Steering vibrates at every speed
Zyrofillica
definitely try wheel alignment and wheel balancing first.second is tyres,third engine and ........
and 4th..is to let Workshop people earn more $$$$
i rem my tyre also used to be like tat which cause it to jerk at watever spd..
Last time my tires also warped, steering vibrating violently at low speed, when jacked up and check, the thread turned "S" shape and the inner metal was exposed.
Age of the tyres is important. You can check the manufactured date at the side of the tyre. There is an oval outline with 4 numbers, eg 2208, 22nd week, 2008. tyres more than two years old should be change as the tyre compound has hardened.
Hey. check your alignment. If all's a ok, go and check up the tyres pressure and the rate of wear and tear.
