Dafansu Turbocharged March 25, 2010 Share March 25, 2010 since you driving auto car, just press on the brake, why need to pull handbrake at junction? are you saying that you pull the handbrake in drive mode and released the brake? ↡ Advertisement Link to post Share on other sites More sharing options...
So_nice 6th Gear March 25, 2010 Share March 25, 2010 ATF is ur gear box oil. auto transmittion fluid. recomended to change every 40k. wat do u mean by u change to D when u stop at traffic light? D -> drive and uses all gears D2 -> 2nd gear D3 -> 1st gear O/D -> overdrive or 3rd gear sometimes when u need alittle extra power u can make use of the O/D button located at the gear knob there. it drops a gear so u can rev higher for power. to drive normally just use D will do. the other 2 Ds are for steep slopes. Link to post Share on other sites More sharing options...
So_nice 6th Gear March 25, 2010 Share March 25, 2010 since you driving auto car, just press on the brake, why need to pull handbrake at junction? are you saying that you pull the handbrake in drive mode and released the brake? lazy lor. hahaha. hey bro u still haf tat speedo for vios? Link to post Share on other sites More sharing options...
Acerchan2002 Clutched March 25, 2010 Share March 25, 2010 Normally i juz pull handbrake without shifting to N at traffic juctions cuz lazy to step on foot brake. This would reduce wear and tear to gearbox. Link to post Share on other sites More sharing options...
Whywhy68 Neutral Newbie March 25, 2010 Author Share March 25, 2010 Normally i juz pull handbrake without shifting to N at traffic juctions cuz lazy to step on foot brake. This would reduce wear and tear to gearbox. but nv shift to N remain at D tot easily spoil the Brakepad ? no meh? Link to post Share on other sites More sharing options...
So_nice 6th Gear March 25, 2010 Share March 25, 2010 brake pads are meant to be replaced an ur gearbox not. anyway brake pad is cheap. even if it does affect the wear and tear rate also nvm. ur gearbox several Ks Link to post Share on other sites More sharing options...
Whywhy68 Neutral Newbie March 25, 2010 Author Share March 25, 2010 brake pads are meant to be replaced an ur gearbox not. anyway brake pad is cheap. even if it does affect the wear and tear rate also nvm. ur gearbox several Ks wah so big diff ar... Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear March 25, 2010 Share March 25, 2010 if u want to save on brake pads then open door use ur leg to stop the car lor. shoes/slippers cheaper than brake pads. ↡ Advertisement Link to post Share on other sites More sharing options...
WISHING ALL MEMBERS A HAPPY CHINESE LUNAR NEW YEAR 2025
Mid year bonus and bicentennial $200
First time buyer looking to buy Avante / Elantra / Vios / Shuttle
