Yuan 6th Gear May 16, 2010 Share May 16, 2010 On 5/16/2010 at 12:15 AM, Pisces69 said: =============== U using nanopulsar for long time already? Is it really good? Maybe next time we meet, u can give me more details. I might consider it. Thanks. PS. My battery (MF) already >2 years so might get it to see how much longer it can last. Will show you next Tuesday night. ↡ Advertisement Link to post Share on other sites More sharing options...
Octopus 3rd Gear May 16, 2010 Share May 16, 2010 On 5/15/2010 at 5:13 AM, Yuan said: The whole theory of the battery desulphator is found somewhere in one of the threads. You can go check it out. Not sure whether the price has increased but when I got it, the cost (with installation) was quite reasonable. The nanopulser was tested on my 2nd MF battery (no brand) and supposed to last me 3 months but when I decided to change my this battery some 9-10 months later as I was going away on a trip, this MF battery was still functional as told to me by my battery installer. But my case has to be taken in the light of the ICE in my car which takes in a lot of the battery energy. My current stock battery already past 2 years with >60k km mileage. When it was around 1 year old, I do noticed some formation in the plates when I topping up battery fluid, probably its the sulphur crystal forming. Then I got those tablets battery additive from Autobacs and drop it into the cells. Surprisingly, until now there is no such formation in the plates. Not sure what those additives are and how it works, so far my battery plates seems cleaner than before. Anyway, appreciate those MCFer using nanopulser giving feedback, please share with us how long your battery last with nanopulser. Thanks. Link to post Share on other sites More sharing options...
Octopus 3rd Gear May 16, 2010 Share May 16, 2010 Thanks for your info. I will find out more from my electrical engineer colleague on the principle of nanopulser. Recently the lead acid battery which provide back-up power for our chemical plant control system manfunction, some need replacement. These lead acid battery are not cheap, cost 2 or 3 times normal car battery each and we have many such batteries. If nanopulser would help, maybe can introduce it in our plant. Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 16, 2010 Share May 16, 2010 On 5/16/2010 at 1:07 AM, Yuan said: Will show you next Tuesday night. ================ Ya. Hope can see in the dark. Link to post Share on other sites More sharing options...
Gohsj89 1st Gear May 17, 2010 Share May 17, 2010 i wonder if higherr capacity battery will help in increasing battery cranking Link to post Share on other sites More sharing options...
Kb27 Supersonic May 17, 2010 Share May 17, 2010 It's hard to say. Your starter motor takes a fixed amount of current during cranking. Your stock battery should already be big enough to provide that current. A bigger battery may not necessary crank it up "faster". Although, it's good to have more capacity than is required. But at the same time, you'll be carrying a heavier weight (battery) For my experience, it was a 45AH battery, followed by a 55AH battery didn't crank it any faster. Now, I'm back to 45AH battery. Link to post Share on other sites More sharing options...
Smhomie Clutched May 17, 2010 Share May 17, 2010 On 5/16/2010 at 3:26 AM, Octopus said: My current stock battery already past 2 years with >60k km mileage. When it was around 1 year old, I do noticed some formation in the plates when I topping up battery fluid, probably its the sulphur crystal forming. Then I got those tablets battery additive from Autobacs and drop it into the cells. Surprisingly, until now there is no such formation in the plates. Not sure what those additives are and how it works, so far my battery plates seems cleaner than before. Anyway, appreciate those MCFer using nanopulser giving feedback, please share with us how long your battery last with nanopulser. Thanks. I also used those tablets before when it first came out. This was because my first battery had white deposits on the plates and I was using HOT Inazma voltage stabilizer.... Later on, I read in US sites that such chemical powdered additives are generally bad for your battery, can't remember EDTP or ETPE or something like that... it hardens the crystal and precipitates down to the bottom of the battery, but also affects the 'healthy' lead as well and the build up precipitation below may short cells in between. When I changed to my 2nd battery, didn't use these chemicals anymore. As for principle behind nanopulser, not only I spoke to distributor to find out before buying, but also checked around internet publications and wrote before to main company, their explanation sounds logical but of course not qualified to conclude on it. Basically they explained that the modern day battery now has differing sulphuric acid concentration, water purity levels and lead composition % amounts ie. calcium + tin + lead + silver + whatever... you need to define and work within such a combination to effectively find out the frequency in order to 'shatter' or dissolve the sulphate crystals without harming or affecting the active soft lead itself. I actually went into some US universities technical library and read some papers and this phenomena and theory was true. However with so much technical explanations in chemical terms and hexagonal diagrams and drawings, I give up after a few pages As long as it is founded on established principles, I guess its good enough for me Hope you join the nanopulser fraternity soon like the rest of us users ↡ Advertisement Link to post Share on other sites More sharing options...
Credit cards - benefits
Benefits of having bigger population in our day to day life.
Low sex drive be careful, expert warning : Double the risk of death
Grassroot leader benefits
Higher starting pay for SMU's 2012 cohort of fresh grads
Installing canopy or awning for ground floor unit
How useful is higher pressure radiator cap?
