Kazuo Neutral Newbie July 8, 2009 Share July 8, 2009 How many of yours GT light still working (shining) ?? ↡ Advertisement Link to post Share on other sites More sharing options...
Whyeme Clutched July 9, 2009 Share July 9, 2009 (edited) How many of yours GT light still working (shining) ?? i guess u r referring to the rear words 'GT' being lighted up? actually it's not LTA friendly to be lighted up i believe Edited July 9, 2009 by Whyeme Link to post Share on other sites More sharing options...
Guan73 Neutral Newbie July 9, 2009 Share July 9, 2009 i guess u r referring to the rear words 'GT' being lighted up? actually it's not LTA friendly to be lighted up i believe Just change the bulb....... Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie July 9, 2009 Author Share July 9, 2009 i think the problem is many dont know what is the size? you know the size? Link to post Share on other sites More sharing options...
Guan73 Neutral Newbie July 10, 2009 Share July 10, 2009 The bulb is about 2cm long. I took out my reflector to change the bulb last time. My advise is not to change to LED as it does not last longer. Change back to the original bulb..... as shown below... Link to post Share on other sites More sharing options...
Swiftboi Neutral Newbie July 10, 2009 Share July 10, 2009 but u got lobang for tis bulb bro ? i oso want leh Link to post Share on other sites More sharing options...
Guan73 Neutral Newbie July 10, 2009 Share July 10, 2009 I do not think this bulb is difficult to find.......I will try my luck around ubi area first. Link to post Share on other sites More sharing options...
Swiftboi Neutral Newbie July 10, 2009 Share July 10, 2009 tried to find but seems nowhere....... the bulb itself got 2way copper wiring i often seen 1way copper wiring type oni the gt panel inside is 2way wiring type bro the bulb better than outside this type of bulb is so small that when u fix the bulb is seated within the bulb holder inside the panel shui shui want..... i had tried other small tiny bulb still won't seat perfectly Link to post Share on other sites More sharing options...
Guan73 Neutral Newbie July 10, 2009 Share July 10, 2009 tried to find but seems nowhere....... the bulb itself got 2way copper wiring i often seen 1way copper wiring type oni the gt panel inside is 2way wiring type bro the bulb better than outside this type of bulb is so small that when u fix the bulb is seated within the bulb holder inside the panel shui shui want..... i had tried other small tiny bulb still won't seat perfectly If you use other size of bulb and place it on the same bulb holder, then I suggest you use small wire to tie it...... or other stuff to stick it to that holder......glue.... After all u will not see the bulb when it is placed to the reflector right? Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie July 11, 2009 Author Share July 11, 2009 Got clearer picture of the bulb? Link to post Share on other sites More sharing options...
Swiftboi Neutral Newbie July 12, 2009 Share July 12, 2009 use sodering it back better it all abt D.I.Y Link to post Share on other sites More sharing options...
Swiftboi Neutral Newbie July 12, 2009 Share July 12, 2009 i will try get the pic of d bulb later....... ↡ Advertisement Link to post Share on other sites More sharing options...
Rear seat passenger : Do they belt up?
Is it illegal to fetch passengers at the back of a Suzuki Every?
Panel beating and respray
Coaxial or Component for Rear speakers
Different front and rear tires
Front/rear strut bar & lower tie
Charging car on the move with solar panel, feasible?
