Yattokame 4th Gear May 27, 2010 Share May 27, 2010 Hi all, Have a question on the above. Lawyer found that part of the land of the project is under "Road reserve". What are the implications of this? The valuation? Subsequent perceived value? Thanx ↡ Advertisement Link to post Share on other sites More sharing options...
Zuoom 1st Gear May 27, 2010 Share May 27, 2010 the banks would probably take that into consideration when doing their evaluation. ie: risk factor. as a result, might quote lower, or offer a lessor amount of quoted value. i would believe your land is near a main road or junction. Link to post Share on other sites More sharing options...
Joseph22 Turbocharged May 27, 2010 Share May 27, 2010 Hi all, Have a question on the above. Lawyer found that part of the land of the project is under "Road reserve". What are the implications of this? The valuation? Subsequent perceived value? Thanx I think meaning that the portion of the land are reserve for road extension in the future. might not be good for you in the long run. Link to post Share on other sites More sharing options...
Yogi 1st Gear May 30, 2010 Share May 30, 2010 It will also affect your set-back. Link to post Share on other sites More sharing options...
Soya Supersonic May 30, 2010 Share May 30, 2010 that's bad news. it means the property gotta surrender the land at any time to the gahmen if they hv road widening plans. if no widening, perceived value oredi factored in the fact that the property is facing some main road. if got widening, not perceived but actual value will prob drop. Link to post Share on other sites More sharing options...
Jordanplus 1st Gear May 30, 2010 Share May 30, 2010 that parcel land within the road reserve is belong to state land (SLA). your nett land area is lesser. The implication r valuation of property is lesser due to lesser total land area, buildable gross floor area is lesser against your nett land area with plot ratio. your boundary fancing have to build after your road reserve line and your project green buffer and building setback must base from road reserve line. Link to post Share on other sites More sharing options...
Yattokame 4th Gear May 30, 2010 Author Share May 30, 2010 (edited) Thanks for the reply. Edited June 5, 2010 by Yattokame Link to post Share on other sites More sharing options...
Soya Supersonic June 1, 2010 Share June 1, 2010 that's why we pay lawyers; to do the necessary due diligence. but ultimately, it's up to the buyer if they wish to proceed wif the transaction given the info presented before them. Link to post Share on other sites More sharing options...
Porker Turbocharged June 1, 2010 Share June 1, 2010 Hi all, Have a question on the above. Lawyer found that part of the land of the project is under "Road reserve". What are the implications of this? The valuation? Subsequent perceived value? Thanx Implications: 1) Part of the boundary will be set back for road widening in future. 2) Smaller land area But... 1) Gross floor area will still be meted to you with respect of the original area Valuation is based on location, shape and size of land. Road reserve affects majority of land parcels in Singapore. Its a given. Don't be so perturbed by it. Its a small thing. Hardly considered an issue. Link to post Share on other sites More sharing options...
Yattokame 4th Gear June 1, 2010 Author Share June 1, 2010 (edited) Thanx again Met up with lawyers and discovered the following 1) Road reserve could also mean they HAD already done something to it. Never update? 2) Most lawyers for condo sale skip this step; even valuers. wth. thanx :) edit: lawyer advised I reserve the right to rescind contract Edited June 5, 2010 by Yattokame ↡ Advertisement Link to post Share on other sites More sharing options...
Reckless Cyclist
Reckless Cyclist
Property in Johor
Property in Johor
Shop Houses Collapse at Syed Alwi Road
Properties info
Properties info
Road Trip To Thailand
