Potex water cistern flushing system
Civic6656
Thank you for sharing [thumbsup] . Although it may be an old thread, it is useful for me now since I encounter similar problem recently.
Have a nice day! [sunny]
This follow up post is to contribute towards this article for members who may have similar problem since I managed to fix the leakage using a compatible part since the original part is no longer in production.
1st thing to note is the model no. of the potex cistern. Mine is a TM311R. After purchasing the part, modification is required to fit the compatible part to the system. Even the flush button which comes with the new part as part of the package is different although the original button may be used.
Photos of the original and compatible parts cannot be uploaded for now because I do not know how to upload the image in this new design of MCF since the image button only has a url column without a browse button which I usually find to upload a file or image from my computer or thumbdrive. [shakehead]
Anyway, parts are available at Tiong Yeong Hardware.
Cheers! [sunny]
i have a query. does any bro know how to remove the potex lid? It is a single flush system built in the past by HDB. i could not google anything on this. hope to receive some advice on this. tks.
A white plastic screw is on the top of the lid,use a coin to open.
Advisable to check the date of the post before you specifically reply to it otherwise you may be relying to an obsolete question and waste unnecessary effort.
Can try look for flush valve assembly and DIY replacement. The flush valve comes in diameters and length/height, although some height adjustment provided. Bring the flush valve along to compare with stocks at the shop. Not sure if I still got spare around.
Photos of substitute cistern parts.
Cheers! [sunny]
Seems it is now possible to upload the photos which I did not manage to in above post. The new part from Tiong Yeong costs iirc was about $10-15 per set. They were the one who recommended me the substituted part. The only modification I need to do was sawing off the length of the new part to fit into existing cistern. The original push button was used instead of the new one which requires adjustment.
Hope this helps those who uses the same Potex model i.e. TM311R.
Edited by Neutralsg
Hi bro.tks for your advice. But how to remove d valve before accessing d screw. Cnt figure out hw it is done...nt a diy guy n nt much info in d web on potex too...tks...
I believe all new and past hdb owner have potex toilet and flushing system installed.If your water keep on flowing from tank to toilet bowl then your dounut shape gasket below the plunger must have spoiled. I manage to found silicone type replacement for potex brand at this place and walaa it stop flowing endlessly.
I found mine at rivervale plaze near punggol a hardware shop called hardware 88 trading, i can't believe i can find the exact fix.Anyone thinking of changing without buying a whole cistern can consider.Homefix also have silicone gasket but not suitable for potex cistern as it was too thin and single layer.
[scholar]
Another type of leak is the 50cent size washer inside the ball float arm that will cause the refill to flow non stop easy to buy and fix too.
potex a sanitary brand from malaysia installed on new hbd flats a decade ago.i help you hope next time you guys can help me back too.
the half size plastic washer on top must use two finger push out side way and use some force too .Careful don't break it.
If you are thinking of DIY, do give more information like the brand, pull or push version. Hopefully someone among us can help.
it's exactly the same as TS first post.....so have narrowed down to GWC, Tiong Lin building, etc.
Good that this thread still here
Thanks
Delayed top cistern, almost collector item. Perhaps you want to save some water with latest flushing cistern model.
perhaps. Thks
reviving this thread
Think my O-seal kaputted. Anyone know where to get?
I found mine at rivervale plaze near punggol a hardware shop called hardware 88 trading, i can't believe i can find the exact fix.Anyone thinking of changing without buying a whole cistern can consider.Homefix also have silicone gasket but not suitable for potex cistern as it was too thin and single layer. [scholar]i have changed myself no leak till now.
I say so many times where to buy people here treat me like idiot like i talking nonsense , you wanna spend 100dollars listening to other old bird here go ahead.Where less than 10 dollars could fix it you still dont want then i got nothing to say i also old bird too look at the year i sign up this account but not as active.
You better switch off your cistern water supply and use pail to flush first , if not next month you water bill comes haha you will cry .Clean water flowing 24hour non stop away it will hit you hard and it did to me too.
i know you talking crap to me when i first posted my solutions and leaking incident , now it hit you too and know how it felt.Even you got car the possiblity of findng excact seal are still low ,outside simply dont sell that exact kind of item and most will lure you to change whole system to eanr from you.I was so lucky to found exact silicone replacement and confirm wont leak when installed properly.You guys and other laugh at me what a joke.
Er... Yes? You put your point across and now? U wan give limpei lecture?
Is ok I got it fr the source.
Now old man go back to whr u came from. Tuvm
just to update.
took a nice bus ride to Rivervale mall on a wet rainy morning. Found the shop, at lvl 1. 88 trading or sth....
Uncle there very nice and taught me how to do instal. $8.5 each. No biggie. Lesson on how to fix a leak all included and fully worth it
Bought 2.
Installed in 10mins for each and leak solved.
thanks bros for all the guidance and keep this thread handy for surely most wil need this tip.
Have a gd wknd all
