Yr1985 1st Gear May 25, 2010 Share May 25, 2010 The conversion cost like 1.4k and above, but I do not see many on the road, especially Honda Fit, Airwave or other rear drum cars. ↡ Advertisement Link to post Share on other sites More sharing options...
macrosszero Turbocharged May 25, 2010 Share May 25, 2010 The question is also whether you are prepared to risk your safety on a retrofitted brake kit. Link to post Share on other sites More sharing options...
Krado Clutched May 25, 2010 Share May 25, 2010 The conversion cost like 1.4k and above, but I do not see many on the road, especially Honda Fit, Airwave or other rear drum cars. Because in every day driving, full disc or front disc makes little difference... Link to post Share on other sites More sharing options...
Yr1985 1st Gear May 25, 2010 Author Share May 25, 2010 On contrary, it is suppose to be safe and makes a difference right? I wonder how does it communicate with the electronics like ABS etc... Link to post Share on other sites More sharing options...
Yuan 6th Gear May 25, 2010 Share May 25, 2010 On contrary, it is suppose to be safe and makes a difference right? I wonder how does it communicate with the electronics like ABS etc... Good to get a reliable workshop who had experience to your model. Link to post Share on other sites More sharing options...
macrosszero Turbocharged May 25, 2010 Share May 25, 2010 Your brake bias balance between the front and rear could be altered if the rear disc is more effective than your drum brakes were. It can cause your car to handle differently when you slam hard on the brakes. Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 25, 2010 Share May 25, 2010 chge to a rear disc brake set up, n u get urself a more powderful brake. ........it don work tat way, its not tat simple . like some bros said, there is tis brake bias thingy which plays a big prt. Get in wrong n u find urself spurning ard under hard braking Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear May 25, 2010 Share May 25, 2010 yes. very dangerous to change only one pair. just stay stock else do a proper biasing. if either pair is changed while the other pair is stock, one pair will brake faster than the other. what will happen next? better be safe than sorry. Link to post Share on other sites More sharing options...
Nf0rc3r 1st Gear May 25, 2010 Share May 25, 2010 Yah. No one knws the car better den the manufacturer, unless its a optional addon by the manufacturer many won't consider touch the brakes if its working well. Link to post Share on other sites More sharing options...
Davidcks 1st Gear May 25, 2010 Share May 25, 2010 Used to drive a Mz3 first generation, and that time got a rear disc conversion program. Think there was some issue on the drum brakes sticking I guess. Anyway, change already also cannot feel the differences.... Guess save the money better lah...... Link to post Share on other sites More sharing options...
Krado Clutched May 25, 2010 Share May 25, 2010 Yah. No one knws the car better den the manufacturer, unless its a optional addon by the manufacturer many won't consider touch the brakes if its working well. My car came with a "faster" version with full disc brakes... In fact its almost a direct plug-n-play system, but the thought of having an ABS ring custom made makes me think twice... Link to post Share on other sites More sharing options...
Mini-itx Clutched May 25, 2010 Share May 25, 2010 Nay, I don't see the point in changing to disc brakes. If you really want better braking, just get better brake pads for your front. Link to post Share on other sites More sharing options...
5936 1st Gear May 25, 2010 Share May 25, 2010 Insurance issue comes in? change brake ="MODIFIED CAR"?? I agree to replacing better brake pad. or put it in your MUST HAVE item for your next car. Link to post Share on other sites More sharing options...
Krado Clutched May 25, 2010 Share May 25, 2010 Nay, I don't see the point in changing to disc brakes. If you really want better braking, just get better brake pads for your front. Yah loh... "if you want a better car, buy a better car". ↡ Advertisement Link to post Share on other sites More sharing options...
Change Disc Rotors
Change Disc Rotors
Brake Pads
Brake Pads
Is it illegal to fetch passengers at the back of a Suzuki Every?
Brake squeak every morning
2014 Jetta Brake Servo Failure
