Wt_know Supersonic July 14, 2010 Share July 14, 2010 hi, where can i buy this CRC DISC BRAKE QUIET ? autobacs ? is there other brand of disc brake quiet that you would recommend ? thanks ! ↡ Advertisement Link to post Share on other sites More sharing options...
Mockngbrd Supersonic July 14, 2010 Share July 14, 2010 can't imagine this being good.. but thats just me Link to post Share on other sites More sharing options...
Caravan 5th Gear July 14, 2010 Share July 14, 2010 Normally got noise meh? If there is noise it's to signify the brake pads need to be replaced. Why you want to silence it? Link to post Share on other sites More sharing options...
Tom_kkh 1st Gear July 14, 2010 Share July 14, 2010 Normally got noise meh? If there is noise it's to signify the brake pads need to be replaced. Why you want to silence it? if u change good brakes, it will get noisy when near "flat" If u change lousy brakes, it will get noisy starting the following week after installation. Not saying TS buy lousy brakes, maybe he don know, kana cheated by workshop. just sharing info. I got lousy brakes b4 too, not worth, too noisy and embarrassing every time u brakes. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged July 14, 2010 Share July 14, 2010 if u change good brakes, it will get noisy when near "flat" If u change lousy brakes, it will get noisy starting the following week after installation. .... Maybe TS has good sports brake? Link to post Share on other sites More sharing options...
Silver_blade Turbocharged July 14, 2010 Share July 14, 2010 TS, I wouldn't try such products at all. I will just replace the brake pad to one which is of softer compound. Link to post Share on other sites More sharing options...
Accord Clutched July 14, 2010 Share July 14, 2010 I bought performance brake pad, too noisy...till fedup. going to change back to original or oem type. Link to post Share on other sites More sharing options...
Ah_Lau 1st Gear July 14, 2010 Share July 14, 2010 hi, where can i buy this CRC DISC BRAKE QUIET ? autobacs ? is there other brand of disc brake quiet that you would recommend ? thanks ! Here is a list of companies that handle CRC: http://www.thegreenbook.com/BrandName.aspx?BrandName=crc I bought CRC Brakleen from Kaizen Marketing & Trading before. Link to post Share on other sites More sharing options...
Wt_know Supersonic July 14, 2010 Author Share July 14, 2010 (edited) my aftermarket performance brake pads squels and squeks in order to make it quiet is to apply disc brake quiet lube / spray the creaking sound is due to the movement of the clip with caliper. it's a common problem with aftermarket performance brake pads replacing oem brake pads Edited July 14, 2010 by Wt_know Link to post Share on other sites More sharing options...
Wt_know Supersonic July 14, 2010 Author Share July 14, 2010 (edited) thanks !!! if too troublesome, i will just order from amazon USD$4.50 with vpost usa Here is a list of companies that handle CRC: http://www.thegreenbook.com/BrandName.aspx?BrandName=crc I bought CRC Brakleen from Kaizen Marketing & Trading before. Edited July 14, 2010 by Wt_know Link to post Share on other sites More sharing options...
Ah_Lau 1st Gear July 14, 2010 Share July 14, 2010 thanks !!! if too troublesome, i will just order from amazon USD$4.50 with vpost usa You are welcome. Please do add value to this forum by updating whether you can get this item here. I'm away so can't investigate further. I was researching this product and saw it on Amazon also. Definitely can order but vPost may have shipping restrictions on such packages. My brake squeal problem is only at walking speeds and cannot be heard when the windows are up. My car is too quiet and the brake squeal is actually a good thing because it serves as a pedestrian repellent when on small lanes off Serangoon Road and other places where certain people think that they are entitled to just anyhow walk on the road. Link to post Share on other sites More sharing options...
Wt_know Supersonic July 14, 2010 Author Share July 14, 2010 (edited) i hate the brake creaking sound. it makes my car sounds like a 10 years old proton. the creaking sound is only heard when i tap on the brake at slow speed (car park, approaching hump, morning traffic, etc) -> very irritating. Edited July 14, 2010 by Wt_know Link to post Share on other sites More sharing options...
Kb27 Supersonic July 14, 2010 Share July 14, 2010 The high frequency sound can be reduced. I use anti-seize grease on the back of the pads. Should be available at local hardware shops. Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 14, 2010 Share July 14, 2010 Us only high temp silicon grease, normal great will not work Link to post Share on other sites More sharing options...
Kb27 Supersonic July 14, 2010 Share July 14, 2010 Yeah, I use Permatex high temp anti-seize grease. http://www.permatex.com/products/Automotive/lubricants/specialty_lubricants/Permatex_Anti-Seize_Lubricant_a.htm Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 14, 2010 Share July 14, 2010 hi, where can i buy this CRC DISC BRAKE QUIET ? autobacs ? is there other brand of disc brake quiet that you would recommend ? thanks ! =========== No need to buy this special stuff. If your disc brakes squeel, it was cos your mech did not apply some high temp copper grease to the shims when he changed the brakes. I always remind my mech to apply the grease & I never had any problems with noisy brakes. Link to post Share on other sites More sharing options...
Yuan 6th Gear July 17, 2010 Share July 17, 2010 my aftermarket performance brake pads squels and squeks in order to make it quiet is to apply disc brake quiet lube / spray the creaking sound is due to the movement of the clip with caliper. it's a common problem with aftermarket performance brake pads replacing oem brake pads Not necessary that aftermarket brake pads will produce squeaking sound. There are only certain types of brake pads that has metallic composition and such pads may result in the sound when driver brakes the car. Advisable to go to a mechanic and check your brakes. In my opinion, no need to use the above product. Link to post Share on other sites More sharing options...
Wt_know Supersonic July 17, 2010 Author Share July 17, 2010 the creaking sound comes from the movement of the brake pad that secured to the caliper thru a clip. there is a tiny bit gap between the clip and the caliper. need to apply such brake grease to lubricate the touch point ↡ Advertisement Link to post Share on other sites More sharing options...
Change Disc Rotors
Change Disc Rotors
Markets and Hawker Centre Chat - It's Really Quiet?
Brake Pads
Brake Pads
Extending quiet time by 1½ hours among recommendations to tackle neighbourhood noise in Singapore
Brake squeak every morning
