Lala81 Hypersonic January 10, 2010 Share January 10, 2010 (edited) Deciding between the 2. Mainly for surfing, facebook, talk to fiancee on MSN while at work Anyone with any negative/positive feedback regarding their experiences? I've tried my colleague's starhub ? 3.6mbps (that's what it said when connected), found it decent. Using SNBB 10mbps at home. Is 1mbps very slow? or good enuff in most of your experiences?v Singtel 1mbps $13.50 for 2yr contract, $22.5 for 1 yr 2mbps $18.5 for 2 yr, $ 26 for 1 yr Starhub (only 2 yr contract) 1.2mbps $14 2mbps $19.4 Singtel starhub Edited January 10, 2010 by Lala81 ↡ Advertisement Link to post Share on other sites More sharing options...
Albeniz Turbocharged January 10, 2010 Share January 10, 2010 I have been on Singtel mobile broadband for a few months. Used mostly during off-office hours and the weekends. So far no problem encountered. Link to post Share on other sites More sharing options...
Lorinser 1st Gear January 10, 2010 Share January 10, 2010 starhub works badly in punggol. i gave that up and change to singtel. check with someone that stays same location as you. starhub is not broadband... it's shareband. the more ppl use starhub in your area, the slower it will get. for your requirement, as long as youtube can play smoothly.... it's good enuff for you on the safe side... dun take starhub Link to post Share on other sites More sharing options...
Jman888 Moderator January 10, 2010 Share January 10, 2010 iPhone with data plan? can surf, msn, facebook... now am doing this fr bintan (using wifi lah)... Link to post Share on other sites More sharing options...
Blackyv Turbocharged January 10, 2010 Share January 10, 2010 starhub works badly in punggol. i gave that up and change to singtel. check with someone that stays same location as you. starhub is not broadband... it's shareband. the more ppl use starhub in your area, the slower it will get. for your requirement, as long as youtube can play smoothly.... it's good enuff for you on the safe side... dun take starhub i can vouch for M1 too that works badly in punggol... was using M1 mbb in sengkang with no problem but the moment i moved to punggol, no signal, disconnect, ..until i dont bother to use till contract end and have it cancel... change to st on the same day and working fine from day one..... so, the rule is whichever telco signal is strong at your area, that is the one that most likely work well since it's all about signal when come to mobile bb..... Link to post Share on other sites More sharing options...
Lala81 Hypersonic January 10, 2010 Author Share January 10, 2010 iPhone with data plan? can surf, msn, facebook... now am doing this fr bintan (using wifi lah)... me no smartphone. i dun really like to surf with a small screen. I was considering it. but probably mobile BB suits my needs more. There is a pc at my workplace. I can just plug in the usb modem to it to surf with normal screen Link to post Share on other sites More sharing options...
Lala81 Hypersonic January 10, 2010 Author Share January 10, 2010 i can vouch for M1 too that works badly in punggol... was using M1 mbb in sengkang with no problem but the moment i moved to punggol, no signal, disconnect, ..until i dont bother to use till contract end and have it cancel... change to st on the same day and working fine from day one..... so, the rule is whichever telco signal is strong at your area, that is the one that most likely work well since it's all about signal when come to mobile bb..... Do the 2 use different technology in their mobile BB? Link to post Share on other sites More sharing options...
Lekkie Neutral Newbie January 10, 2010 Share January 10, 2010 No, the 2 same tech. For home than they are different. 1 using phone line, 1 using SCV cable point. Link to post Share on other sites More sharing options...
Geminik Neutral Newbie January 10, 2010 Share January 10, 2010 (edited) me no smartphone. i dun really like to surf with a small screen. I was considering it. but probably mobile BB suits my needs more. There is a pc at my workplace. I can just plug in the usb modem to it to surf with normal screen U can use iphone as a portable modem and connect to a laptop and surf, like wad i'm doing now, mine is starhub, kinda fast in woodlands area.....my area maybe.... Edited January 10, 2010 by Geminik Link to post Share on other sites More sharing options...
Pratakosong 2nd Gear January 10, 2010 Share January 10, 2010 I have both starhub (comes free bundled with my home maxonline) which i use solely at home and a singtel BBOM which i use when i go out. I personally find that singtel speed slightly slower but its much more stable (ie can use on mrt, CBD, ulu areas) without any problems... Link to post Share on other sites More sharing options...
Raining Neutral Newbie January 10, 2010 Share January 10, 2010 used all 3 services on their mobile bb... in order of stability (most impt imo for mobile bb) 1)singnet 2)starhub (the coverage some bro mention is true, as mobile bb is basically ur hp network) 3) m1 (bad experience despite having supposely better mobile coverage) in terms of hardware, most of them uses huawei, which is pretty stable so far, no crashes or funny funny stunts as far as i can rem... Link to post Share on other sites More sharing options...
Raining Neutral Newbie January 10, 2010 Share January 10, 2010 starhub works badly in punggol. i gave that up and change to singtel. check with someone that stays same location as you. starhub is not broadband... it's shareband. the more ppl use starhub in your area, the slower it will get. for your requirement, as long as youtube can play smoothly.... it's good enuff for you on the safe side... dun take starhub nope, you are wrong, all 3 telco's mobile broadband are essentially your mobile network. if starhub's mobile bb is shared, so is singtel's. on the home bb i suggest you read up DSL vs Cable broadband cheers Link to post Share on other sites More sharing options...
Booboon 1st Gear January 10, 2010 Share January 10, 2010 U can use iphone as a portable modem and connect to a laptop and surf, like wad i'm doing now, mine is starhub, kinda fast in woodlands area.....my area maybe.... Wat aps did u use for internet sharing. i thou iphone got no internet shharing, only wm ph can? Link to post Share on other sites More sharing options...
Will_I_Am 2nd Gear January 10, 2010 Share January 10, 2010 I have both M1 and SingTel Mobile broadband. Don't bother with M1 - signal sucks big time. Always kenna disconnected or super slow speed. Think worse than 14.4kbps modem era. Singtel signal quality still acceptable and consistent. At 1Mbps, cannot complain already. Link to post Share on other sites More sharing options...
Duythangos Neutral Newbie January 10, 2010 Share January 10, 2010 I stay in West Coast garden and i used to try starhub and M1.... just two word : very bad. signal drop every half hour, then i switch to singtel, it's better Link to post Share on other sites More sharing options...
Myrl Clutched January 10, 2010 Share January 10, 2010 Wat aps did u use for internet sharing. i thou iphone got no internet shharing, only wm ph can? I think he is referring to iPhone's tethering ability. Check it out here. Link to post Share on other sites More sharing options...
Devilac Neutral Newbie January 11, 2010 Share January 11, 2010 Using Starhub 2mbps mobile bb. So far so good. Link to post Share on other sites More sharing options...
Tkseah Turbocharged January 11, 2010 Share January 11, 2010 The speed for my Singtel mobile BB is not consistent.. can be pretty fast in the morning & afternoon.. but crawls in the evening.. guess it's due to congestion.. ↡ Advertisement Link to post Share on other sites More sharing options...
YouTrip Mobile wallet
Fibre broadband
Fibre broadband
Singtel line down?
Singtel line down?
StarHub customers affected by home broadband disruption can register for one-time 20% rebate on monthly fee
UMIDIGI mobile phone
I got charged for Global SMS by Singtel, and they cannot do anything!
Is M1 mobile network down ? 04 Feb 2014
