Billcoke 2nd Gear May 6, 2010 Share May 6, 2010 You can't do anything about the zooming as well as preventing the POI from disappearing from the screen. It's all in the Nuvi's software and one possible way out is for Garmin to do a firmware update if there are areas that are problematic. If you are talking about those POIs which you saved as waypoints in your "Favourite", then it is possible to transfer all or selected one from one device to another using mapsource. All these favourites reside in G:/Garmin/GPX. Just connect your device to the mapsource and under "Tranfser" in mapsource, select "Receive from device". All your routes, maps, waypoints and tracks will be imported from your connected device and displayed in mapsource. ONce done, unplugged your device from the PC and connect the other device to the PC. Before you transfer all the favourites or selected one to the second device, please delete all those waypoints and also those tracks, maps and routes, if any, that you do not want to transfer over. Then, under "Transfer", select "Send to device". Thank you. Roger that. :) Once again, many thanks for your guidance on GPS related matters. ↡ Advertisement Link to post Share on other sites More sharing options...
Billcoke 2nd Gear May 9, 2010 Share May 9, 2010 You can't do anything about the zooming as well as preventing the POI from disappearing from the screen. It's all in the Nuvi's software and one possible way out is for Garmin to do a firmware update if there are areas that are problematic. If you are talking about those POIs which you saved as waypoints in your "Favourite", then it is possible to transfer all or selected one from one device to another using mapsource. All these favourites reside in G:/Garmin/GPX. Just connect your device to the mapsource and under "Tranfser" in mapsource, select "Receive from device". All your routes, maps, waypoints and tracks will be imported from your connected device and displayed in mapsource. ONce done, unplugged your device from the PC and connect the other device to the PC. Before you transfer all the favourites or selected one to the second device, please delete all those waypoints and also those tracks, maps and routes, if any, that you do not want to transfer over. Then, under "Transfer", select "Send to device". Thank you. For Garmin, how do we do a exact search for address? Garmin only locate the road name but not the exact blk. Where To -> Address -> Search All -> 74 (House no) -> Bedok North Road (Street name) Link to post Share on other sites More sharing options...
Donut Supercharged May 11, 2010 Share May 11, 2010 which Garmin model is able to make route planning? i know lower end model can't do it? Link to post Share on other sites More sharing options...
EleGPS Neutral Newbie May 12, 2010 Share May 12, 2010 which Garmin model is able to make route planning? i know lower end model can't do it? As I know, Garmin can do if you turn off the GPS signal. but only A to B type plan, I am not able to do A to B to C or more.... Igo8 has this feature to set via point, and Igo8 can save these route plan for future usage, for instance today I want use A to B1 to C, tomorrow I want to use A to B2 to C. papago also can do via point route plan, but can not save. mapking 2007 and mapking landmark also can, but can not save. sygic, route66, agis, tibo and amigo all can do route plan at home. Link to post Share on other sites More sharing options...
Ender Hypersonic May 12, 2010 Share May 12, 2010 For Garmin, how do we do a exact search for address? Garmin only locate the road name but not the exact blk. Where To -> Address -> Search All -> 74 (House no) -> Bedok North Road (Street name) I usually use the Point of Interest-> Spell name.. I'll key in partial name to search.. e.g just key in "100 Ang Mo" for 100 ang mo kio.. Search time takes longer though. Link to post Share on other sites More sharing options...
Billcoke 2nd Gear May 12, 2010 Share May 12, 2010 (edited) I usually use the Point of Interest-> Spell name.. I'll key in partial name to search.. e.g just key in "100 Ang Mo" for 100 ang mo kio.. Search time takes longer though. Thanks Ender, tried the Point of Interest-> Spell name, and it works. But Garmin will also attempt to search addresses in Malaysia and Thailand too, hence takes so long to search, right? Edited May 12, 2010 by Billcoke Link to post Share on other sites More sharing options...
Dwoon 1st Gear May 12, 2010 Share May 12, 2010 Turn off the maps you're not using lor...... Link to post Share on other sites More sharing options...
Ender Hypersonic May 12, 2010 Share May 12, 2010 Thanks Ender, tried the Point of Interest-> Spell name, and it works. But Garmin will also attempt to search addresses in Malaysia and Thailand too, hence takes so long to search, right? Not only that, it also search thru the database of restaurants, lodging, ATM, basically all POIs, that's why it takes much longer compare to a proper search.. But no choice as MFM and MAlsing put those blk numbers as a POI and not as addresses. Link to post Share on other sites More sharing options...
MadDog70 2nd Gear May 12, 2010 Share May 12, 2010 I find Garmin forum a bit confusing, with so many different steps in updating the maps. Some more, the POI updates is in different pages. Why can't they put everything CLEAR in one page? Link to post Share on other sites More sharing options...
Esmond Neutral Newbie May 20, 2010 Share May 20, 2010 garmin is garmin. a bit complicated. Link to post Share on other sites More sharing options...
Mdfaz 2nd Gear June 10, 2010 Share June 10, 2010 Exactly.. I find updating map on garmin quite troublesome.. Dunno which page to refer to and its confusing. Link to post Share on other sites More sharing options...
Robo 2nd Gear June 15, 2010 Share June 15, 2010 i just got the 1350... kinda lost on the updating part... Link to post Share on other sites More sharing options...
Mdfaz 2nd Gear June 15, 2010 Share June 15, 2010 You can update your map from here: http://www.malsingmaps.com/forums/viewtopi...92&start=30 But this one is free and has no JCV and LA... for that, i think you need unclock codes or something... quite complicated... hope this helps. Link to post Share on other sites More sharing options...
Redstorm 1st Gear June 15, 2010 Share June 15, 2010 You can update your map from here: http://www.malsingmaps.com/forums/viewtopi...92&start=30 But this one is free and has no JCV and LA... for that, i think you need unclock codes or something... quite complicated... hope this helps. No, now the map in malsingmaps no longer requires an unlock code. It is very straightforward. Just download, unzip, copy and paste the file (gmapsupp.img) into the Garmin folder of the SD card and you are good to go. Link to post Share on other sites More sharing options...
Ender Hypersonic June 15, 2010 Share June 15, 2010 You can update your map from here: http://www.malsingmaps.com/forums/viewtopi...92&start=30 But this one is free and has no JCV and LA... for that, i think you need unclock codes or something... quite complicated... hope this helps. Malsing has stopped locking their maps.. Simply copy the Gmapsupp.img file into your USB_Drive:\Garmin directory. Link to post Share on other sites More sharing options...
Mdfaz 2nd Gear June 15, 2010 Share June 15, 2010 ok, does this apply for localised sets that support JCV and LA as well? Link to post Share on other sites More sharing options...
Robo 2nd Gear June 15, 2010 Share June 15, 2010 will it corrupt the files i have already in the stored memory? that means 1 gps has gt multiple maps? Link to post Share on other sites More sharing options...
Mdfaz 2nd Gear June 15, 2010 Share June 15, 2010 Not sure if can take multiple maps.. i just copied the gmapsupp.img file over to the file located in the sd card. you can refer to Redstorm's advice at the beginning of this thread... i followed that and managed to update mine. ↡ Advertisement Link to post Share on other sites More sharing options...
Which airline is the best?
Attention all Duragloss #951 Aquawax user.
Advice: which web hosting good?
Google Maps can now tune its eco-friendly navigation for gas, diesel, and electrified vehicles
Honda Civic servicing... Which workshop to go?
