Idiotboi89 Neutral Newbie September 13, 2009 Share September 13, 2009 Hi bros, in this case.. could a oxygen sensor be still good for a car that is 15-16 years old? a B13 Nissan sunny..Manual The car's good for another 10 year at least in its condition, was just wondering what can i do to ensure the car is given the love it needs =) ↡ Advertisement Link to post Share on other sites More sharing options...
GoodCar 4th Gear September 13, 2009 Share September 13, 2009 They said local petrol quite clean, so far their customer didn't need fuel filter replacement... I do remember when I driving a carburattor engine car, the fuel filter is semi-transparent in the engine bay, easy to replace. After changing I shake the old filter to see if its dirty, surprising its clean, no sediments or dirt inside. If you know what to look out for, good for you lah. For those not sure, better change, you don't want to run into a situation one day where suddenly your engine die on you due to fuel starvation. Lucky you only driving the car, if aeroplane engine die in air then become glider liao.....hehe. Link to post Share on other sites More sharing options...
Byond 1st Gear September 13, 2009 Share September 13, 2009 hello... just to check, so does the universal sensor fits into ur ride? Link to post Share on other sites More sharing options...
Mit81 Clutched September 13, 2009 Share September 13, 2009 i change mine, as error code 0420 was detected. mileage abt 85k Link to post Share on other sites More sharing options...
Tohdj Neutral Newbie September 14, 2009 Author Share September 14, 2009 update: got the sensors installed. working well now. Link to post Share on other sites More sharing options...
Jimny09 Neutral Newbie February 6, 2010 Share February 6, 2010 hi. may i know how much is reasonable to change an O2 sensor at workshop? one quoted $360. car is Suzuki Jimny. tks! Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged February 8, 2010 Share February 8, 2010 Is there such thing as a universal catalyst convertor? hahaa.... there is... depends on your ride... those car like altis and vios cat converter design is relatively simple and can be replace with aftermarket sports cat converter. where some korean car's cat convertor come in 1 piece with the extractor, you need to change it with extractor all together.. pls note that even there is an aftermarket replacement, whether its LTA friendly or not its another thing... Link to post Share on other sites More sharing options...
Joemit7850 1st Gear October 15, 2010 Share October 15, 2010 my O2 sensor was detect spoilt today also, anyone know where can i get reasonable cost for Swift 06 model? i heard the defect will cos the car become more hungy for fuel and less powerful. beside this will they cos other problem Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged October 15, 2010 Share October 15, 2010 my O2 sensor was detect spoilt today also, anyone know where can i get reasonable cost for Swift 06 model? i heard the defect will cos the car become more hungy for fuel and less powerful. beside this will they cos other problem how do u know that your O2 sensor was defective??? you may want to provide more details? im not too sure how mush does the swift O2 sensor cost, would suggest you check it out from swift / suzuki forum for more details. The members there should have more info. Link to post Share on other sites More sharing options...
Joemit7850 1st Gear October 16, 2010 Share October 16, 2010 how do u know that your O2 sensor was defective??? you may want to provide more details? im not too sure how mush does the swift O2 sensor cost, would suggest you check it out from swift / suzuki forum for more details. The members there should have more info. while driving yestersay, there was a light beside the RPM came out therefore i drove to my WS and they use a handheld system to check and cancel away the light, he say likely is the O2 sensor but ask me to monitor for the new few driver.. i can't find suzuki forum since early this year, you have their new www? Link to post Share on other sites More sharing options...
Joemit7850 1st Gear October 16, 2010 Share October 16, 2010 (edited) dbl post Edited October 16, 2010 by Joemit7850 Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged October 17, 2010 Share October 17, 2010 while driving yestersay, there was a light beside the RPM came out therefore i drove to my WS and they use a handheld system to check and cancel away the light, he say likely is the O2 sensor but ask me to monitor for the new few driver.. i can't find suzuki forum since early this year, you have their new www? u r rite, www.sgsuzukiclub.com seems to be down... u may want to try your luck at http://www.swiftclubsg.com/forumv1/ instead... what the workshop did is correct. sometimes, the error code may be false alarm... u may monitor for some time until the checklight came out again b4 u do something.. Link to post Share on other sites More sharing options...
Hermit 1st Gear October 17, 2010 Share October 17, 2010 U might be right.. But to be sure yourself, it will be good if u see for yourself wad code was thrown for the CEL. There might be other factors spoiling the O2,eg bad cat; or may juz be wear n tear.. FYI, I changed my O2 for my 06 subaru last year n nothing come back since. Good luck. Link to post Share on other sites More sharing options...
Joemit7850 1st Gear October 17, 2010 Share October 17, 2010 U might be right.. But to be sure yourself, it will be good if u see for yourself wad code was thrown for the CEL. There might be other factors spoiling the O2,eg bad cat; or may juz be wear n tear.. FYI, I changed my O2 for my 06 subaru last year n nothing come back since. Good luck. i hope i am rite cos my fc have been ridiculous low ever since after i had did my servicing. usually full tank at least 400km but now 320km low fuel light start come out Link to post Share on other sites More sharing options...
Joemit7850 1st Gear October 17, 2010 Share October 17, 2010 u r rite, www.sgsuzukiclub.com seems to be down... u may want to try your luck at http://www.swiftclubsg.com/forumv1/ instead... what the workshop did is correct. sometimes, the error code may be false alarm... u may monitor for some time until the checklight came out again b4 u do something.. thanks at last i found the web Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 18, 2010 Share October 18, 2010 If the shop has a HC C0 gas analyser, the nmech can easily confirm whether it is the lambda sensors or other fuel related problem. Yr feedback on fuel consumption is a good indicator that the lambda sensors are not switching from open to close loop when the engine warm up to operating temp. If the exhaust CO is very high when the engine temp it up to operating temp then the cause can be due to faulty lambda sensors. PS By measuring the exhaust pipe temps with a non contact thermometer before and after cat , the different can als0 be used to diagnose fault lamdba sensors Link to post Share on other sites More sharing options...
Tlks Clutched July 26, 2011 Share July 26, 2011 i had my O2 sensor spoilt too. went to stamford tyre to check diagnosed and they confirmed. quoted me $270 each.. after sourcing around in the net, i found out there is a second hand shop selling at $50 each only. without installation.. Link to post Share on other sites More sharing options...
Satria_neo Clutched July 26, 2011 Share July 26, 2011 i had my O2 sensor spoilt too. went to stamford tyre to check diagnosed and they confirmed. quoted me $270 each.. after sourcing around in the net, i found out there is a second hand shop selling at $50 each only. without installation.. $270 for an O2 sensor is really expensive!! Esp. since stock O2 sensors are narrow range ones and is generally cheaper than wide range sensors. ↡ Advertisement Link to post Share on other sites More sharing options...
Replacing fuel filter
Home oxygen generator
Replacing GPS software on DVD WINCE 6.0
Experts advice needed : O2 sensor or MAF sensor?
Reverse sensor
Reverse sensor
Replacing a watch battery - it pays to check
Replacing Main door lock
Reverse sensor or camera to recommend
