How to read this tyre pressure label?
Jj5599
post-1798-0-22142600-1537917439_thumb.jp
I think we are at missing something here .... :huh:
Their "cold" refer to Winter temperature in countries with 4 seasons and Summer temperature could hit 39 ~ 40 .
In SG, everyday the same temperature 24 ~ 34, just pump to your preferred driving style and comfort.
Some like steering light so as not to tire your arms, then pump 260 ~ 320. (risk of skidding on wet roads if pump 280 ~ 320)
Some like steering heavy so that more grip on the road, then pump 180 ~ 220
By asking here for opinion will instead confuse yourself.
Air pressure also depend on your current set of tyres width, height and Rim sizes. Example like 175/60/R15, 185/60/R16 and so on till .... 235/40/R20
So, to each his own comfort level of driving. No harsh and fast rules governing tyre pressure driving in Singapore where max speed limit restricted to 90Km/h ...... [wave]
But if you are driving up North to MY, there are different set of rules on tyre pressure & size to follows for that long journey up and also for your safety as average speed of some drivers around 110 km/h to 180 km/h... [sly]
I myself pump 250 in SG driving and when going in to MY, I will reduce the tyres pressure to 210 on 215/50/R17. [drivingcar]
Practice SAFE DRIVING always. -_-
Bro, cold in Tyre pressure context refers to cars which have been parked overnight and then not been driven for more than 1.6km before pumping.
Best is to follow the label on the car.
Let say u change to PS4. The load index will increase to 92.
Accordingly, u need to reduce pressure to 230 while maintaining load capacity at 515kg.
If you upgrade size say from 16 to 17, do you still follow the recommended tire pressure or you will up??
  On 9/24/2018 at 4:02 PM, Vratenza said:
If your car comes with TPMS (those w individual pressure read outs), can observe the pressure changes from when you just pumped after a long drive and the next morning after starting the car and just driven for a few hundred metres. The difference can be as much as 20-30kpa.
So I usually compensate by pumping about 20kpa more than the recommended pressure when I pump at the kiosk after a long drive....ie hot tires.
Agree.... if pump base on recommendation, next morning become under already... so usually will up 20 to 30 more...
  On 9/22/2018 at 1:56 AM, Stevetp1 said:
Hi all, just got my pre-owned Odyssey 2015. Is it ok to pump 270-280kpa on stock tyre since the ride is heavy.
The recommended pressure on the side door seems to be on the Low side.
Thanks in advance.
Steve
too much.. i also have ody.. 240 good enough..
What’s stock tyre load index and pressure? Look at the sticker.
What’s new tyre load index?
Alot of times people also forget about individual tire brand/model differences in the stiffness of the sidewall....even more so when comparing  RFT to non-RFT.
my original were 19"  RFT, when I upsided to 20" non-RFT (staggered rims), I tried sticking to the former pressure of 250kPa (hot), but find that although my acceleration is more urgent because overall lighter wheels setup, it is a little squirmish and slight increase in lateral roll on hard cornering.
So, I did a little playing around with the pressure and finally settled on 260kPa front and 280kPa rear. That sorted out the cornering issues. With the larger but lighter wheels set, the ride is much more comfortable at low speed especially over humps and imperfect road surfaces (despite running at higher pressure than before)
My point being, the manufacturer tire pressure label is only useful as a guide if you are running the stock factory setup. Once you change the tire brand, model, size...everything needs to be adjusted according to how you want your car to behave. Not all drivers are sensitive to how tire pressure affects the handling of their cars, so following the label is a failsafe method but not the only method.
Doc, tyre is load bearing.
What’s stock and new tyre load index? I can tell you what’s the minimum pressure to pump.
My previous PSS and current PS4 has same load index of 92.
But PSS sidewall is as stiff as RFT.
Stock 19" RFT is this : 235/55R19 101V
The new tires I go check and let you know later.
Thanks..... but sibei chim....  [laugh]  [confused]
  On 9/26/2018 at 6:08 AM, Vratenza said:
Let me say first....nitrogen is snake oil in normal road application. [grin]
It works for me (normal road application)  but with detrimental effect.  [laugh]
Had been using Nitrogen for the last 5 years [rolleyes]
Confirm same as normal air leakage [idea]
100% no difference except I paid for Nitrogen package  [lipsrsealed]
IIRC,  when I opted for nitrogen during tyres change,  my leakage was much lesser vs normal air.
The fact that my leakage was all so often,  after a while, my tyres would be mostly nitrogen.
While the benefit is that I pump less often, I have to pay more attention to cold tyre pressure.
  On 9/25/2018 at 3:46 PM, Vratenza said:
is your car front wheel drive?
the recommended front pressure seem to be higher than the rear.
Yap. Mine fwd
  On 9/25/2018 at 3:14 PM, Davidtch said:
Load index: 93.
At 230, load capacity per tyre is 540kg with total capacity of 2.16 tonne.
Still not enough?
240~250 within my comfy range for my current rides, 260 a bit too hard for me liao.
