Nmnhnlm Clutched May 9, 2010 Share May 9, 2010 IMHO, if you really want to get good FC, the best way is to get your ECU tuned and don't drag your gears! Cause Factory ECU is never tuned for 1 specific car and always on the safe side. You should get the ECU tuned to match local condition and your driving style. Most of the people tuned for more power but actually it can be done for FC as well. 1. Reduce your fuel enrichment time under warm up. Our engines always run rich when its cold to make it warm up the engine faster. This time period can actually be reduced. 2. Throttle enrichment. When you step on the throttle, the ECU will spray more fuel than necessary so you get better acceleration. If you are better light on the throttle, can actually set ECU to reduce amt of fuel injected. Get less power but you don't need it under light throttle conditions. This is also why its better to travel at the same speed than accelerate and brake and accelerate again. Throttle enrichment...... 3. Highway cruising. Can actually set the engine to run lean when cruising. But make sure its well tuned else there may pinging. 4. For manual cars, don't drag your gears! If no power, shift down. Running at higher RPM is actually better. I realise when I go up slope on 4th gear, the engine runs rich because of heavy engine load and low RPM. Once I shift down to 3rd, the engine turns to stoichiometric ratio. This can be set in ECU as well. This is what I have observed. IMHO, all the moddings except for CAI (Not open pod, just ducting to draw cooler air outside engine bay) hardly benefits anything in terms of FC. Its ECU tuning that really makes a difference. ↡ Advertisement Link to post Share on other sites More sharing options...
Albeniz Turbocharged May 9, 2010 Share May 9, 2010 Any workshop to recommend for such tuning jobs (particularly for better FC). How much would a typical tuning session cost? Link to post Share on other sites More sharing options...
Zangetsu77 Clutched May 9, 2010 Share May 9, 2010 Any workshop to recommend for such tuning jobs (particularly for better FC). How much would a typical tuning session cost? Depends on your ECU (and hence your car). I would presume it's easier for a non-performance JDM car ECU. Running leaner means you can produce more HP, but bear in mind that driving style makes more difference. Link to post Share on other sites More sharing options...
Friendstar Supercharged May 9, 2010 Share May 9, 2010 IMHO, if you really want to get good FC, the best way is to get your ECU tuned and don't drag your gears! Cause Factory ECU is never tuned for 1 specific car and always on the safe side. You should get the ECU tuned to match local condition and your driving style. Most of the people tuned for more power but actually it can be done for FC as well. 1. Reduce your fuel enrichment time under warm up. Our engines always run rich when its cold to make it warm up the engine faster. This time period can actually be reduced. 2. Throttle enrichment. When you step on the throttle, the ECU will spray more fuel than necessary so you get better acceleration. If you are better light on the throttle, can actually set ECU to reduce amt of fuel injected. Get less power but you don't need it under light throttle conditions. This is also why its better to travel at the same speed than accelerate and brake and accelerate again. Throttle enrichment...... 3. Highway cruising. Can actually set the engine to run lean when cruising. But make sure its well tuned else there may pinging. 4. For manual cars, don't drag your gears! If no power, shift down. Running at higher RPM is actually better. I realise when I go up slope on 4th gear, the engine runs rich because of heavy engine load and low RPM. Once I shift down to 3rd, the engine turns to stoichiometric ratio. This can be set in ECU as well. This is what I have observed. IMHO, all the moddings except for CAI (Not open pod, just ducting to draw cooler air outside engine bay) hardly benefits anything in terms of FC. Its ECU tuning that really makes a difference. with all these trial and error, just one time kanna stranded in expressway will burn away all the fuel u saved. Link to post Share on other sites More sharing options...
Happily1986 5th Gear May 9, 2010 Share May 9, 2010 with all these trial and error, just one time kanna stranded in expressway will burn away all the fuel u saved. you sound like you have got a bitter lesson in this. care to share? Link to post Share on other sites More sharing options...
Nmnhnlm Clutched May 9, 2010 Author Share May 9, 2010 with all these trial and error, just one time kanna stranded in expressway will burn away all the fuel u saved. Whos your Tuner? What ECU you using? Link to post Share on other sites More sharing options...
Kiadaw 6th Gear May 9, 2010 Share May 9, 2010 (edited) My tips. 1) If your manual says can pump 95, don't pump 98 lah, waste money only. But if you like to boost profit of petrol companies, please carry on. 2) Less cheeseburgers & fried chicken & cha qiao tiao. I know I need to cut...Hehe 3) Keep things you don't need to used often back home or in garage. Keep your chainsaw & shovel unless you are going off road & last check, there have not been snow in Singapore since...recorded history. Keep your detailing kits at home & keep only quick cleaning kit in case of air raid. I will however, also keep a small box of handy tools like screwdrivers, torch lights & cable ties. 4) Control your right foot. 5) Off air con (or heater, if you enjoy in car suana session) 5 mins before your destination. 6) Pump your tire regularly, about once every 2-3 weeks. 7) Plan your trip probably. It can save you on distance travel as well as unwanted "Flashing" sound in you IU. 8) Car pool when going for lunch. 9) Be courteous to other drivers, give way & relax when driving. No, it does not improve FC, but it make driving less stressful Cheers Edited May 9, 2010 by Kiadaw Link to post Share on other sites More sharing options...
Krado Clutched May 9, 2010 Share May 9, 2010 you sound like you have got a bitter lesson in this. care to share? I think he means spending all that amount of money for ECU tuning... which saves petrol, will be moot when you're stuck in a traffic jam. Link to post Share on other sites More sharing options...
Ken4555 1st Gear May 9, 2010 Share May 9, 2010 I think he means spending all that amount of money for ECU tuning... which saves petrol, will be moot when you're stuck in a traffic jam. he said stranded... means breakdown in expressway lah... Link to post Share on other sites More sharing options...
Nmnhnlm Clutched May 10, 2010 Author Share May 10, 2010 My tips. 1) If your manual says can pump 95, don't pump 98 lah, waste money only. But if you like to boost profit of petrol companies, please carry on. 2) Less cheeseburgers & fried chicken & cha qiao tiao. I know I need to cut...Hehe 3) Keep things you don't need to used often back home or in garage. Keep your chainsaw & shovel unless you are going off road & last check, there have not been snow in Singapore since...recorded history. Keep your detailing kits at home & keep only quick cleaning kit in case of air raid. I will however, also keep a small box of handy tools like screwdrivers, torch lights & cable ties. 4) Control your right foot. 5) Off air con (or heater, if you enjoy in car suana session) 5 mins before your destination. 6) Pump your tire regularly, about once every 2-3 weeks. 7) Plan your trip probably. It can save you on distance travel as well as unwanted "Flashing" sound in you IU. 8) Car pool when going for lunch. 9) Be courteous to other drivers, give way & relax when driving. No, it does not improve FC, but it make driving less stressful Cheers Actually, you can simply tune the ECU to take advantage of 98 petrol. Having high RON means its more resistant to knocking. Hence you can run leaner than 95 and advance ignition timing further. The problem with most stock ECU is that its simply not set to take advantage of 98 petrol (must remember stock settings need to be catered to many countries and different conditions etc). As mentioned earlier, controlling right foot is subjective due to throttle enrichment. Link to post Share on other sites More sharing options...
Vidz 6th Gear May 10, 2010 Share May 10, 2010 4. For manual cars, don't drag your gears! If no power, shift down. Running at higher RPM is actually better. I realise when I go up slope on 4th gear, the engine runs rich because of heavy engine load and low RPM. Once I shift down to 3rd, the engine turns to stoichiometric ratio. This can be set in ECU as well. good info... thanks Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear May 10, 2010 Share May 10, 2010 i thought only the manufacturers have the program to tune ecu. usually ecu are reflash. another way is to get a standalone to replace the stock ecu. Link to post Share on other sites More sharing options...
Nmnhnlm Clutched May 10, 2010 Author Share May 10, 2010 i thought only the manufacturers have the program to tune ecu. usually ecu are reflash. another way is to get a standalone to replace the stock ecu. Many workshops can do ECU reflash for you though. You can either reflash, get standalone ECU or piggyback. I would say best is piggyback cause it does not alter your stock ECU and process is completely reversible so it does not void warranty. Link to post Share on other sites More sharing options...
Rachaellee Neutral Newbie May 10, 2010 Share May 10, 2010 our stock cars are always gear running on rich juz incase we need to carry heavy loads... wouldn't running lean will cause problems if we suddenly need to carry heavy loads like our Parent in laws???? Link to post Share on other sites More sharing options...
Nmnhnlm Clutched May 10, 2010 Author Share May 10, 2010 our stock cars are always gear running on rich juz incase we need to carry heavy loads... wouldn't running lean will cause problems if we suddenly need to carry heavy loads like our Parent in laws???? No, your ECU will tune the petrol according to the load. If you are under heavy load, ECU will automatically run rich to give you power. Most if not all ECUs will have a load vs RPM table and set the A/F ratio. I am using standalone ECU thus I can see and edit this table. However, its pretty standard stuff so stock ECU do have it as well. Link to post Share on other sites More sharing options...
Mikepitt Clutched May 10, 2010 Share May 10, 2010 After getting a remapped, my FC suffered. Its just too addictive with the gain enjoying my ride more since and never look back. Link to post Share on other sites More sharing options...
Nmnhnlm Clutched May 10, 2010 Author Share May 10, 2010 After getting a remapped, my FC suffered. Its just too addictive with the gain enjoying my ride more since and never look back. Lol... thats the biggest problem. Most people tune for more power rather than better FC. Difficult to have best of both worlds. Link to post Share on other sites More sharing options...
Weiming 1st Gear May 10, 2010 Share May 10, 2010 Proper tuning of ECU to match your driving style will improve FC but will cost lah and improvement is not going to be mind boggling huge :) This path is only for those who like to toy with their ride and planning on keeping it long term or the ride is >10yrs old (older tech that can benefit from modern input) else not worth it. ↡ Advertisement Link to post Share on other sites More sharing options...
Declining eyesight can be improved by looking at red light
Tuned Volvo D2
Tuned Volvo D2
Toyota Harrier Auto transmission problem
Want to buy medical insurance but ....
Daddy Daddy I Want This Want... Its the same age as me..
Hard to engage in 1st gear after transmission oil change
What is the current Manual car selling in Singapore?
