Hotamp 3rd Gear June 21, 2009 Share June 21, 2009 My convection oven always trip the MCB when i switched it on, i guess some wiring got shorted somewhere inside. Any bro knows of any neighbourhood HDB type appliance repair shop where i can bring in to service? I called the authorized service centre leow, the charges are a bit high. . ↡ Advertisement Link to post Share on other sites More sharing options...
Kopi_peng Neutral Newbie June 22, 2009 Share June 22, 2009 is it because you seldom use it? was told be the service ctr tech that if heating coil not used for long time, it'll cause a trip on the power. have u tried turning it on at lowest possible temp setting? Supposed to warm up and it'll remove moisture that cause the trip Link to post Share on other sites More sharing options...
Hotamp 3rd Gear June 22, 2009 Author Share June 22, 2009 is it because you seldom use it? was told be the service ctr tech that if heating coil not used for long time, it'll cause a trip on the power. have u tried turning it on at lowest possible temp setting? Supposed to warm up and it'll remove moisture that cause the trip yep...i have not been using the oven for sometime leow, i didnt know that part abt turning to lowest setting to remove the moisture :) , i will try at this sat. Thanks Link to post Share on other sites More sharing options...
Ahwhye 5th Gear June 23, 2009 Share June 23, 2009 yep...i have not been using the oven for sometime leow, i didnt know that part abt turning to lowest setting to remove the moisture :) , i will try at this sat. Thanks If that still cannot, then you have to disconnect the all "earth" wirings to the oven, heat up the oven thoroughtly (dun touch the external metal surface hor), then it will be OK. remember to re-connect the 'earth"wiring. that is how the repairman will do.... But your oven is like mine, with gas pipe connected, then have to disconnected it as well. Some new /seldom-used oven has to be heated at least once every few months to keep the moisture away from the heating elements. ↡ Advertisement Link to post Share on other sites More sharing options...
Where you cut your hair?
NBA - Where Amazing Happens
Shopee Singapore
Shopee Singapore
Used Mercedes buyer spends $40,000 on repairs
Shop Houses Collapse at Syed Alwi Road
‘I might have to close in a few years’: Singapore’s ‘mamak shops’ could soon disappear
