Ultra Racing Strut Bar WHAT IS THIS ??????
Michiko
Struts bars just transfer the stress onto other parts of the car.
Cars are designed to flex for a purpose. Those with rear lower tie bars will note that after about 5 years, with heavy driving, the rear joint holding the bolts start to crack.
Yes strut bars give better handling but at the expense of a shorter lifespan of your car chassis.
Trackies want the handling, not all understand the cons of it.
So you have to decide if strut bars are something you need, or just something flashy u want to shop for.
Just like girls, all guys like to shop too. even if its just window shopping at accessories shops. :)
Under hard driving even if your tie bar joint doesnt crack, your wheel bearings and such will also wear and tear.
Strut bars wont affect sillypore car users in any big way in terms of extra wear and tear. Our cars are only here for 10 years.
People who go track will go for stiffer bar and brace, normal driver who like high speed cornering will also like to install 1. 3 year later sell the car and the new owner will feel the problem. some new car do come with sway bar and strut bar its just they are not very hard setting. I dun mind go for a good candy bar, they do feel diff in handling. Ofcourse every thing come with price. Try driving a subaru Legacy, with stock setup the car is very stable liao.
Turbocharged
IMO, strut bars only gave very minor improvements in handling...if you really want to cut down body roll significantly, then coilovers is the way to go..
Coilover is good, but the rear passenger backside will pain. My friend mum say: Boi ah! your car spoil huh? how come so hard when go over the hump?
Will leh, SHC tt time got one post, Honda Civic ES model after 4 years, the lower tie end joints cracked.
strut bars dun go for the carbon fibre type, cos by right it should be as firm as possible so to deliever the load from one place to the other... imho, strut bars work hand in hand wif anti roll bars for ur whole car to be stable enough...
Did you scroll down the page you linked? There is a short description of what a strut bar does.
Ultra Racing is a Malaysian brand. I am using a number of their products to stiffen my ride and it does work well in chassis stiffening. Other brands in the market include: Carbing, Alutech, Cusco etc.
strut bar basically stiffens the ride.....and its good for high speeds..but not so much for comfort....maybe for girls who want comfort
strutbars might help but not significant...
coilover should be better...
in term of handling, safety and stability,
-> increase rims size, better tyres grip and better suspension are the main factors..
didn't know all these chocolate bars will have "side effect" later on.
iam getting abit worried as i got quite a few of these chocolate bars on my car chassis. [sweatdrop]
Some cars came stock with struct bar. At least KM's Honda Accord is one of them. I doubt the joint will crack that easily if the correct bushing and maintenance is performed. If you have coilover and you lower the car damn low, you have a higher chances of your bottom chassis hitting high humps and bumps.
If one is serious about the joint issue, they could have gotten the mechanic to reinforce the joints if they want to. There is a choice.
Regards,
It should not affect your ride if you take proper maintenance.
Regards,
Hi 'Kelpie', some cars come stock with the rear undercarriage anti-roll bar but not strut bar. These stock rear undercarriage anti-roll bar are relatively thinner in diameter and flexes easily.
That is why car owners who have stock rear undercarriage anti-roll bar will upgrade to a stronger and thicker diameter one. I was in a specialist workshop recently and noticed that an owner of a brand new Audi A4 even have their stock bars changed to thicker ones.
Hi 'Yuan', you did not mention how what are the components that you have installed. There are many parts to make the chasis rigid depending on the car model. If one will to install all such as engine top strut bar, front undercarriage brace, front fenders brace, rear strut bar in the boot, rear undercarriage brace, rear undercarriage anti-roll bar, etc, the car body will be very rigid as all the body parts are in a way anchored to one another.
This would ultimately make the car very stiff and very rigid especially going over humps and passengers in the car will feel very uncomfortable just like a roller-coaster ride.
It is therefore very important to know what you want and just install the essential bars and braces.
I would suggest that for those who have not installed such bars and braces and what to try out, I would suggest to install the rear undercarriage anti-roll bar first. You will feel instant strengthening at the rear and get use to it for at least 2 weeks and therafter, the front top strut bar.
It's good to read the various functions of each bar or brace before installing them.
Generally speaking and from my personal opinion, installing the front and rear undercarriage braces will make the car rather stiff as the front and rear suspensions are anchored onto the body. This will result in the ride rather stiff and bumpy.
