How to Reduce Groin Abrasion?
Baka
I have started training hard for the marathon end of year but realised that everytime I run more than 5km, I will have abrasion in upper thighs close to the groin area.
I remember in army days people told me wearing bicycle tights will help to reduce this but I have yet to try. Any other suggestions (like medicine applications, etc)?
Hope experienced marathon runners here can offer tips so I dun have to walk like a crab after each run, thanks.
This works for me: OpSite dressing. It is a clear adhesive film.
There is also a spray-on version (which must be applied well before you have any abrasions). If the skin is already broken and you spray it on, you will feel like you set your balls on fire.
better shorts and underwear?
go pharmacy and have a look at those cream for babies' nappy rash. i used them during ict when out in the field without shower for 3~4 days. Helps alot! even soothe the affected areas if forgot to put. there are many brands...best is to try those UK made ones
abrasion is caused by loose clothing or skin to skin. so the solution is yes, bicycle shorts. it must be tight such that the cloth do not rub against ur skin.
Go & buy the most oily body lotion. Put it on ur upper thigh. It helps. I used it for past 4 yrs. By the way, don't forget to oil ur nipple. Nipple abrasion is worse than thigh abrasion.
Bike shorts is the way to go. effective and prevents chaffing too. Dun forget nipple shields too. Yes Opsite dressing can be used but it is very drastic and pretty painful to rip off, all your hair will be ripped out with it.
I think vaseline for a marathon session is a great idea! [:p]
But for running I just dap a bit of hazaline snow on the thighs.
Nice and cool, keeps dry and not oily!
Is there really such a thing as nipple abrasion?
this is not the 1st time i heard of liao haha.
How do u get it??
try applying vaseline
Yes, vaseline is the best. Apply generously around the groin region. Other possible regions prone to abrasions are the armpits and the nipples.
How do u get it??
kana before, when you clothing is quite loose and you run, then the clothes will sway to and fro rubbing against your nipples on the way
rub rub rub at the end of the day nipple becomes abrasioned.
very painful AFTER your run when u go into the shower.. wow feels like nips on fire. [bounce1][bounce1]
anyway dun say nipple abrasion, even butt also can get abrasion when the butt cheeks rub against each other too much..
haiz guess fat ppl like me easier to get
