Altivo 3rd Gear September 30, 2009 Author Share September 30, 2009 hey bluepica and M3, thanks for that. Ya.... i guess need to go to Jln Besar there to look see look see. ↡ Advertisement Link to post Share on other sites More sharing options...
Altivo 3rd Gear September 30, 2009 Author Share September 30, 2009 (edited) HDB toilet really CMI... just 6 months back, the refill valve leaked for both toilets. Now is the stop/flapper valve which is leaking... sian Edited September 30, 2009 by Altivo Link to post Share on other sites More sharing options...
Shull Turbocharged January 16, 2015 Share January 16, 2015 Dug out old thread. Same thing, toilet Cistern leaking. Problem is, my cistern is those designer brand (Gustavsberg) which the developer installed when the condo is built. Long story short, the authorised supplier charge a whopping $160 for a new set of mechanism. My mechanism is fine, it's the rubber seal which is leaky, but the seal is those ball type kind, which cannot be found in typical neighbourhood hardware shop. Any idea where can i find plumbing shops (other than the distributor) to buy the rubber seal? 1 Link to post Share on other sites More sharing options...
Alpha78 6th Gear January 16, 2015 Share January 16, 2015 Dug out old thread. Same thing, toilet Cistern leaking. Problem is, my cistern is those designer brand (Gustavsberg) which the developer installed when the condo is built. Long story short, the authorised supplier charge a whopping $160 for a new set of mechanism. My mechanism is fine, it's the rubber seal which is leaky, but the seal is those ball type kind, which cannot be found in typical neighbourhood hardware shop. Any idea where can i find plumbing shops (other than the distributor) to buy the rubber seal? Lame idea, go to your neighbourhood cobbler and buy rubber sheet from him. Then do your own cut to size. $160 for the mechanism is kill man set fire. $200 onwards can get a brand new toilet bowl set (China brand of course). 1 Link to post Share on other sites More sharing options...
Jman888 Moderator January 16, 2015 Share January 16, 2015 Lame idea, go to your neighbourhood cobbler and buy rubber sheet from him. Then do your own cut to size. $160 for the mechanism is kill man set fire. $200 onwards can get a brand new toilet bowl set (China brand of course). stay condo must markup 50% more 1 Link to post Share on other sites More sharing options...
Ender Hypersonic January 16, 2015 Share January 16, 2015 Most diy shop sells the mechanism for less than $20. Can change your self if you're a handy man, the plunger is cut to size to fit different cistern. 1 Link to post Share on other sites More sharing options...
Alpha78 6th Gear January 16, 2015 Share January 16, 2015 stay condo must markup 50% more Bollocks man! I tried to source for replacement valve for my leaky toilet bowl, and the neighbourhood shop asked for $60 for the valve, some more it's the old fashioned lever type, not the newer press button type which is easy to find. Ended up I used silicone to "reconstruct" the valve seal rubber, and it lasted for quite a while more. 2 Link to post Share on other sites More sharing options...
Kangadrool Supersonic January 16, 2015 Share January 16, 2015 (edited) Normally, it's the joint areas that is causing the leaking problem. For example, many char boh langs like to put those toilet cleaning chemicals/agents inside the cistern. This makes the storage too clean, As all the slimes are cleaned and flushed away, leaking will occur. In short, don't make it too clean since 99.99999999% of the cisterns are not transparent kind and you won't have the luxury to admire it's internals! (I have not seen a clear acrylic type before). What I do is use those white pipe tapes PTFE to seal the joint areas; and it works. Costs 40 cents per roll in neighbourhood hardware shops. Same analogy applies to car engines. Many people like to chemical flush their engines. DON'T!!! It will do more damage than good. Dug out old thread. Same thing, toilet Cistern leaking. Problem is, my cistern is those designer brand (Gustavsberg) which the developer installed when the condo is built. Long story short, the authorised supplier charge a whopping $160 for a new set of mechanism. My mechanism is fine, it's the rubber seal which is leaky, but the seal is those ball type kind, which cannot be found in typical neighbourhood hardware shop. Any idea where can i find plumbing shops (other than the distributor) to buy the rubber seal? Edited January 16, 2015 by Kangadrool 1 Link to post Share on other sites More sharing options...
Shull Turbocharged January 16, 2015 Share January 16, 2015 Lame idea, go to your neighbourhood cobbler and buy rubber sheet from him. Then do your own cut to size. $160 for the mechanism is kill man set fire. $200 onwards can get a brand new toilet bowl set (China brand of course). The seal is not flat kind.. rather it's round like a ball.. If i can DIY, i would've done it looong time ago.. Link to post Share on other sites More sharing options...
Kb27 Supersonic January 16, 2015 Share January 16, 2015 The seal is not flat kind.. rather it's round like a ball.. If i can DIY, i would've done it looong time ago.. Depend whether it can fit. If you're looking for tank to bowl gasket. This one fits my old hdb one. http://www.amazon.com/gp/product/B000BQRQ3W/ Link to post Share on other sites More sharing options...
Strat 6th Gear January 16, 2015 Share January 16, 2015 The seal is not flat kind.. rather it's round like a ball.. If i can DIY, i would've done it looong time ago.. looks like is a unique rubber part for your cistern you can bring this and try to ask Garlin (shop specialists in rubber seals) at Towner road. if they don't have, most likely you would need to buy the whole mechanism from the AD.. Link to post Share on other sites More sharing options...
Volvobrick Hypersonic January 16, 2015 Share January 16, 2015 Leaking cistern is a more common problem than I thought! I have one leaking one-piece type for months.... still searching for the replacement part! And I can't swap out this bast@rd with after market system as it is one-piece design. Link to post Share on other sites More sharing options...
Count-Bracula Twincharged January 16, 2015 Share January 16, 2015 DIY is one thing but when done wrongly *touch wood* the leaky cistern will become more leaky Link to post Share on other sites More sharing options...
Lala81 Hypersonic January 16, 2015 Share January 16, 2015 My cistern is leaking from the side outside. Any ideas? Link to post Share on other sites More sharing options...
Opel17 6th Gear January 16, 2015 Share January 16, 2015 My cistern is leaking from the side outside. Any ideas? Please show some pictures so that we can offer some suggestions. 2 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic January 16, 2015 Share January 16, 2015 My cistern is leaking from the side outside. Any ideas? Overflow? 2 Link to post Share on other sites More sharing options...
Angchug 3rd Gear January 17, 2015 Share January 17, 2015 Mine is a Swiss brand and after 10 years started giving me problem. I went shopping looking for a replacement. OMG cost $1000++++ In the end I went to the hardware shop and bought a few cistern. Got a workshop to make me some plates. DIY and cost me only $37 per modification/bowl. No rocket science. Just DIY Link to post Share on other sites More sharing options...
Naimed 5th Gear January 18, 2015 Share January 18, 2015 The seal is not flat kind.. rather it's round like a ball.. If i can DIY, i would've done it looong time ago.. Tried to look for the Gustavsberg brand every where as well, even big distributors at IMM and Balestier don't carry it. Firstly, it depends on the water leak is inside the bowl (rubber seal) or externally (float). We have 2 cisterns leaking so the plumber change the float valve (Fluidmaster brand 400UK073 - direct replacement) for $90 each. He replaced the rubber seal with an older spare piece for free. DIY rubber seal can get for $12 at hardware shop, they come in multiple rubber rings/washers in different diameters to match the the shape of the original seal. ↡ Advertisement Link to post Share on other sites More sharing options...
Toilet ceiling leaking
Neutral gender bathroom
Help: ceiling n wall cracks are leaking water
Lobang to change toilet sink faucet
In Tokyo, public toilets are works of art
Toilet Bowl Advice
Toilet Bowl Advice
