Zyrofillica 1st Gear October 11, 2009 Share October 11, 2009 (edited) steering wheel is juddering left and right slightly at all speeds. Judders faster and faster at higher speeds. Notices car also pulls to the left slightly. No unusual sounds heard. Any ideas if its the steering rack or wheel bearings or god forbid my shaft bent on its own? Have checked tyre pressures and my wheels were balanced after tyre rotation 10000km ago so i do not think its the tyres or the stock rims problem. mileage nearing 130k km mark now. any ideas anyone? Edited October 11, 2009 by Zyrofillica ↡ Advertisement Link to post Share on other sites More sharing options...
Bornno1 1st Gear October 11, 2009 Share October 11, 2009 try doing wheel alignment and wheel balancing first, if still no luck maybe tie rod spoil or control arm bushings worn out. Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear October 12, 2009 Author Share October 12, 2009 ok thanks for your inputs. Anyone else with similar problems before? Link to post Share on other sites More sharing options...
Timmz2000 Neutral Newbie October 12, 2009 Share October 12, 2009 maybe u can try to jack up the car/wheel till you can freely rotate them. 1) run your palm to feel any irregularities on the tyre surface as it spins. i had put in too much air once ( 37psi ) on the gas station pump- but I guess it was more - and the michelins had deformed and had bumps on the thread, it created more tyre roar than vibrations. stupid tyre rotation techs did not detect the issue while balancing the tyres. 2) with the car jacked up and preferably on stands. grab the wheel and try to shake it - up down left right / side. it should always be mounted solidly and not have any free play at all. Link to post Share on other sites More sharing options...
Byond 1st Gear October 12, 2009 Share October 12, 2009 check ur engine mounts... Link to post Share on other sites More sharing options...
Chogokin 1st Gear October 12, 2009 Share October 12, 2009 Jus did tyre rotation ? if yes then might due to uneven wear. after a while should be ok once it is even out. I had the same problem after tyre rotation . Went to tyre shop ask for alightment. After doing alightment test they swop the tire again , this time pull to the right , previously pull to left . They said after a while will be ok . Indeed after driving for a weeks ok liao . Link to post Share on other sites More sharing options...
Yongtaufoo 1st Gear October 13, 2009 Share October 13, 2009 hi bro, Have you try to take alook underneath your car? Perhaps the tie rods or bushings are worn off. Attached photo with worn off bushings for your reference. Link to post Share on other sites More sharing options...
Mtkpl Neutral Newbie October 18, 2009 Share October 18, 2009 alightment issue? Link to post Share on other sites More sharing options...
Alfisti168 1st Gear October 18, 2009 Share October 18, 2009 Your mileage is very high. Could be be tyre wear? Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear October 19, 2009 Author Share October 19, 2009 changed tyres. problem solved. The old tyres deformed already causing one side to wobble. 40k km firenzas. Thank you everybody, for all the tips and help. Link to post Share on other sites More sharing options...
Jchuacl Clutched October 20, 2009 Share October 20, 2009 How long did you originally intend to use your old tyres? changed tyres. problem solved. The old tyres deformed already causing one side to wobble. 40k km firenzas. Thank you everybody, for all the tips and help. Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear November 5, 2009 Author Share November 5, 2009 (edited) How long did you originally intend to use your old tyres? tyres 2 years old? mileage around 35k. Thread grooves still very deep. dunno why tyre deformed. must be i suay. Edited November 5, 2009 by Zyrofillica Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 5, 2009 Share November 5, 2009 tyres 2 years old? mileage around 35k. Thread grooves still very deep. dunno why tyre deformed. must be i suay. firenza tyre is one brand tat u muz avoid at all costs.... Link to post Share on other sites More sharing options...
Watwheels Supersonic November 5, 2009 Share November 5, 2009 firenza tyre is one brand tat u muz avoid at all costs.... Yeah man. Although it offers cheaper prices dan other brands but what you pay is what you get. Link to post Share on other sites More sharing options...
Enduro25 Clutched November 5, 2009 Share November 5, 2009 i rem my tyre also used to be like tat which cause it to jerk at watever spd.. Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear November 5, 2009 Author Share November 5, 2009 lol. ok... i just changed another set of firenzas! a bit late in the advice department shucks, at least they are cheap. i hope they are safe enuff for a simple A to B driver like me. Link to post Share on other sites More sharing options...
Accord Clutched November 9, 2009 Share November 9, 2009 Face the same problem too..had it checked, was my uneven tyres which causes by my faulty shocks..:( Link to post Share on other sites More sharing options...
Luckcent 4th Gear November 9, 2009 Share November 9, 2009 If you want cheap and good tyres...Get Hankook. :D ↡ Advertisement Link to post Share on other sites More sharing options...
Steering leather wrapping
Top 5 questions to ask every used car dealer
How problematic is VW's 7 speed DSG?
OMEGA low speed juicer
