2010 hi bro im using H&R wheel spacer with hub centric so i won't damage my axle. wheel vibration havent encounter any so far yet... prolly cause i don't drive fast... but with the wider wheel track.. taking the bends feel more sturdy... Link to post Share on other sites More sharing options...
Ken4555 1st Gear August 21, 2010 Author Share August 21, 2010 hi bro im using H&R wheel spacer with hub centric so i won't damage my axle. wheel vibration havent encounter any so far yet... prolly cause i don't drive fast... but with the wider wheel track.. taking the bends feel more sturdy... thanks for your response bro... actually i'm asking this cause i feel like putting wheel spacers on my rears... but i'm an FF car... doing so might kill my car's balance... have you heard of ppl only doing front or rear only? dub perhaps but just wanna know... and your wheel spacer how thick ah? got size one i remember seeing... and you lowered? got bars? or did nothing except spacers?? thanks Link to post Share on other sites More sharing options...
Readonly Neutral Newbie August 21, 2010 Share August 21, 2010 thanks for your response bro... actually i'm asking this cause i feel like putting wheel spacers on my rears... but i'm an FF car... doing so might kill my car's balance... have you heard of ppl only doing front or rear only? dub perhaps but just wanna know... and your wheel spacer how thick ah? got size one i remember seeing... and you lowered? got bars? or did nothing except spacers?? thanks for wheel spacers dont get those universal type. customize a set. leong seng at paya ubi does a great job of it. they will measure with a ruler and a string, then you will get the exact thickness that you require. if your bolts arent long enough they will make those spacers for you that comes with the bolts. i only did it for my rear because i had a pair of customised wide fenders on the rear. no issues with balancing as well. Link to post Share on other sites More sharing options...
Ken4555 1st Gear August 21, 2010 Author Share August 21, 2010 for wheel spacers dont get those universal type. customize a set. leong seng at paya ubi does a great job of it. they will measure with a ruler and a string, then you will get the exact thickness that you require. if your bolts arent long enough they will make those spacers for you that comes with the bolts. i only did it for my rear because i had a pair of customised wide fenders on the rear. no issues with balancing as well. hi bro, is your car rear wheel drive or front wheel drive? thanks.. and Leong Seng is which blk which floor ah? thanks... Link to post Share on other sites More sharing options...
Timphee Neutral Newbie August 21, 2010 Share August 21, 2010 Hi TS, from you avatar i guess your are driving a Nissan sunny? Im driving one as well. My view is get customize ones which would be stable at high speeds. Im on 15mm spacers with extended bolts to clear BBK and to make it flush with the fenders and intending to put 10mm ones for the rear which i already have but yet to find longer bolts. So far no vibrations at all during high speeds. For FF cars, front track should be wider than the back for better traction in corners imo. Link to post Share on other sites More sharing options...
Rb26dett Clutched August 21, 2010 Share August 21, 2010 if budget is a concern , hub centric spacers with long bolts if spacer thickness is more than 8mm. but of course it is always better to get proper offset rims rather than using spacers. Link to post Share on other sites More sharing options...
Rb26dett Clutched August 21, 2010 Share August 21, 2010 hi bro, is your car rear wheel drive or front wheel drive? thanks.. and Leong Seng is which blk which floor ah? thanks... along the stretch in paya ubi . go in from the right side entrance .its just one or two units away on your left. Link to post Share on other sites More sharing options...
Ken4555 1st Gear August 22, 2010 Author Share August 22, 2010 Hi TS, from you avatar i guess your are driving a Nissan sunny? Im driving one as well. My view is get customize ones which would be stable at high speeds. Im on 15mm spacers with extended bolts to clear BBK and to make it flush with the fenders and intending to put 10mm ones for the rear which i already have but yet to find longer bolts. So far no vibrations at all during high speeds. For FF cars, front track should be wider than the back for better traction in corners imo. sunny with BBK.... rare find nowadays... keke... well you're right... cause i'm asking to see if i can put spacers on my rear... but i dnt want it to handle with too much difference... my front is so close to the fenders its already hitting when i get deep bumps once in a while... by the way i'm oversized on 205/16/55.... think i should have gotten 50s... arghhhh Link to post Share on other sites More sharing options...
Ken4555 1st Gear August 22, 2010 Author Share August 22, 2010 thanks bro... only 2 blks there will find it... Link to post Share on other sites More sharing options...
Thedream 3rd Gear August 22, 2010 Share August 22, 2010 thanks for your response bro... actually i'm asking this cause i feel like putting wheel spacers on my rears... but i'm an FF car... doing so might kill my car's balance... have you heard of ppl only doing front or rear only? dub perhaps but just wanna know... and your wheel spacer how thick ah? got size one i remember seeing... and you lowered? got bars? or did nothing except spacers?? thanks Bro, I don't think this is a good idea. Your FF car is probably biased for understeer right now. Making your rear further out will make the rear more reluctant to turn out, increasing your understeer even further. I guess you feel the rear doesn't look very nice. But much better to maintain the handling than go for looks but making your car more "dangerous." Some of the advice given by the other bros was good. Ideally go for rums with the required offset rather than use spacers. But if still going for spacers, customise them with hub centric rings (prevents vibrations) rather than use universal ones. Also, anything more than 5mm and you should probably need to change to long bolts, otherwise your nuts will not be able to latch on to enough thread. Link to post Share on other sites More sharing options...
Marcng Neutral Newbie August 22, 2010 Share August 22, 2010 if budget is a concern , hub centric spacers with long bolts if spacer thickness is more than 8mm. but of course it is always better to get proper offset rims rather than using spacers. hi bro,roughly how much its cost for a 5mm hub centric spacer? Link to post Share on other sites More sharing options...
Mustank Hypersonic August 22, 2010 Share August 22, 2010 i am also thinking for fixing spacers but i am concerned about safety.....will it compromise safety? Link to post Share on other sites More sharing options...
Lectrosphere 1st Gear August 22, 2010 Share August 22, 2010 i am also thinking for fixing spacers but i am concerned about safety.....will it compromise safety? whats your concern bro? im using 20mm H&R spacer now Link to post Share on other sites More sharing options...
Lectrosphere 1st Gear August 22, 2010 Share August 22, 2010 (edited) thanks for your response bro... actually i'm asking this cause i feel like putting wheel spacers on my rears... but i'm an FF car... doing so might kill my car's balance... have you heard of ppl only doing front or rear only? dub perhaps but just wanna know... and your wheel spacer how thick ah? got size one i remember seeing... and you lowered? got bars? or did nothing except spacers?? thanks mine is 20mm... nv lower... my ride quite high so i widen the wheel track... improve overall stability ... only time will vibrate very hard is when my air pressure too high... other den that np! Edited August 22, 2010 by Lectrosphere Link to post Share on other sites More sharing options...
Ken4555 1st Gear August 22, 2010 Author Share August 22, 2010 (edited) after some consideration... will leave my car as it is... thanks for your advice btw... Edited August 22, 2010 by Ken4555 Link to post Share on other sites More sharing options...
Mustank Hypersonic August 23, 2010 Share August 23, 2010 i scared wheel drop out i know it is just my irrational fears Link to post Share on other sites More sharing options...
Mini-itx Clutched August 23, 2010 Share August 23, 2010 I do use spacers on my Celica because my wheels are of the wrong offset. It a set of custom made spacers. From what I have heard, spacers will damage your wheel bearings. I have already replaced 1 rear wheel bearings. Don't know if its because its due to spacers or because I kana kerb. ↡ Advertisement Link to post Share on other sites More sharing options...
How are you using the SkillsFuture?
Wheel bolts and Wheel spacer
Wheel Spacer Installation DIY
Wheel Spacer, where to buy?
Using blower to dry car
Wheel Hubs
Wheel Hubs
CPU chip - What are you using? Intel or AMD?
