Weber DCOE 45
Guan73
fitment is very tight as the space between the engine and firewall is quite narrow. need some modifications to the car body. also, 45 is probably too large for anything smaller than 1.6L
best to go with DCNF 40, there are more pple with jettings and parts available in town.
Thank you so much for your info bro.
How to check if a weber carb is still working well or what do I need to check before I buy a used carb?
Eg like a used carb attached....
if getting second hand and you don't know its history, you should get a rebuilt kit from ebay. the pump diaphragm (would tear) and floats (punctured with rust holes) are two components that get faulty more often than the other parts. you should look for clogged jettings, veturi pipes, etc. you need to get new gaskets too.
