Ken4555 1st Gear January 28, 2010 Author Share January 28, 2010 On 1/28/2010 at 6:06 AM, Byond said: haha already got FREE awareness in SLC forum liao last year OCt.... do u have the link pls... i wanna read.... ↡ Advertisement Link to post Share on other sites More sharing options...
OLLAH Neutral Newbie January 28, 2010 Share January 28, 2010 On 1/26/2010 at 4:03 AM, Ken4555 said: hi all, went through the latest issue of hot stuff just... (wah girls this issue power sia...) ... and i saw Motec's ad says OWS NA racing @ $48... usual $96... WTF??? but there was a star next to the $48... anybody knows wats the terms and con?.... the last i saw the OWS NA racing at Motec a month ago, it was $130 or $128... or smthing... hmmmmm..... any bro can shed some light pls.... i tried calling them yesterday couldnt get through... and now they are close right?... many thanks.. Can someone advice where is OWS company and manufacturing plant is? I hear that OWS is not a real company but just a rebranded product. Not sure if it's true. Link to post Share on other sites More sharing options...
Yuan 6th Gear January 28, 2010 Share January 28, 2010 On 1/28/2010 at 2:16 AM, Robo said: U're comparing a different grade and quality oil. lol lol..... This thread is getting so serious...Trying to crack a joke to lighten everybody.... Link to post Share on other sites More sharing options...
Yuan 6th Gear January 28, 2010 Share January 28, 2010 On 1/28/2010 at 4:13 AM, Ken4555 said: same here... seems OWS NA running temp slightly lower... even after high revs... and FC not bad comparing to previous X-rev... by the way bro do you keep the extra OWS NA after your oil change? My car only requires 3.5 litres. The tin I think is 4 or 5 litres. Sure got residue or leftover. I donated to the workshop. Link to post Share on other sites More sharing options...
OLLAH Neutral Newbie January 28, 2010 Share January 28, 2010 On 1/28/2010 at 8:27 AM, Yuan said: My car only requires 3.5 litres. The tin I think is 4 or 5 litres. Sure got residue or leftover. I donated to the workshop. Your car engine still working well? Link to post Share on other sites More sharing options...
Yuan 6th Gear January 28, 2010 Share January 28, 2010 On 1/28/2010 at 2:17 AM, Robo said: im using ows 5w30 dont really like it. smooth yes, gd fc? not too bad. still prefer my RL Haven't try RL yet. Intend to do so in one of my next servicings. Link to post Share on other sites More sharing options...
Ken4555 1st Gear January 28, 2010 Author Share January 28, 2010 On 1/28/2010 at 7:57 AM, OLLAH said: Can someone advice where is OWS company and manufacturing plant is? I hear that OWS is not a real company but just a rebranded product. Not sure if it's true. that report was on voltronic... OWS sue them liao or somthing cause they made false info and claims onOWS...... OWS here now is real lah... some German problem they had... long time liao... Link to post Share on other sites More sharing options...
Ken4555 1st Gear January 28, 2010 Author Share January 28, 2010 On 1/28/2010 at 8:27 AM, Yuan said: My car only requires 3.5 litres. The tin I think is 4 or 5 litres. Sure got residue or leftover. I donated to the workshop. its 4 liters lah... you buy you dont know?... my car only use 2.7liters... with oil filter 2.9... so i always keep... Link to post Share on other sites More sharing options...
Yuan 6th Gear January 28, 2010 Share January 28, 2010 On 1/28/2010 at 9:54 AM, Ken4555 said: its 4 liters lah... you buy you dont know?... my car only use 2.7liters... with oil filter 2.9... so i always keep... I old uncle liao....Got short term memory failure.... Thanks for informing and reminding me. Link to post Share on other sites More sharing options...
Yuan 6th Gear January 28, 2010 Share January 28, 2010 On 1/28/2010 at 8:29 AM, OLLAH said: Your car engine still working well? Still working fine. Thanks for your concern. Link to post Share on other sites More sharing options...
Ken4555 1st Gear January 28, 2010 Author Share January 28, 2010 if next time you change OWS NA racing... donate to me your left over... maybe we do an exchange for fuel additive or something? seal new one dont worry... Link to post Share on other sites More sharing options...
Yuan 6th Gear January 29, 2010 Share January 29, 2010 On 1/28/2010 at 5:07 PM, Ken4555 said: if next time you change OWS NA racing... donate to me your left over... maybe we do an exchange for fuel additive or something? seal new one dont worry... No problem. You can PM me and we can go for a kopi as well.... Link to post Share on other sites More sharing options...
Kb27 Supersonic January 29, 2010 Share January 29, 2010 On 1/26/2010 at 4:35 AM, Ken4555 said: by the way, any bro here knows if voltage boosters till 18+ volts... will it kill any prt of the car? blown fuses or bulbs? Voltage booster is a little like using 98 octane when your car doesn't need it. However, it's more dangerous to electronics that is designed to run off 12Vdc. Example are your very expensive ecu, your HU, amp, bulbs, etc. If it blows fuse, you are lucky. If not, you get expensive repair. If you only increase voltage to the spark plug, then you get higher tension than is necessary. If your spark plug is already firing optimally and efficiently combusting fuel/air mix, there's nothing more than can make it bang harder. By setting a bigger fire to a house, it will still burn with the same energy with the same fuel (house). Link to post Share on other sites More sharing options...
OLLAH Neutral Newbie January 29, 2010 Share January 29, 2010 On 1/28/2010 at 10:10 AM, Yuan said: Still working fine. Thanks for your concern. Good Luck. Better check your dip stick often Link to post Share on other sites More sharing options...
OLLAH Neutral Newbie January 29, 2010 Share January 29, 2010 On 1/28/2010 at 9:54 AM, Ken4555 said: its 4 liters lah... you buy you dont know?... my car only use 2.7liters... with oil filter 2.9... so i always keep... 2.7? You driving a QQ? Link to post Share on other sites More sharing options...
Ken4555 1st Gear January 29, 2010 Author Share January 29, 2010 On 1/29/2010 at 1:30 AM, OLLAH said: 2.7? You driving a QQ? i was surprised.... sunny N16.... 2.7 liters... with oil filter is 2.9.... i poured in 3liters above the H mark... no kidding.... start engine stop engine... still above H mark.... Link to post Share on other sites More sharing options...
Ken4555 1st Gear January 29, 2010 Author Share January 29, 2010 On 1/29/2010 at 12:58 AM, Kb27 said: Voltage booster is a little like using 98 octane when your car doesn't need it. However, it's more dangerous to electronics that is designed to run off 12Vdc. Example are your very expensive ecu, your HU, amp, bulbs, etc. If it blows fuse, you are lucky. If not, you get expensive repair. If you only increase voltage to the spark plug, then you get higher tension than is necessary. If your spark plug is already firing optimally and efficiently combusting fuel/air mix, there's nothing more than can make it bang harder. By setting a bigger fire to a house, it will still burn with the same energy with the same fuel (house). thanks for saving me a couple hundred dollars.... hope you have a great weekend! Link to post Share on other sites More sharing options...
Yuan 6th Gear January 29, 2010 Share January 29, 2010 On 1/29/2010 at 1:29 AM, OLLAH said: Good Luck. Better check your dip stick often I check my dipstick and car fluids every weekend. Thanks for reminding me again. ↡ Advertisement Link to post Share on other sites More sharing options...
Johor gov’t plans to reopen Pasir Gudang circuit
How to migrate aust , nz with only engineering deg ?
View this subaru WRX listing at tp compound
Why Koenigsegg has never gone racing
McLaren 720s accident on ECP
Car Closest to Formula 1
Speeding, Rounding, Orchard Gudang and much more
AP racing rotor
AP racing rotor
