Sp33dst3r Neutral Newbie July 26, 2010 Share July 26, 2010 Is Amsoil engine oil really so good? ↡ Advertisement Link to post Share on other sites More sharing options...
Mini-itx Clutched July 27, 2010 Share July 27, 2010 Read my thread about the Motul oil Unless you track, Amsoil is all you need. Link to post Share on other sites More sharing options...
BblocK Neutral Newbie July 28, 2010 Share July 28, 2010 Dun noe....but I'm using Lucas oil..changed from OWS NA racing oil. No comparison btween the two, Lucas oil simply beats it hands down! Link to post Share on other sites More sharing options...
Mits_jc 5th Gear July 28, 2010 Share July 28, 2010 Try it for ur own car, I've been using SSO 0w30, doing yearly/20k EO change instead of the typical 6mth/10k EO change. So far so good..good mileage too. Is Amsoil engine oil really so good? Link to post Share on other sites More sharing options...
Sp33dst3r Neutral Newbie August 11, 2010 Author Share August 11, 2010 (edited) Read my thread about the Motul oil Unless you track, Amsoil is all you need. where to buy? price? Edited August 11, 2010 by Sp33dst3r Link to post Share on other sites More sharing options...
Kelpie 2nd Gear August 11, 2010 Share August 11, 2010 Is Amsoil engine oil really so good? To me, want to get Amsoil must use the Signature series. To me Amosil is an alternative to Redline. Regards, Link to post Share on other sites More sharing options...
SUVperb Clutched July 7, 2011 Share July 7, 2011 Try it for ur own car, I've been using SSO 0w30, doing yearly/20k EO change instead of the typical 6mth/10k EO change. So far so good..good mileage too. Bro don mind me ask,EO chg every 20K but how abt ur oil filter? Link to post Share on other sites More sharing options...
Darkblue 1st Gear July 7, 2011 Share July 7, 2011 Bro don mind me ask,EO chg every 20K but how abt ur oil filter? EO change 20K, but oil filter swap @ 10K. Based on email from Amsoil USA. Link to post Share on other sites More sharing options...
Amsoil_ACEONG Neutral Newbie July 25, 2011 Share July 25, 2011 Actually you can use your oil filter throughout the entire stretch. For those of you doing oil change with AMSOIL, remember to select the right oil filter as per OEM to your car. Try not to go for some cheap oil Link to post Share on other sites More sharing options...
Amsoil_ACEONG Neutral Newbie July 25, 2011 Share July 25, 2011 Actually you can use your oil filter throughout the entire stretch. For those of you doing oil change with AMSOIL, remember to select the right oil filter as per OEM to your car. Try not to go for some cheap oil filter. There has been some speculation in the market as to the extended drain interval. Trust me, if you are using your car in Singapore traffic condition, my advice to you is to drain at maximum 16,000km. We have actually done a test in Singapore with our current traffic condition on a Toyota Altis, OEM oil filter. The oil losses its additive compound at 17k odd. regards, ~ Ace Ong AMSOIL lubricant specialist. Excl distributor, AMSOIL Singapore. visit us @ triple "w" dot amsoil dot com dot sg ↡ Advertisement Link to post Share on other sites More sharing options...
