Nismoblack76 Neutral Newbie September 15, 2009 Share September 15, 2009 any lobang to get the radiator fan fix???its wrking if i on the air con but certain time the temp just shot up ...scary sia... ↡ Advertisement Link to post Share on other sites More sharing options...
Rev2redline Neutral Newbie September 15, 2009 Share September 15, 2009 if you never on the air con, the fan will only activate when the temperature is hot enough... maybe your fan is dying, and you should check with your mechanic... it's not good to have overheating problems in your car as it may affect other items such as head gasket... no use delaying your replacement of the radiator fan and having to fork out more if a top overhaul is required.. you can check the cost price at a parts supplier and bring it to your preferred mechanic to install for you if you want... Link to post Share on other sites More sharing options...
Kyojin 1st Gear September 15, 2009 Share September 15, 2009 any lobang to get the radiator fan fix???its wrking if i on the air con but certain time the temp just shot up ...scary sia... the air con fan is different from the radiator fan (usually). but it helps to draw air through the radiator and air con condenser. you should just go to any trusted workshop to check it out. could be simply a loose wiring. but as the bro said, u need to get it fixed asap. don't want to be melting stuff - could result in costly bills. Link to post Share on other sites More sharing options...
Nismoblack76 Neutral Newbie September 17, 2009 Author Share September 17, 2009 thanks guys for the advise ...will do that asap....cheers njoy ur holiday aite Link to post Share on other sites More sharing options...
Rev2redline Neutral Newbie September 17, 2009 Share September 17, 2009 Actually, there are some cars that share a main fan for both radiator and aircon... my ride's using a single fan for both radiator and air con, that's why when i went to the mechanic, i was advised to leave the air conditioning on to check on the life of the radiator fan... the radiator fan will only turn on at random times, when the coolant temperature is high, especially during idle and start stop traffic.. i do agree some cars have seperate fans, but i guess manufacturers nowadays adopt the single fan due to space constraints and lesser parts to maintain... cheers.. Link to post Share on other sites More sharing options...
Raindanze Neutral Newbie October 24, 2009 Share October 24, 2009 changed mine @$90, motor only i.e. blade and hiusing use back teh old one. Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie October 24, 2009 Share October 24, 2009 (edited) Not so true. Toyota cars (mid sized) saloons have 2 Fans. 1 for the Radiator and the other for the A/C. Both will be turned on when A/C cut in and off when A/C cut out. However, if the engine temp goes higher, the Radiator Fan will remained on regardless of the A/C fan cutting in or out. It all depends on Mfg design and engine sized. I personally felt that 2 Fans design are my liking. 1 for A/C and 1 for radiator. Cos if its a 1 fan type, then this fan is very hugh and will runs at higher RPM when its working which translate to vibration in the cabin which I dislike. Not forgetting the noise it produce which bystanders will looked at you when you stopped at the lights. Edited October 24, 2009 by Godfinger ↡ Advertisement Link to post Share on other sites More sharing options...
Radiator Cap
Radiator Cap
Ang Mo Kio junction to be turned into temporary roundabout for North-South Corridor works
Traffic junction without traffic lights
Traffic accident deaths in Singapore spiked by 58% in first half of 2023
No more walk-ins: Traffic e-Appeals Portal is only way to submit appeals
Complex Braddell-Upper Serangoon-Bartley road junction to be simplified
My date with Traffic Court, Court 21
