Tohto Hypersonic September 14, 2009 Share September 14, 2009 Need some advise here. Bought a set of spark plug and may had got the wrong heat range, what is the side effect if the spark plug I used was too hot. ↡ Advertisement Link to post Share on other sites More sharing options...
Hamburger Hypersonic September 14, 2009 Share September 14, 2009 (edited) centre electrode will disintegrate n cost misfiring. Not worth e try esp running on NSW Edited September 14, 2009 by Hamburger Link to post Share on other sites More sharing options...
Freifeit Neutral Newbie September 14, 2009 Share September 14, 2009 Need some advise here. Bought a set of spark plug and may had got the wrong heat range, what is the side effect if the spark plug I used was too hot. It may cause detonation (engine knocking), i.e. the air/fuel mixtures ignites before the spark plug fires cause by hot spark plug.. just my 2cts. Link to post Share on other sites More sharing options...
Trex101 3rd Gear September 15, 2009 Share September 15, 2009 Depends on how hot or wrong spec you bought. Most cars can run between a certain heat range base mostly on driving condition, for example, if your car call for BKR6E-11 and you bought BKR5E-11(1 heat range hotter), it will still be fine and in fact provide better combustion cleanliness if it's mostly city driving but might cause detonation/pinging under heavy load or high speed driving. If you drive like crazy and rev the hell out of your motor then BKR7E-11 which is 1 grade colder would also be suitable. So, it all depends mostly on your driving condition and application, there's no 1 size fit all plugs, just the most suitable in that condition . Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie September 17, 2009 Share September 17, 2009 Hi Trek, may I side track abit, do you happen to had any link that provide a Cross-Ref table on all the plugs Part number. I tried to search in the resource folder but could not return any results. Thanks. Link to post Share on other sites More sharing options...
Trex101 3rd Gear September 17, 2009 Share September 17, 2009 Hi Trek, may I side track abit, do you happen to had any link that provide a Cross-Ref table on all the plugs Part number. I tried to search in the resource folder but could not return any results. Thanks. There's no x-ref link but what part number are you trying to cross? Just post it here, maybe i can help. Link to post Share on other sites More sharing options...
Genie47 1st Gear September 17, 2009 Share September 17, 2009 You can get away if you gap them smaller. So if the plugs use 1.1mm, push down to 0.9mm. You will not have a lot of power but the plugs will last longer and won't blow themselves to smithereens. Link to post Share on other sites More sharing options...
Windchoco 1st Gear September 17, 2009 Share September 17, 2009 Hi, how to tell if your spark plug is due for change ? Will feel anything during driving or FC will drop? Asking bcos my service manual is all "inspect" only, dun have "replace" at any servicing interval Link to post Share on other sites More sharing options...
Yeobh 4th Gear September 17, 2009 Share September 17, 2009 Just google and all the infos will be in front of you in no time. Link to post Share on other sites More sharing options...
Darkblue 1st Gear September 17, 2009 Share September 17, 2009 Rule of thumb is Copper -> 20K change Rest I not sure, because I don't use fancy spark plugs.. if ain't broke don't fix it, I use back Copper plugs Link to post Share on other sites More sharing options...
Trex101 3rd Gear September 17, 2009 Share September 17, 2009 Rule of thumb is Copper -> 20K change Rest I not sure, because I don't use fancy spark plugs.. if ain't broke don't fix it, I use back Copper plugs It also depends on how demanding is your ignition system. Like for my car which is dual fuel, i need fine wire plugs for it's lower voltage advantage to create sparks, if not the demand on the ignition system would be too high and might fried or shorten the ignition coil. Even with fine wire plugs, we still have to gap the plugs smaller(~0.2-0.3mm) for ignition coil longevity. Link to post Share on other sites More sharing options...
Yeochris Clutched September 17, 2009 Share September 17, 2009 just a Qs about spark plug... if my ride fuel too rich... how does the plug look like at the tip? Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged September 17, 2009 Share September 17, 2009 just a Qs about spark plug... if my ride fuel too rich... how does the plug look like at the tip? black and sometimes, wet looking... Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged September 17, 2009 Share September 17, 2009 (edited) Hi, how to tell if your spark plug is due for change ? Will feel anything during driving or FC will drop? Asking bcos my service manual is all "inspect" only, dun have "replace" at any servicing interval one of the sign is the the gap of the sparkplug... that is also why if you know how to do regaping of sparkplug, most sparkplug can last u very very long... Edited September 17, 2009 by Tigershark1976 ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Tool to change Spark Plug
Right side speakers no sound
Need Advice On Honda Fit 2008 (GE) Side Mirror Repair
Plug-and-play vaccine
Spark Car Care
Spark Car Care
Herbal tonic wine (any side effects?)
