Micb 5th Gear September 20, 2022 Share September 20, 2022 My sibling's COEd 2008 Camry (XV40, mileage about 150k+) has a slow ATF leak (few drops after parking) for the last few months. It will judders when going upslope (fr basement carpark) every morning cold start, brought it to the mechanic and top up 2L of ATF. Last replaced ATF only 2 months back. Well, the mechanic noted the leakage is from the seal but need to lower GB to pinpoint the location. Mechanical suggested her to do a GB overhaul given the COE will last tell May 2028, another 5yrs 8mths to go. After looking through the threads, I think she has the following options: 1. Repair and replace the seals only (if this is even a possibility) 2. Rebuilt or overhaul the GB 3. Drop in a recon GB (imported from Japan) Key consideration is to last for the duration of COE, and cost (of course). Would like to have some advices and views here. Kum sia very much ! ↡ Advertisement Link to post Share on other sites More sharing options...
Fcw75 Hypersonic September 20, 2022 Share September 20, 2022 (edited) 2 hours ago, Micb said: My sibling's COEd 2008 Camry (XV40, mileage about 150k+) has a slow ATF leak (few drops after parking) for the last few months. It will judders when going upslope (fr basement carpark) every morning cold start, brought it to the mechanic and top up 2L of ATF. Last replaced ATF only 2 months back. Well, the mechanic noted the leakage is from the seal but need to lower GB to pinpoint the location. Mechanical suggested her to do a GB overhaul given the COE will last tell May 2028, another 5yrs 8mths to go. After looking through the threads, I think she has the following options: 1. Repair and replace the seals only (if this is even a possibility) 2. Rebuilt or overhaul the GB 3. Drop in a recon GB (imported from Japan) Key consideration is to last for the duration of COE, and cost (of course). Would like to have some advices and views here. Kum sia very much ! I would overhaul the gearbox since 5 years 8 mths is a long time. I went to this workshop few years back to overhaul. Hope it helps. That time was $1600 but now probably went up liao plus different car. Boss name is Ah Seng. Edited September 20, 2022 by Fcw75 3 Link to post Share on other sites More sharing options...
Beregond Supersonic September 20, 2022 Share September 20, 2022 2 hours ago, Micb said: My sibling's COEd 2008 Camry (XV40, mileage about 150k+) has a slow ATF leak (few drops after parking) for the last few months. It will judders when going upslope (fr basement carpark) every morning cold start, brought it to the mechanic and top up 2L of ATF. Last replaced ATF only 2 months back. Well, the mechanic noted the leakage is from the seal but need to lower GB to pinpoint the location. Mechanical suggested her to do a GB overhaul given the COE will last tell May 2028, another 5yrs 8mths to go. After looking through the threads, I think she has the following options: 1. Repair and replace the seals only (if this is even a possibility) 2. Rebuilt or overhaul the GB 3. Drop in a recon GB (imported from Japan) Key consideration is to last for the duration of COE, and cost (of course). Would like to have some advices and views here. Kum sia very much ! Atf leakage from gearbox could be from alot of location. if the judder is from low level of atf, it properly mean the gearbox itself is ok ( if once u top up, and the gearbox work normally) In this case need to check where its leaking, Most popular location is the lock nut itself (esp toyota) That lock nut its very cheap even with a atf refill. next popular location is the driveshaft seal ( where the drive shaft is connected into the gearbox ) To me i will only go for overhaul if even when the atf is at full level but it still judder. 4 Link to post Share on other sites More sharing options...
Mkl22 Supersonic September 20, 2022 Share September 20, 2022 (edited) Overhaul. I made the mistake of just replace it a seal and then about 8mths later it needed an overhaul. Don’t waste time and just do a full overhaul, since there is already juddering. I would assume the mileage is not 100% unless you are the 1st owner. Edited September 20, 2022 by Mkl22 5 Link to post Share on other sites More sharing options...
Micb 5th Gear September 21, 2022 Share September 21, 2022 Thanks @Fcw75, @Beregond and @Mkl22 ! We will go check out SW Autotrans and one or two more gearbox specialist workshop to check the costing. Seems like getting a recon (imported) gear box is not preferred by most, if not all. See if the leak area and the seal replacement can be done without lowering the GB, else if have to lower, then might as well do an overhaul. 2 Link to post Share on other sites More sharing options...
Mkl22 Supersonic September 21, 2022 Share September 21, 2022 1 hour ago, Micb said: Thanks @Fcw75, @Beregond and @Mkl22 ! We will go check out SW Autotrans and one or two more gearbox specialist workshop to check the costing. Seems like getting a recon (imported) gear box is not preferred by most, if not all. See if the leak area and the seal replacement can be done without lowering the GB, else if have to lower, then might as well do an overhaul. 1L a mth is a rather big leak of atf. 1 Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged October 17, 2022 Share October 17, 2022 I would like to ask those who have overhauled your gearbox before: At which point would you decide that a gearbox overhaul is needed? My situation currently: My gearbox ATF oil pan magnet has caught black metal particles during the last 3 ATF oil changes. No problem changing gears between P, R, N, D. Occasionally when driving, I would feel a little slip when I re-accelerate. Sluggish and retarded when trying to downshift. Most of the time I have to put the pedal to the floor before it would downshift. No problems upshifting. Car is lively and responsive when in manual mode though. Would this be a situation serious enough to go for an overhaul? Or should I wait till I have problems changing gears during cold start and/or major clutch slip when driving? 14 year old car here, 6 years renewed COE left. Link to post Share on other sites More sharing options...
Beregond Supersonic October 17, 2022 Share October 17, 2022 11 minutes ago, Beehive3783 said: I would like to ask those who have overhauled your gearbox before: At which point would you decide that a gearbox overhaul is needed? My situation currently: My gearbox ATF oil pan magnet has caught black metal particles during the last 3 ATF oil changes. No problem changing gears between P, R, N, D. Occasionally when driving, I would feel a little slip when I re-accelerate. Sluggish and retarded when trying to downshift. Most of the time I have to put the pedal to the floor before it would downshift. No problems upshifting. Car is lively and responsive when in manual mode though. Would this be a situation serious enough to go for an overhaul? Or should I wait till I have problems changing gears during cold start and/or major clutch slip when driving? 14 year old car here, 6 years renewed COE left. try this 1 first . i try before. it help 😂 1 Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged October 17, 2022 Share October 17, 2022 23 minutes ago, Beregond said: try this 1 first . i try before. it help 😂 You're the second person, after my workshop boss, to introduce this to me. How did this work for your gearbox? Link to post Share on other sites More sharing options...
Beregond Supersonic October 17, 2022 Share October 17, 2022 24 minutes ago, Beehive3783 said: You're the second person, after my workshop boss, to introduce this to me. How did this work for your gearbox? i put coe car. when i first got the car, it got problem shifting gear, like lag of power like that, it help alot after 2 atf change, each atf change i put 1 btl. Its not cheap. 1 btl i buy at 50 sgd...... so far i already use 3 btl. dun need put liao. now gear change back to almost new. 1 Link to post Share on other sites More sharing options...
Micb 5th Gear October 17, 2022 Share October 17, 2022 1 hour ago, Beehive3783 said: I would like to ask those who have overhauled your gearbox before: At which point would you decide that a gearbox overhaul is needed? My situation currently: My gearbox ATF oil pan magnet has caught black metal particles during the last 3 ATF oil changes. No problem changing gears between P, R, N, D. Occasionally when driving, I would feel a little slip when I re-accelerate. Sluggish and retarded when trying to downshift. Most of the time I have to put the pedal to the floor before it would downshift. No problems upshifting. Car is lively and responsive when in manual mode though. Would this be a situation serious enough to go for an overhaul? Or should I wait till I have problems changing gears during cold start and/or major clutch slip when driving? 14 year old car here, 6 years renewed COE left. My 2 cents, it is good to try out some ATF treatment and wait out a while. When the symptoms are quite bad, then go for an overhaul. Speaking from the recent experience of my sis's 2008 Camry, left with about 5yrs+ COE to go. Decided to go for a transmission overhaul ($2.2k) due to the leaking ATF. Frankly, after the overhaul, it solved the leaking issue and the transmission felt lighter and eager to accelerate. Just not sure if this overhaul will last the car till 2028 haha. 1 Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged October 17, 2022 Share October 17, 2022 3 minutes ago, Beregond said: i put coe car. when i first got the car, it got problem shifting gear, like lag of power like that, it help alot after 2 atf change, each atf change i put 1 btl. Its not cheap. 1 btl i buy at 50 sgd...... so far i already use 3 btl. dun need put liao. now gear change back to almost new. I found this on Shopee.. $22 per 250ml bottle 1 Link to post Share on other sites More sharing options...
Beregond Supersonic October 17, 2022 Share October 17, 2022 11 minutes ago, Beehive3783 said: I found this on Shopee.. $22 per 250ml bottle ya. buy online confirm cheaper ma. i use years back, ws make a profit, then labour bababa. u can buy 1 and ask then put together for a atf change and see if any improvement or any different at all then decide if want overhaul GB. Its not only the 2-3k sgd, but lost of use for 3-5 days also.......... 1 Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged October 17, 2022 Share October 17, 2022 1 hour ago, Beregond said: ya. buy online confirm cheaper ma. i use years back, ws make a profit, then labour bababa. u can buy 1 and ask then put together for a atf change and see if any improvement or any different at all then decide if want overhaul GB. Its not only the 2-3k sgd, but lost of use for 3-5 days also.......... My workshop quoted me $70 for 2 bottles. Didn't take on the spot. Said I'd do some research. Sekali found on shopee so cheap lol I can buy 2 bottles and try la since i just changed ATF not long ago. 1 Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged October 17, 2022 Share October 17, 2022 1 hour ago, Micb said: My 2 cents, it is good to try out some ATF treatment and wait out a while. When the symptoms are quite bad, then go for an overhaul. Speaking from the recent experience of my sis's 2008 Camry, left with about 5yrs+ COE to go. Decided to go for a transmission overhaul ($2.2k) due to the leaking ATF. Frankly, after the overhaul, it solved the leaking issue and the transmission felt lighter and eager to accelerate. Just not sure if this overhaul will last the car till 2028 haha. Mine also COE car till 2028 haha. If 2 bottles can rejuvenate the gearbox till 2028, why not? Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 17, 2022 Share October 17, 2022 3 hours ago, Beehive3783 said: I would like to ask those who have overhauled your gearbox before: At which point would you decide that a gearbox overhaul is needed? My situation currently: My gearbox ATF oil pan magnet has caught black metal particles during the last 3 ATF oil changes. No problem changing gears between P, R, N, D. Occasionally when driving, I would feel a little slip when I re-accelerate. Sluggish and retarded when trying to downshift. Most of the time I have to put the pedal to the floor before it would downshift. No problems upshifting. Car is lively and responsive when in manual mode though. Would this be a situation serious enough to go for an overhaul? Or should I wait till I have problems changing gears during cold start and/or major clutch slip when driving? 14 year old car here, 6 years renewed COE left. Mine is when the car cannot move even when I put to D. 😓 Sometimes when it’s moving too. 😅 Was doing grabhitch somemore. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 17, 2022 Share October 17, 2022 (edited) 2 hours ago, Micb said: My 2 cents, it is good to try out some ATF treatment and wait out a while. When the symptoms are quite bad, then go for an overhaul. Speaking from the recent experience of my sis's 2008 Camry, left with about 5yrs+ COE to go. Decided to go for a transmission overhaul ($2.2k) due to the leaking ATF. Frankly, after the overhaul, it solved the leaking issue and the transmission felt lighter and eager to accelerate. Just not sure if this overhaul will last the car till 2028 haha. Which workshop you went in the end? Do share with bros here. I also don’t mind another recommendation to keep…haha. Edited October 17, 2022 by Fcw75 Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged October 17, 2022 Share October 17, 2022 47 minutes ago, Fcw75 said: Mine is when the car cannot move even when I put to D. 😓 Sometimes when it’s moving too. 😅 Was doing grabhitch somemore. Touch wood, mine still can shift gears. Already ordered 3 bottles of the ATF treatment to try out. See if it helps. If in D and can't move, means really gg liao ↡ Advertisement 1 Link to post Share on other sites More sharing options...
All about smoking
All about smoking
Car inspection questions
Top 5 questions to ask every used car dealer
Honda civic FD4 gearbox issue
All about springs and shocks(dampers)
