Niltrams 3rd Gear August 28, 2009 Share August 28, 2009 Hi Starlets, I'm on a Weber. When I'm cornering hard LEFT, with the clutch engaged, the engine will have a very noticeable stutter and jerk, making the subsequent acceleration less responsive. With the clutch disengaged (free wheeling), the engine dies off, which is pretty dangerous cos I lose the power steering. Seems as though the carb is starved of petrol in the float when cornering left. This does not apply if I'm cornering right. Do any of you guys on Webers experience this scenario? Is it due to the orientation of the carb in my car? Your reply is greatly appreciated =) ↡ Advertisement Link to post Share on other sites More sharing options...
Kyojin 1st Gear August 28, 2009 Share August 28, 2009 do u have a pic of ur engine bay? i'd like to see how ur weber is mounted. it makes a difference. Link to post Share on other sites More sharing options...
Niltrams 3rd Gear September 6, 2009 Author Share September 6, 2009 (edited) Hi.. the pic may not show it clearly, but the orientation of the weber is such that it is " | " instead of " -- " . . . Thanks! edit: added an inverted color foto for better visibility Edited September 6, 2009 by Niltrams Link to post Share on other sites More sharing options...
So_nice 6th Gear September 6, 2009 Share September 6, 2009 looks abt the same as mine. so far no such problems. why not bring back to the installer? or a mech. Link to post Share on other sites More sharing options...
Swiftboi Neutral Newbie September 6, 2009 Share September 6, 2009 mine oso got tis problem...... when hard cornering...... the car began to shift one side like some angle tat makes the webber suffer lose of air. webber need the balance the air n fuel mixture. I know tat too much fuel will makes the webber hard start properly. i had try before try stepping on gas pedal few times before starting sure hard to had one crank startup. need to start and step on (holding togather movement) gas pedal to let the air suck in more, too much fuel like choke the webber that casue hard to breath. Ned to confirm with more starlet kakis who got encounter tis problem so far Link to post Share on other sites More sharing options...
Starletgt Neutral Newbie September 7, 2009 Share September 7, 2009 EFi la Link to post Share on other sites More sharing options...
Kyojin 1st Gear September 7, 2009 Share September 7, 2009 ok, with this pix, we eliminate the first problem. coz if you put the float transversely, it will definitely affect when you are cornering one way. it's a common problem with the Fiats that run Weber DCNF. but since your carb is mounted longitudinally this isn't the problem. which brings us to the next possibility that your float level is incorrect. this works the same way as your toilet bowl cistern where the fuel will stop flowing into the chamber when you have enough reserve petrol there. you can adjust the float level to prevent the carb from over flowing. have this checked. sounds like you are having a overly rich problem, so when you corner, the petrol "overflows" into the emulsion tube and causes your car to stutter and even die off. meaning your float level is too high. set it a bit lower. at the same time check that the float is not rusted. coz if it's rusted, petrol will go into the float and make it useless. ↡ Advertisement Link to post Share on other sites More sharing options...
Hard to engage in 1st gear after transmission oil change
Hard Rock, Soft Rock, Metal... who are the greatest 10?
SG Hard Truth by Prof Tommy Koh
Who Says Conti Car Metal is Hard
Hard rubber mats
Hard rubber mats
How to improve handling and Stability of the Car
External Hard Disk - Reliable
Is non-power steering car hard to drive?
