Orangepineapple Clutched July 16, 2009 Share July 16, 2009 When using aircon while driving, do you use Fresh air or Circulated air?? what are the pros and cons of each? i find that when very hot, using circulated air the aircon would be colder. whats your preference?? ↡ Advertisement Link to post Share on other sites More sharing options...
Tas0577 1st Gear July 16, 2009 Share July 16, 2009 When using aircon while driving, do you use Fresh air or Circulated air?? what are the pros and cons of each? i find that when very hot, using circulated air the aircon would be colder. whats your preference?? I have sealed up the circulated vent inlet so no more outside air anymore as you know that when you close the circulation vent, there will be around 10% of the outside air coming into the cabin. Singapore air are full of exhaust fumes so how to have fresh air from outside if you open up the circulation vent. Link to post Share on other sites More sharing options...
Blueray Hypersonic July 16, 2009 Share July 16, 2009 circulated air. once fumes from buses, lorries etc get into the car the smell is terrible. Link to post Share on other sites More sharing options...
Orangepineapple Clutched July 16, 2009 Author Share July 16, 2009 I have sealed up the circulated vent inlet so no more outside air anymore as you know that when you close the circulation vent, there will be around 10% of the outside air coming into the cabin. Singapore air are full of exhaust fumes so how to have fresh air from outside if you open up the circulation vent. wa, i din know that. you even went to seal up the vent Link to post Share on other sites More sharing options...
Tas0577 1st Gear July 16, 2009 Share July 16, 2009 circulated air. once fumes from buses, lorries etc get into the car the smell is terrible. Even if you close the circulation vent, there will be some exhaust fumes coming into the cabin as all new air-con system are running by electronic control compared to the older vehicles which are running by cable, they will have allow less outside air coming in. Link to post Share on other sites More sharing options...
Tas0577 1st Gear July 16, 2009 Share July 16, 2009 wa, i din know that. you even went to seal up the vent If you check with those air-con specialist like Tomika or Mark Cool regarding this, they will tell you the same thing also. After sealing the inlet, I have no worries when driving behind a rubbish truck. Link to post Share on other sites More sharing options...
Peaceracer 1st Gear July 16, 2009 Share July 16, 2009 Definitely Circulated. I will only open the valve for the outside air when i am on the straight road with no cars. If there is one, i will close the valve le... Leh Che, so jus leave it in Circulated. Link to post Share on other sites More sharing options...
Kb27 Supersonic July 16, 2009 Share July 16, 2009 If you're driving on MY highway, you might want some fresh air. If you're driving on SG roads, definitely recirculated air. Link to post Share on other sites More sharing options...
Winfong Neutral Newbie July 16, 2009 Share July 16, 2009 Btw, How do you seal the inlet? DIY or Shop? Want Fresh air.... Why not Just Wind down The window.... har har har >_< Link to post Share on other sites More sharing options...
Fireball0088 5th Gear July 16, 2009 Share July 16, 2009 I have sealed up the circulated vent inlet so no more outside air anymore as you know that when you close the circulation vent, there will be around 10% of the outside air coming into the cabin. Singapore air are full of exhaust fumes so how to have fresh air from outside if you open up the circulation vent. How did you seal up the circulated vent? Link to post Share on other sites More sharing options...
Tas0577 1st Gear July 16, 2009 Share July 16, 2009 Btw, How do you seal the inlet? DIY or Shop? Want Fresh air.... Why not Just Wind down The window.... har har har >_< Just drive to the air-con specialist or your agent if your car is still under warranty, they will help you to seal the inlet. Link to post Share on other sites More sharing options...
Thestig Clutched July 16, 2009 Share July 16, 2009 Mostly recirculated air but on the long NSHW drives, I have to make a conscious effort to switch to fresh air every half hour or so. I once forgot to do so on a no-stop drive back from KL and left it on circulate, felt tired until I switched over to fresh air. Every car should be equipped with an in-cabin oxygen meter. Link to post Share on other sites More sharing options...
Orangepineapple Clutched July 16, 2009 Author Share July 16, 2009 what if you buy durians and put in the car and the car full of durian smells? will opening up the vent clear up the smell faster? my experience: helps a bit Link to post Share on other sites More sharing options...
Orangepineapple Clutched July 16, 2009 Author Share July 16, 2009 wind down then not cool already ma.. haha wanna fresh air and cool air at the same time you ai pee you ai qii you ai dua lip ni Link to post Share on other sites More sharing options...
Pcslim Neutral Newbie July 16, 2009 Share July 16, 2009 I have sealed up the circulated vent inlet so no more outside air anymore as you know that when you close the circulation vent, there will be around 10% of the outside air coming into the cabin. Singapore air are full of exhaust fumes so how to have fresh air from outside if you open up the circulation vent. No wonder somtimes I can still smell the exhaust even after switched to circulated air. Link to post Share on other sites More sharing options...
Watwheels Supersonic July 16, 2009 Share July 16, 2009 Air con by design is recirculating the air, in the case of a car by recirculating the air cools faster and the compressor dun have to work so hard when it reaches the preset temperature. In a way it improve a bit on FC. Some a/c are program to switch to outside air for a while to dilute the CO2 in the cabin of your car otherwise you will feel tired and nausea after some time. Those whose children have hyperventilation is better they switch to outside air more often. It's good to let in some fresh air or outside air if you are on a long drive or in your car for too long. Car cabin space is very small and if you have a lot of passengers the concentration of CO2 build-up very fast. In my room, I dun fully close my windows when I sleep with air con on. For those who shut the doors and windows tight you will find yourself pale and want to throw up in the morning. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged July 16, 2009 Share July 16, 2009 Fresh air for most of the time...unless I'm stuck in a jam. The filter is good enough to filter out the foul smells from exhaust, etc... Link to post Share on other sites More sharing options...
Route88 2nd Gear July 16, 2009 Share July 16, 2009 Circulated air,using manual for this as auto will on/off the fresh air intake which i dont like. Lorry,motobike exhaust can smell if set to fresh air circulation. ↡ Advertisement Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Car air-con
Car air-con
Car aircon check / servicing from $9.90! Edwin Garage - 100% cheapest in Town. For Conti, Japanese and Korean cars.
W212 Rear aircon vent cover replacment
Any good and reliable home aircon service to share
Looking for Job in automotive sector, need advise
