Chiangauto Clutched November 12, 2009 Share November 12, 2009 definitely try wheel alignment and wheel balancing first.second is tyres,third engine and ........ ↡ Advertisement Link to post Share on other sites More sharing options...
Picanto 3rd Gear November 14, 2009 Share November 14, 2009 definitely try wheel alignment and wheel balancing first.second is tyres,third engine and ........ and 4th..is to let Workshop people earn more $$$$ Link to post Share on other sites More sharing options...
Keen 1st Gear November 14, 2009 Share November 14, 2009 how come tyre will deform? din really heard of it before... anyone can further explain? Link to post Share on other sites More sharing options...
Geminik Neutral Newbie November 14, 2009 Share November 14, 2009 i rem my tyre also used to be like tat which cause it to jerk at watever spd.. Last time my tires also warped, steering vibrating violently at low speed, when jacked up and check, the thread turned "S" shape and the inner metal was exposed. Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 14, 2009 Share November 14, 2009 how come tyre will deform? din really heard of it before... anyone can further explain? inferior rubber n construction not well suited to local climate Link to post Share on other sites More sharing options...
Amsyl Neutral Newbie November 14, 2009 Share November 14, 2009 Age of the tyres is important. You can check the manufactured date at the side of the tyre. There is an oval outline with 4 numbers, eg 2208, 22nd week, 2008. tyres more than two years old should be change as the tyre compound has hardened. Link to post Share on other sites More sharing options...
Hisap Neutral Newbie November 15, 2009 Share November 15, 2009 Hey. check your alignment. If all's a ok, go and check up the tyres pressure and the rate of wear and tear. ↡ Advertisement Link to post Share on other sites More sharing options...
Steering leather wrapping
Top 5 questions to ask every used car dealer
How problematic is VW's 7 speed DSG?
OMEGA low speed juicer
