How to read this tyre pressure label?
Jj5599
Hi, can anyone please help me with how much pressure to pump for my front and for my rear tyres? I can't understand the typre pressure label in the photo. thanks!
Edited by Jj5599
  • Praise 2
[thumbsup] Lots of figures, but not too difficult.
1) Look for your tyre size
2) Decide on load 4 pax or full load with lagguages
3) Cross check column on pressures for front and rear tyres.
From my experience, the normal 4 pax us good enough for every day use.
I like this type of chart.
I had one that's even more headache-- 3 levels of press. :wacko:
2 front pax.
4 Pax
4 Pax & lagguages.
MIC & MIK cars same press from all tyres.
  • Praise 2
If the nos 5 passenger is someone you dun like, you can explain that the tire pressure chart allow only 4 pax maximum, please call a cab yourself. :D
  • Praise 3
4 passengers. Tyre size I don't know, should be default.
You should read yr tyre size off your default tyre then let us know. Then we can help you on the correct pressure to pump.
When is getting a nail/screw poked into the tyre considered too often?
Yesterday I had the 2nd in 6months ( too often ). As the tyres were already 3 years old, had them changed and had 2 surprises:
- the tyre shop pump to 140KPa(34PSI) while I had been only letting in 215KPa(31PSI).
- the mechanic checked the front tyres and found one with 300KPa ( wow, how did this happen when I usually select 215 at the air pump )
tyre size is 195/65/R15
  • Praise 2
Supersonic
Could be a leaky valve stem.
Or tyre guy anyhow pump. Seem to hv this issue everytime they helpfully "check" & rotate my tyres. Always end up having to recalibrate the pressures myself after that.
  • Praise 2
