In car vehicle recorder
Tom_kkh
Minor road must give way to major road.
That is one idiot driver n nearly cause a collision with you.
Red plate mah. but really an idiot, confirm see you coming still come out, come out liao nvm, still drive so slow.
the civic also, want to cut in dont know to cut in anot. i hate drivers who signal and cannot make up their mind whether to change lane.
I am having 2 problems with GSE580.
Firstly, HP viewer will not run on Windows 7. Identical software runs fine on Vista.
Secondly, once the engine is shut off, at times I lose the file currently being recorded. Defeats a lot of the purpose of having the thing.
Any help would be appreciated.
So far I have never encounted this problem with my GSE580.
Does the circular icon appear at the centre of the screen when u shut off ur engine??? Mine does everytime. It is saving the file before shutting down.
Hi Vega,
You can try to rename the file back in this format AMBAXXXX.MOV.
XXXX should be a number example 0105 etc...
Hopefully you can play the video from the GSE580 itself.
Cheers
Tried rename it back to the camera naming convention but still can't read. I think once you rename it, the camera can't read the file anymore.
Hi Bro,
1st) May i know whether you bought the GSE580 from me? Or someone else?
Like i said earlier to everyone here, i am here to help on any GSE580 related issue but my customer will be top priority.
2nd) Please confirm whether is HP or HD player. If HD player, where do you get it? Are you able to playback using VLC player?
3rd) What problem do you encounter on the HD Player? Can briefly describe? Any error or pop up?
4th) As you mentioned, the unit will not save any video after you shutdown your engine. Before you shutdown the engine can you see the red circle flickering on the LCD, also what is the setting for USB OUT? DURATION?
Please reply the above questions, i am most willing to provide you support.
Cheers
Renaming a file is not just as simple as name change...the attributes changes as a diff sys was used to change the name. The native player in 580 will not play.
Hi Vega,
Let me try on my unit & get back to you.
Please correct me if i am wrong, Basically, it is a recorded video recorded by GSE580. Then you select CUT & PASTE on your PC & rename it ( retaining the video format & original video length). So after that even if you rename the format that i inform you & copy back to the same folder, the unit unable to detect/playback?
Cheers
Hi Adrianli,
Thanks for the queries. I managed to get DOD SDHC datasheet. Will post on my facebook for you all to see this weekend.
Cheers
U got the 32gb class 10?
Hi Vega,
Cheers
Yes you are correct.
Hi Adrianli,
Cheers
Bro if order when can get? It's micro sd or sd?
Latest Recommendation 2: DSX1412CH Latest Dual Camera! Front Lens 140 degree with 120 degree back lens / GPS Logger / G-Sensor!
Model: DSX1412CH
Price: Please sms me at 97572495 for special introductory price!
Main features:Ultra small volume; the front lens with ultra wide angle of 140 degrees can be rotated up and down 20 degrees; the back lens with ultra wide-angle of 120 degrees high resolution; this perfect modular design is more convenient for various angle and high resolution video shooting.
- Built-in 1/4 inch low-noise and high-quality photographic element can capture ultra clear picture in a dark place.
- Built-in lithium battery with charging and meanwhile recording function.
- Built-in microphone/speaker.
- Support high-capacity Micro TF Card
- Automotive turning on and recording function when the vehicle start.
- With a delayed start function to prevent transient pulse current damage machine at the moment the vehicle start.
- GPS scanning and positioning.
- Gravity induced SENSOR
LCD screen size 2.7" TFT LCD (16:9)
Lens Front lens with wide angle of 140 degrees;
Back lens with wide-angle of 120 degrees
language English, Russian, German, French, Spanish, Italian,
Portuguese, Traditional Chinese, Simplified Chinese, Japanese
Video format AVI
Video Resolution 1280 x 480 30FPS (2CH Record),
640 x 480 30FPS (1CH Record)
Audio Built-in microphone and Speaker.
Recording Media Support Micro SD Card up to 32GB
White balance Auto / sunny / cloudy / tungsten / fluorescent
TV System 50Hz/60Hz
Light frequency NTSC, PAL
Power Supply Built-in lithium polymer battery
5V 500MA
12V / 24V convert to 5V
Nutrition DC 12-24V
Working humidity 10% ~ 80%
Temperature -10 ~ 70
Guest
