Friendstar Supercharged October 18, 2009 Share October 18, 2009 where should i go to get my wheel alignment? in addition, good price, short waiting time, good service. i'm thinking of changing tyres for my 1.6m3 realized my inner section botak after 40k km. i suspect wheel alignment got problem. but soh bros don't do alignment. any advice? ↡ Advertisement Link to post Share on other sites More sharing options...
Kyojin 1st Gear October 18, 2009 Share October 18, 2009 M3 got 1.6 meh? thought 3L inline-6 and above only? Kenny Alignment or Stamford Tyres Link to post Share on other sites More sharing options...
Whitecvt Clutched October 18, 2009 Share October 18, 2009 same computerized alignment @ Autodynamac Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged October 18, 2009 Share October 18, 2009 M3 got 1.6 meh? thought 3L inline-6 and above only? Kenny Alignment or Stamford Tyres his is mazda 3 lah, not the M3 that u r toking about... Link to post Share on other sites More sharing options...
Ken_leong 2nd Gear October 18, 2009 Share October 18, 2009 where should i go to get my wheel alignment? in addition, good price, short waiting time, good service. i'm thinking of changing tyres for my 1.6m3 realized my inner section botak after 40k km. i suspect wheel alignment got problem. but soh bros don't do alignment. any advice? Leong seng or city auto Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 18, 2009 Share October 18, 2009 M3 got 1.6 meh? thought 3L inline-6 and above only? Kenny Alignment or Stamford Tyres His is Mazda 3, not BMW M3. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 18, 2009 Share October 18, 2009 Since Soh bro is at AMK, suggest you go to either Riverview Auto or Kenny Alignment at AMK Autopoint. Both on the 4th floor and using computerised wheel alignment. Can ask both of them to quote you first. Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 18, 2009 Share October 18, 2009 Since Soh bro is at AMK, suggest you go to either Riverview Auto or Kenny Alignment at AMK Autopoint. Both on the 4th floor and using computerised wheel alignment. Can ask both of them to quote you first. 4-50 is e norm Link to post Share on other sites More sharing options...
Friendstar Supercharged October 18, 2009 Author Share October 18, 2009 4-50 is e norm Wah thanks man!!! very informative. Link to post Share on other sites More sharing options...
Friendstar Supercharged October 18, 2009 Author Share October 18, 2009 M3 got 1.6 meh? thought 3L inline-6 and above only? Kenny Alignment or Stamford Tyres zzzzz i can also say M5 but mazda 5 Link to post Share on other sites More sharing options...
Yuan 6th Gear October 18, 2009 Share October 18, 2009 where should i go to get my wheel alignment? in addition, good price, short waiting time, good service. i'm thinking of changing tyres for my 1.6m3 realized my inner section botak after 40k km. i suspect wheel alignment got problem. but soh bros don't do alignment. any advice? Go google Creative Trading. It is computerized alignment. Located at Woodlands Industrial Park E. I always go to him. Nice and honest boss! Link to post Share on other sites More sharing options...
Glow Neutral Newbie October 20, 2009 Share October 20, 2009 Behind Po Heng tyre shop ...old uncle not bad Link to post Share on other sites More sharing options...
Friendstar Supercharged October 20, 2009 Author Share October 20, 2009 Behind Po Heng tyre shop ...old uncle not bad you mean for alignment? Link to post Share on other sites More sharing options...
Firecman Neutral Newbie October 20, 2009 Share October 20, 2009 where should i go to get my wheel alignment? in addition, good price, short waiting time, good service. i'm thinking of changing tyres for my 1.6m3 realized my inner section botak after 40k km. i suspect wheel alignment got problem. but soh bros don't do alignment. any advice? Inner shoulder wear shows negative camber. Did you change your springs and dampers? or are they stock? If they are stock, I am not so sure if you can adjust the camber settings. The factory settings are generally within a range and not perfect. If your camber cannot be adjusted, the alignment job cannot help in that area. Your best bet is to rotate your wheels diagonally more often. Link to post Share on other sites More sharing options...
Friendstar Supercharged October 20, 2009 Author Share October 20, 2009 Inner shoulder wear shows negative camber. Did you change your springs and dampers? or are they stock? If they are stock, I am not so sure if you can adjust the camber settings. The factory settings are generally within a range and not perfect. If your camber cannot be adjusted, the alignment job cannot help in that area. Your best bet is to rotate your wheels diagonally more often. ok i'm noob in this. when people do rotation, they do rotation between front and back right? do they do left and right? Link to post Share on other sites More sharing options...
WWbarb 1st Gear October 20, 2009 Share October 20, 2009 criss cross... back left --> front right, back right --> front left Link to post Share on other sites More sharing options...
Garlic 1st Gear October 20, 2009 Share October 20, 2009 (edited) criss cross... back left --> front right, back right --> front left Not applicable for asymmetrical and directional tyres. Edited October 20, 2009 by Garlic Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear October 20, 2009 Share October 20, 2009 ok i'm noob in this. when people do rotation, they do rotation between front and back right? do they do left and right? Directional/Rotational Tires will only swap front and back.. Uni-directional tires can swap criss cross, front back.. ↡ Advertisement Link to post Share on other sites More sharing options...
COVID-19: Retrenchments
NUS Grad becomes rubbish collector after retrenchment
My engine after 150,000 kms
Shell to downsize ops in sgp
Refund of booking fee after 6 failed COE bids?
Getting job after retrenchment: What will u do?
Hard to engage in 1st gear after transmission oil change
