Versatile 1st Gear April 15, 2010 Share April 15, 2010 (edited) I've been experiencing sluggish low-end especially during 2nd gear after i change my stock 15" to 17" recently. i've changed k&n drop-in filter & customize cai. the problem could be due to the 17".. and yes, i'm on lenso samurai sc01 (it's considered as the "lightweight" cat w/ 7kg per rim.) was wondering what can be the next steps to improve my low-end? i've no issue with mid/high-end and can feel the power with anything above 5k rpm. i'm looking for parts that don't void warranty.. please advise if any of the below that helps and feel free to suggest if i do missed out any. - change stock sparks plug - change stock sparks plug cable - pro steel RS brake hose kit to improve stock brake kit - lta-approved exo (sadly, in the market current don't have any) - uniQ piggyback yes, i'm driving avante 1.6MT. thanks. Edited April 15, 2010 by Versatile ↡ Advertisement Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear April 15, 2010 Share April 15, 2010 ur rolling diameter became much larger or did u get a very thin walled tyre to keep within the same rolling diameter? things that dun void warranty, off aircon/radio while u drive, remove spare tyre and barang from your boot and buy genuine carbon fibre bonnet/boot/bumper/fenders. Link to post Share on other sites More sharing options...
Ken4555 1st Gear April 15, 2010 Share April 15, 2010 abv 5k rmp still no power car can buang liao... and bro sluggish is different to different ppl.... cheapest way to get your low end power up would be a good extractor i guess... but Avante is fairly new so happy serching for the right one... also i feel any mod to air filters/open pod will lower the low end power... that is with a stock engine and exhaust... and seriously... i feel CAIs are really wasting $... yes correct cold air is denser than hot air so logically cold air will create better combustion... but a moving car has out side air continuously entering the engine bay.... so logically i do not feel much lowered air temp as the air pipings would hv heated up anyways... so unless you are measuring ur car's power stationary... i tink CAI systems in the market are useless.... and if you are those with the open pod INSIDE the bumper way below... becareful when it rains.... happy driving.... Link to post Share on other sites More sharing options...
Celicagt42010 Neutral Newbie April 16, 2010 Share April 16, 2010 Changing to bigger rims will definitely make the car sluggish. This is because your wheel diameter will usually increase (unless you use extremely low profile tyres). Weight will increase as well. If you want better performance for low end, You can advance your ignition timing using a piggyback and retune your A/F ratio. A 4-2-1 extractor will also improve your low end a little. Remove cat converter can also do that. change intake manifold also can..... But why bother. Just throw in a supercharger and you get instant power boost.... Link to post Share on other sites More sharing options...
Watwheels Supersonic April 16, 2010 Share April 16, 2010 Instead of throwing more money on things which cannot guarantee to improve low end power/acceleration, might as well loose some money and revert back to stock. Link to post Share on other sites More sharing options...
Kangadrool Supersonic April 16, 2010 Share April 16, 2010 I've been experiencing sluggish low-end especially during 2nd gear after i change my stock 15" to 17" recently. i've changed k&n drop-in filter & customize cai. the problem could be due to the 17".. and yes, i'm on lenso samurai sc01 (it's considered as the "lightweight" cat w/ 7kg per rim.) was wondering what can be the next steps to improve my low-end? i've no issue with mid/high-end and can feel the power with anything above 5k rpm. i'm looking for parts that don't void warranty.. please advise if any of the below that helps and feel free to suggest if i do missed out any. - change stock sparks plug - change stock sparks plug cable - pro steel RS brake hose kit to improve stock brake kit - lta-approved exo (sadly, in the market current don't have any) - uniQ piggyback yes, i'm driving avante 1.6MT. thanks. Change everything back to stock, including the steel rims. This is not a performance car. Link to post Share on other sites More sharing options...
Zaska 1st Gear April 16, 2010 Share April 16, 2010 I've been experiencing sluggish low-end especially during 2nd gear after i change my stock 15" to 17" recently. i've changed k&n drop-in filter & customize cai. the problem could be due to the 17".. and yes, i'm on lenso samurai sc01 (it's considered as the "lightweight" cat w/ 7kg per rim.) was wondering what can be the next steps to improve my low-end? i've no issue with mid/high-end and can feel the power with anything above 5k rpm. i'm looking for parts that don't void warranty.. please advise if any of the below that helps and feel free to suggest if i do missed out any. - change stock sparks plug - change stock sparks plug cable - pro steel RS brake hose kit to improve stock brake kit - lta-approved exo (sadly, in the market current don't have any) - uniQ piggyback yes, i'm driving avante 1.6MT. thanks. Your customised CAI n K&N could be the could be the problem, try putting in stock filter n try. very unlikely rev until 5k still no power one. also, for the rest of mod, personally i feel only brake hose its more useful, the rest can dun do. Link to post Share on other sites More sharing options...
Unfair 3rd Gear April 16, 2010 Share April 16, 2010 Bro, there are cases whereby change of upsize rims/change of tyres from stock also void warranty. Warranty on gearbox somemore lol, AD claims due to gearbox not designed to handle the new load..... anyways, - change stock sparks plug (not useful) - change stock sparks plug cable (not useful) - pro steel RS brake hose kit to improve stock brake kit (improves feel only, braking distance still the same. consider upsized rotor, caliper if $$ allows.) - lta-approved exo (sadly, in the market current don't have any) (if you want to try can get exhaust shop do up illegal one.) - uniQ piggyback (this is normally done after all other mods are done and you are satisfied.) Link to post Share on other sites More sharing options...
Versatile 1st Gear April 16, 2010 Author Share April 16, 2010 abv 5k rmp still no power car can buang liao... and bro sluggish is different to different ppl.... cheapest way to get your low end power up would be a good extractor i guess... but Avante is fairly new so happy serching for the right one... also i feel any mod to air filters/open pod will lower the low end power... that is with a stock engine and exhaust... and seriously... i feel CAIs are really wasting $... yes correct cold air is denser than hot air so logically cold air will create better combustion... but a moving car has out side air continuously entering the engine bay.... so logically i do not feel much lowered air temp as the air pipings would hv heated up anyways... so unless you are measuring ur car's power stationary... i tink CAI systems in the market are useless.... and if you are those with the open pod INSIDE the bumper way below... becareful when it rains.... happy driving.... Actually there are customized extractor out in the market already. Not locally but overseas. I can feel slight improvement on throttle especially on stock rim.. but the improvement eventually go away after upgrading to 17". Kinda regretted changing to 17" tho.. should have just upgrade to 16" will do. Link to post Share on other sites More sharing options...
Versatile 1st Gear April 16, 2010 Author Share April 16, 2010 Change everything back to stock, including the steel rims. This is not a performance car. I know it's not a performance car.. If i would want a performance car in the first place.. i would had go for more high-end performance car.. but it's a passion to slowly upgrade to market's performance parts. it's a joy to drive a not-so-stock saloon car.. personal opinion tho.. Link to post Share on other sites More sharing options...
Versatile 1st Gear April 16, 2010 Author Share April 16, 2010 Bro, there are cases whereby change of upsize rims/change of tyres from stock also void warranty. Warranty on gearbox somemore lol, AD claims due to gearbox not designed to handle the new load..... anyways, - change stock sparks plug (not useful) - change stock sparks plug cable (not useful) - pro steel RS brake hose kit to improve stock brake kit (improves feel only, braking distance still the same. consider upsized rotor, caliper if $$ allows.) - lta-approved exo (sadly, in the market current don't have any) (if you want to try can get exhaust shop do up illegal one.) - uniQ piggyback (this is normally done after all other mods are done and you are satisfied.) Thanks bro. guess i will just to wait.. Link to post Share on other sites More sharing options...
So_nice 6th Gear April 16, 2010 Share April 16, 2010 17" is too big lah. wanna pick up u should stay 15" Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear April 16, 2010 Share April 16, 2010 anyway dun worry, wait a few more months, you will get used to the slower pickup. Just "tahan" a bit now. touch your engine and warranty sure void. Link to post Share on other sites More sharing options...
Circuit Clutched April 16, 2010 Share April 16, 2010 it is like tat when 15 to 17. when i change it last time to light wt rims, my fuel consumption down by 50km. and slower pk up. if heavier rims lucky worst. but hell alot more grip, corner no brakes like no tomorrow. 16" cannot match the grip offering. if u want a bigger rim, get 16 jus nice for the grip and pick up. For looks 17 lor and get use to it lor. Link to post Share on other sites More sharing options...
Pandaeyes Neutral Newbie April 16, 2010 Share April 16, 2010 Instead of throwing more money on things which cannot guarantee to improve low end power/acceleration, might as well loose some money and revert back to stock. I fully agree. Y CAI/Open Pod? Since you say that your rims are lightweight, then the prob of sluggish low end could be due to your Open Pod. Stock is best brother... Dun spend so much money since your car is NA. Link to post Share on other sites More sharing options...
Windchoco 1st Gear April 16, 2010 Share April 16, 2010 Agree that stock Avante is already well balanced car. By changing to openpod, u lose the low end. by changing to 17", u lose the almost best in class comfort and quietness. Not worth. Link to post Share on other sites More sharing options...
Luckcent 4th Gear April 16, 2010 Share April 16, 2010 Dont change all those yu have mentioned...Just changed the car to wrx....all solved. Link to post Share on other sites More sharing options...
Dwoon 1st Gear April 16, 2010 Share April 16, 2010 Hmmm.... why would CAI/Pod affect the pickup? This is the input to engine.... doesn't affect the back pressure at all (that's exhaust) . If you ask me, it'll give faster throttle rev response due to more free flow of air into the engine. Question for TS. Did you change the tube diameter whereby your MAF/MAP sensor is mounted? (That requires tuning otherwise it'll screw up all your AFR). I hope you didn't mess around with that when doing your CAI piping. This should be done for piping upfront of the air flow sensor and nothing at or after, leading to the engine. (Unless you intend to tune) If the above holds true..... then tis your added weight of the wheels/tyres. To get some low end back, you might want to try a lightened crank pulley. (will most likely void warranty) Leave the alternator pulley alone (some will recommend you do that too), else your battery charging might be adversely affected. (unless you know what you're doing) ↡ Advertisement Link to post Share on other sites More sharing options...
Check Engine Light and Sluggish Performance
Sluggish car
Sluggish car
Extremely WHITE!
Extremely WHITE!
Sluggish Acceleration issue
Extremely bad jam tis mrn at KPE and Tampines Rd
ENGINE Sluggish when EO hits 6K mark
Sluggish sunny FL N16
