Albc Neutral Newbie January 8, 2010 Share January 8, 2010 hurricane is famous for their drop in filter. ↡ Advertisement Link to post Share on other sites More sharing options...
Vtec88 Neutral Newbie January 21, 2010 Share January 21, 2010 just treat it as a investment.... cos if all fails... at least u tell yourself u buying a filter that can last forever and need not spend $$ at evry svc ing Link to post Share on other sites More sharing options...
Hammerhammer 1st Gear January 22, 2010 Share January 22, 2010 Ya this filter not as expensive as K&N and easier to maintain. Just take out use water to hose it all the dirt will come out. And it is better then stock paper ones. In the long run still better as you have to change stock filter once in a while. Power wise pick up increase a bit. My low end improved more then mid to high end. Link to post Share on other sites More sharing options...
Nmnhnlm Clutched January 23, 2010 Share January 23, 2010 Yes I used to have a hurricane on my E39. Its confirm better than stock paper. Link to post Share on other sites More sharing options...
Introz Clutched February 2, 2010 Share February 2, 2010 sori to ask K&N is what brand? Link to post Share on other sites More sharing options...
Picanyeo 1st Gear February 2, 2010 Share February 2, 2010 K&N is quite a reputable company manufacturing air filters for automobiles.. You can do a search and read up on it.. Link to post Share on other sites More sharing options...
SaNibOy Clutched February 2, 2010 Share February 2, 2010 K&N not only for cars. Even bikes also have. Link to post Share on other sites More sharing options...
Niltrams 3rd Gear February 2, 2010 Share February 2, 2010 I heard hurricane SS air filter not recommended for turbocharged cars... cos the poor filtration can let small particles pass through and damage the turbine ?? Link to post Share on other sites More sharing options...
Roger78 Neutral Newbie February 3, 2010 Share February 3, 2010 Ya this filter not as expensive as K&N and easier to maintain. Just take out use water to hose it all the dirt will come out. And it is better then stock paper ones. In the long run still better as you have to change stock filter once in a while. Power wise pick up increase a bit. My low end improved more then mid to high end. K&n ish only about 80 or 90 SGD for drop in type... Hurricane is at least 120 to 140 SGD.. Link to post Share on other sites More sharing options...
SaNibOy Clutched February 4, 2010 Share February 4, 2010 Is it? I tot K&N and Hurricane price wise both ard $120 to $140? Link to post Share on other sites More sharing options...
Ishootthemoon Neutral Newbie February 22, 2010 Share February 22, 2010 Video of K&N Air Filter Demo http://www.mobilpac.com/musicvideo.php?vid=9ac5554a6 Link to post Share on other sites More sharing options...
Qes78 Neutral Newbie May 14, 2010 Share May 14, 2010 I currently use Hurricane on both my cars. No complaints. I used to be a KnN fan, but lazy to wash and oil Link to post Share on other sites More sharing options...
Question Neutral Newbie May 24, 2010 Share May 24, 2010 stock best Link to post Share on other sites More sharing options...
SaNibOy Clutched May 26, 2010 Share May 26, 2010 stock best Then u stay stock la. Tis thread not for u. Link to post Share on other sites More sharing options...
Victor68 Turbocharged July 11, 2010 Share July 11, 2010 Although I used to wonder if all these so called performance enhancing parts do help, and why don't the car manufacturers themselves installed them if they work. I have used 1 or 2 of these items that I feel make sense but I didn't really able to account the difference. Take for example of the talk of having higher voltage for spark plugs to ensure better burning of the fuel. I don't agree with that theory. Coil can be designed to discharge much higher voltage if necessary by the manufacturer. It is the optimal voltage that count not the higher the better. Link to post Share on other sites More sharing options...
Boo_saa Neutral Newbie July 12, 2010 Share July 12, 2010 No offence but my take is that its not usefull, It only make you suffer on the low end. look at the filler, have you ever wonder why it can take in more air? The filtration for that filter is to big to trap partical. For some of the bro that are using it, i will suggest you get some mech to clean you thr-body more offten. cheers Link to post Share on other sites More sharing options...
Garis Clutched July 12, 2010 Share July 12, 2010 Bought 2nd hand-used for 1 week-sold 3rd hand-Lao hong feeling-period. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged July 12, 2010 Share July 12, 2010 hold the ss filter under light n see - much bigger lobangs than K&N n other types. plus ecu WILL recompensate a/f mixture. conclusion - either stock or K&N at most. ↡ Advertisement Link to post Share on other sites More sharing options...
Air Purifier Discussion - tips and info
DIY engine oil change
Recommendation for water filter
Dyson Zone, the real deal or has April fool's day come early?
Replacing fuel filter
TRD Engine Air Filter
More frequent filter and engine oil change due to haze
