Tough Mathematical Qns (Help!!!)
Ivan96935sg
Calling all maths genius for help........to solve the following qns:-
Tried to solve but then apparently my maths had returned a huge bulk to my former teachers. :wacko:
There were 2 identical flight of steps. For the 1st flight of steps, Jim walked up some steps and ran 7 steps in 70s. For the 2nd flight of steps, he walked up some steps and ran 15 steps in 46s. How long did Jim take to walk up both flight of steps? (Ans: 182s).
x=walk
y=run
x+7y = 70 ---(1)
x+15y = 46 ---(2)
(1)x15 -> 15x + 105y = 1050 ---(3)
(2)x7 -> 7x + 105y = 322 ---(4)
(3)-(4) -> 8x = 728
therefore x = 91s, if he walk up the 2 flight of stairs he will use 91s x 2 which is 182s
Edited by Ahleon
the difference of 1st and 2nd: 70-46 = 24s
2nd step run more step: 15-7=8
so every step run/walk difference is 24/8=3s
so for 1st flight of step, if all walk need 70+7*3 = 91s
for 2nd flight of step, if all walk need 46 + 15*3 = 91s
Total = 91*2 = 182 s
am I math genius? YES
:D
Edited by Wadexu
It looks like test english first and test math later...
the time he saved by running up instead of walking up 8 steps(15-7) is 70s-46s=24s
one step walking takes up 3s more.
So if he walk 7 steps instead of running, he took 3s x 7 = 21s more
So total for 1st flight of stairs is 70s +21s =91s
so 2 flight = 2 x 91s = 182s
yes, an English test. this will make it clearer.
There were 2 identical flight of steps. For the 1st flight of steps, Jim walked up some steps and ran 7 steps in a total of 70s. For the 2nd flight of steps, he walked up some steps and ran 15 steps in a total of 46s. How long did Jim take to walk up both flight of steps? (Ans: 182s).
Based on the above solution, so X=91 and Y=-3. So if assuming ran 32 steps, the time taken will be -5s. So this is a mathematical Q but with an illogical outcome.
x=walk
y=run
x+7y = 70 ---(1)
x+15y = 46 ---(2)
(3)-(4) -> 8x = 728
pardon me for my limited knowledge, your solution too chim for me.
what exactly is 'x'? i assume is time spend on walking, then 'x' is not the same for both equation right?
U are right...
a=number of total steps, y=walking steps per second and x=running steps per seconds
For alegbra,
Equation1
[a-7]/y+7/x=70
Equation2
[a-15]/y+15/x=46
The question and answer are not logically correct....The total time taken is 70s+46s=116s and the answer is for walking step is 182s more than total time taken...
Edited by Sucker
how come everytime i do not hav the chance to reply 1st (was outside client's place)?? haiz, so many maths experts here.. i no need to makan le.. wanted to look for tuition jobs in maths but looks like there are many out there fighting wif me...
U are right...
For alegbra,
Equation1
[a-7]/y+7/x=70
Equation2
[a-15]/y+15/x=46
i guess is english problem again... question should be asking what is the total time taken if he is to ONLY walk up both flight of stairs.
this answer explain quite clearly i guess.
if u looking at the correct solution, Y=-3 is the time save on running compare to walking. that means 3sec difference. so if he ran 32 steps, he would have save 96secs compare to walking.
Your english is clearer.... the question posed below is correct... just that the question did not drill into my mind.. tend to drift off... [dizzy]
