Decimal86 Clutched October 23, 2009 Share October 23, 2009 hi all, i have a sealed lead acid battery 6 V. but it is dead. cannot be recharged. i was wondering if it can be serviced? thks for all yr help. ↡ Advertisement Link to post Share on other sites More sharing options...
LauSaiKia Neutral Newbie October 23, 2009 Share October 23, 2009 Perhaps what you can do is empty the water in the battery and top up with acid again and try charge again...Mostly likely it wont work but since its dead so no harm trying. Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 25, 2009 Share October 25, 2009 It got nothing to do with the diluted sulphric acid and moreover it's enviromentally difficult to dispose off the fluid. The cause is either damaged/shorted or highly sulphated plates. My adv is DON'T try to open up the sealing cover don't endanger yrself and the enviroment. Link to post Share on other sites More sharing options...
Alfisti168 1st Gear October 25, 2009 Share October 25, 2009 If your battery 2 years le its time to change your batt liao. can call AA to replace your battery. Delivery to doorstep Link to post Share on other sites More sharing options...
Leepee 1st Gear October 25, 2009 Share October 25, 2009 Try Ctek, it can recondition any battery that seems dead. Really good for those who use 6V or 12V lead acid battery for security power source or remote control car charging,etc. Link to post Share on other sites More sharing options...
Decimal86 Clutched October 27, 2009 Author Share October 27, 2009 On 10/25/2009 at 10:23 AM, Leepee said: Try Ctek, it can recondition any battery that seems dead. Really good for those who use 6V or 12V lead acid battery for security power source or remote control car charging,etc. hey that's a good tip. kam sia. any contact info pls? yeah, i agree with you guys that we have to give a thought for the enviro, that's why i thot of salvaging (if poss) rather than throw away. Link to post Share on other sites More sharing options...
Smhomie Clutched October 27, 2009 Share October 27, 2009 On 10/27/2009 at 5:15 AM, Decimal86 said: hey that's a good tip. kam sia. any contact info pls? yeah, i agree with you guys that we have to give a thought for the enviro, that's why i thot of salvaging (if poss) rather than throw away. Sorry, had a Ctek charger and didn't do squat for my batteries in the past. If your battery is internally damaged, cells shorted or plates heavily sulfated, you cannot revive it. The charging amperage of Ctek is rather small as well. Now using nanopulser, no need to have charger anymore. Given my Ctek charger away Link to post Share on other sites More sharing options...
Limbat 1st Gear October 27, 2009 Share October 27, 2009 On 10/27/2009 at 5:48 AM, Smhomie said: Sorry, had a Ctek charger and didn't do squat for my batteries in the past. If your battery is internally damaged, cells shorted or plates heavily sulfated, you cannot revive it. The charging amperage of Ctek is rather small as well. Now using nanopulser, no need to have charger anymore. Given my Ctek charger away I agreed with u, nothing can save a dead battery. But CTEK got fast & slow models, which model did u gave away ?? U wan to try a faster model XS25000 - T loan it to you for testing !! Link to post Share on other sites More sharing options...
Alfisti168 1st Gear October 27, 2009 Share October 27, 2009 (edited) On 10/27/2009 at 5:48 AM, Smhomie said: Now using nanopulser, no need to have charger anymore. Given my Ctek charger away what's tt? Edited October 27, 2009 by Alfisti168 Link to post Share on other sites More sharing options...
Smhomie Clutched October 27, 2009 Share October 27, 2009 On 10/27/2009 at 9:41 AM, Limbat said: I agreed with u, nothing can save a dead battery. But CTEK got fast & slow models, which model did u gave away ?? U wan to try a faster model XS25000 - T loan it to you for testing !! I had the XS7000 model. For XS25000, its rated at 25A but still regulated, no adjustment. Ctek can only hope to clear slight sulphation as in the manual specs. Even with RECOND mode, still cannot save. You can't revive damaged plates or shorted cells or heavily sulphated lead plates. Maintenance Charging is meant for undercharged batteries due to infrequent use/stop-go conditions. ↡ Advertisement Link to post Share on other sites More sharing options...
Battery for Honda Vezel
My EV journey to the i4
Battery Voltage up & down
Amaron Battery
Amaron Battery
