Count-Bracula Twincharged July 9, 2020 Share July 9, 2020 1 minute ago, Kangadrool said: Now many contractors steal labour reduce materials, doing away with this control valve. I inspected and made them re-do all. LOL. Good! These lazy buggers trying to potong jalan. TMDG! ↡ Advertisement Link to post Share on other sites More sharing options...
JanM 2nd Gear July 9, 2020 Share July 9, 2020 53 minutes ago, Count-Bracula said: Leaky cistern and tap really very ma fan one. I made a big mistake in my house reno. For every water outlet, there must be a control valve before it. This is to facilitate changing of leaking tap, don't have to outside flat to turn off mains. for toilet cistern, the control valve is quite easy to retrofit. what I regret not doing was install surge reservoir before the washing machine. now the whole pipe network knocks each time the washing machine stops the flow of water. 1 Link to post Share on other sites More sharing options...
Count-Bracula Twincharged July 9, 2020 Share July 9, 2020 47 minutes ago, JanM said: for toilet cistern, the control valve is quite easy to retrofit. what I regret not doing was install surge reservoir before the washing machine. now the whole pipe network knocks each time the washing machine stops the flow of water. Ohh? Surge reservoir? That's new to me. I go google. Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged July 9, 2020 Share July 9, 2020 5 hours ago, Count-Bracula said: Leaky cistern and tap really very ma fan one. I made a big mistake in my house reno. For every water outlet, there must be a control valve before it. This is to facilitate changing of leaking tap, don't have to outside flat to turn off mains. My BTO place has a main valve before every single tap or water outlet. Factory stock, no mods 😂😂😂 1 Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged July 9, 2020 Share July 9, 2020 @Mustank boss, what type of cheap cheap grease do you use for the flush valve flapper? I went to a hardware shop just now. Valvoline EP2 lithium grease $14 for 500g. Another no brand general purpose grease was $4 for 500g. Checked it's mineral oil based so I did not buy. Both are read. Can shed some light on the grease you are using? Link to post Share on other sites More sharing options...
Mustank Hypersonic July 9, 2020 Share July 9, 2020 33 minutes ago, Beehive3783 said: @Mustank boss, what type of cheap cheap grease do you use for the flush valve flapper? I went to a hardware shop just now. Valvoline EP2 lithium grease $14 for 500g. Another no brand general purpose grease was $4 for 500g. Checked it's mineral oil based so I did not buy. Both are read. Can shed some light on the grease you are using? Bro, don’t bother with the grease Liao because not very useful buy the silicone ring instead, not expensive but you must know the size For example: fu至内容₴6T4W1CLteBB₴达开👉τa0寳👈或点几链街https://m.tb.cn/h.Vr9SI7r?sm=b3b31f 至浏.览览.器【马桶水箱配件排水阀拍盖胶垫片冲水器止水拍板密封圈硅胶垫圈胶片】 the search word is: 马桶胶垫 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic July 9, 2020 Share July 9, 2020 But if you really want do grease, have to use high quality plumber grease example: Weld-On 80427 Clear Slik Seal Plumbers Grease 1 oz. Tin https://www.amazon.com/dp/B00KBPE032/ref=cm_sw_r_cp_api_i_ezUbFbC1K55EZ ↡ Advertisement 1 Link to post Share on other sites More sharing options...
In Tokyo, public toilets are works of art
Toilet ceiling leaking
Neutral gender bathroom
Help: ceiling n wall cracks are leaking water
Lobang to change toilet sink faucet
Toilet Bowl Advice
Toilet Bowl Advice
