Yaloryalor 5th Gear November 11, 2009 Share November 11, 2009 Hi All, I will be doing my 40K servicing in about 1 month time. What are the things that need to be change? Top up the auto oil? Aircon flushing? When I bought my car at ~32K mileage, I have already changed the sparkplug and did the engine flush. I suppose I do not need to do engine flash liao? Spark plug also dun need to change rite? My current workshop charges are a bit ex. Any reliable and reasonable pricing workshop to recommend? Tks! ↡ Advertisement Link to post Share on other sites More sharing options...
Chiangauto Clutched November 11, 2009 Share November 11, 2009 well.......engine oil,filter,spark plug,fluids,additives,brake pad,light,timing belt,tyres,and etc Link to post Share on other sites More sharing options...
Ultramega 1st Gear November 11, 2009 Share November 11, 2009 Auto oil? U mean the ATF? At 40k, it's better to drain completely (flush too if budget allows) and replace. Brake fluid - should change also. Power steering fluid and coolant - drain and change if you want, if not, top up. Things like battery, brake pads, engine air filter, spark plugs, aircon filter - ask the workshop check/test/take out let u see, then decide. For peace of mind, change everything la! Link to post Share on other sites More sharing options...
Zniper 2nd Gear November 11, 2009 Share November 11, 2009 Hi All, I will be doing my 40K servicing in about 1 month time. What are the things that need to be change? Top up the auto oil? Aircon flushing? When I bought my car at ~32K mileage, I have already changed the sparkplug and did the engine flush. I suppose I do not need to do engine flash liao? Spark plug also dun need to change rite? My current workshop charges are a bit ex. Any reliable and reasonable pricing workshop to recommend? Tks! on attached is one list u can take a look and compare... it's for my ride but i guess it's almost the same... cheers VIOS_Periodical_Maintenance_Schedule.doc Link to post Share on other sites More sharing options...
Yaloryalor 5th Gear November 11, 2009 Author Share November 11, 2009 well.......engine oil,filter,spark plug,fluids,additives,brake pad,light,timing belt,tyres,and etc Timing belt?? Only change at 100k leh. My previous car change at 150K (recommended by the AD). Link to post Share on other sites More sharing options...
Yaloryalor 5th Gear November 11, 2009 Author Share November 11, 2009 on attached is one list u can take a look and compare... it's for my ride but i guess it's almost the same... cheers Tks Bro! Link to post Share on other sites More sharing options...
Chiangauto Clutched November 12, 2009 Share November 12, 2009 Timing belt?? Only change at 100k leh. My previous car change at 150K (recommended by the AD). timing belt better change at 60k. Link to post Share on other sites More sharing options...
Enduro25 Clutched November 18, 2009 Share November 18, 2009 i changed mine timing belt at 80k..other than tat during 40k is change brake fluid,ATF,power steering fluid,spark plug(since u had change urs think no need change ) Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear November 19, 2009 Share November 19, 2009 40K servicing is consider as major servicing Extra things to change other than those standard servicing as follows:- 1) ATF Fluid 2) Power Steering Fluid 3) Brake Fluid 4) Fuel Filter Maybe top up aircon condener oil, change aircon filter (Some change every 20K interval if your ride is having one) Link to post Share on other sites More sharing options...
7007 2nd Gear November 19, 2009 Share November 19, 2009 Hi All, I will be doing my 40K servicing in about 1 month time. What are the things that need to be change? Top up the auto oil? Aircon flushing? When I bought my car at ~32K mileage, I have already changed the sparkplug and did the engine flush. I suppose I do not need to do engine flash liao? Spark plug also dun need to change rite? My current workshop charges are a bit ex. Any reliable and reasonable pricing workshop to recommend? Tks! many brands classified 40K as major service. So if you do somewhere else you risk the possibility of having your warranty void. better check the T & C first... Link to post Share on other sites More sharing options...
Byond 1st Gear November 19, 2009 Share November 19, 2009 if possible, try not to change some of the items at AD... things like air con filters, u will definately be carrot chop there there are a few sellers selling the same type of ac filters online... getting 2 to 3 pcs from them directly will equate to getting 1 pc from AD... Link to post Share on other sites More sharing options...
7007 2nd Gear November 19, 2009 Share November 19, 2009 Yeah, make sure they seek your permission b4 the AD replace the so-called consumables... Link to post Share on other sites More sharing options...
Picanto 3rd Gear November 21, 2009 Share November 21, 2009 Hi All, I will be doing my 40K servicing in about 1 month time. What are the things that need to be change? Top up the auto oil? Aircon flushing? When I bought my car at ~32K mileage, I have already changed the sparkplug and did the engine flush. I suppose I do not need to do engine flash liao? Spark plug also dun need to change rite? My current workshop charges are a bit ex. Any reliable and reasonable pricing workshop to recommend? Tks! maybe try autosaver? Link to post Share on other sites More sharing options...
Yaloryalor 5th Gear November 22, 2009 Author Share November 22, 2009 Mine is a PI car so no prob. And car is coming to 3 years old liao. I was quoted ~$260 for standard 40K service (without spark plugs). Reasonable? Need to do aircon flashing or engine flash? Link to post Share on other sites More sharing options...
Quekahwhye Clutched November 22, 2009 Share November 22, 2009 well.......engine oil,filter,spark plug,fluids,additives,brake pad,light,timing belt,tyres,and etc 40k need to change timing belt and brake pad???????? Link to post Share on other sites More sharing options...
Picanto 3rd Gear November 22, 2009 Share November 22, 2009 40k need to change timing belt and brake pad???????? no need, unless you want to let the WS chop carrot Link to post Share on other sites More sharing options...
Yaloryalor 5th Gear November 23, 2009 Author Share November 23, 2009 40k need to change timing belt and brake pad???????? 40K confirmed dun need to change the Timing belt. Link to post Share on other sites More sharing options...
Razorback Neutral Newbie November 24, 2009 Share November 24, 2009 no need to change timing belt its too early for ur car to chage it... change engine oil, oil filter gear box oil serpentine belt,, check first for cracks flush coolant sparkplug? if iridium no need.... if copper must change lah.. if u whant i know some work shop at eunos technolink... try to go there... and let them check ur car... here the web www.providencemotor.com ↡ Advertisement Link to post Share on other sites More sharing options...
Workshops with engine oil flushing machine
Volvo Servicing
Volvo Servicing
Lee Sheng Auto - One Stop Auto Repair Centre! From accident repair & claims, spray painting, diagnostics, general repairs to servicing.
Servicing car at Shell station
