Dwoon 1st Gear June 9, 2009 Share June 9, 2009 Hi All, Its driving me nuts...... my ABS and handbrake lights keep turning on. It comes on intermittently. After awhile of driving, switching off the engine (or at least pull out the key with turbo timer on but engine running), the lights will go off. Then it might or might not come back during the rest of the journey. (Now seems to come on more frequently) Both lights always come on together. Mech checked and found brake line leak. Replaced it but the symptoms still there. Topped up brake fluid as mech said might be caused by too low level. But I went back & played with the sensor in the reservoir..... it only turns on the handbrake lights... not the ABS. Can anyone advise what could be the probably cause? Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
B0ss Neutral Newbie June 9, 2009 Share June 9, 2009 (edited) Deleted Edited June 9, 2009 by B0ss Link to post Share on other sites More sharing options...
Watwheels Supersonic June 9, 2009 Share June 9, 2009 (edited) The only thing I can think of is that one of the rear brake caliper piston is jammed and that can explain the brake light, abs light on and they on intermittently. If this is the case, the caliper can be overhauled and cleaned of the debris and particles trapped in the piston. If your mech say koyak already dan change the caliper lor. Edited June 9, 2009 by Watwheels Link to post Share on other sites More sharing options...
Dwoon 1st Gear June 9, 2009 Author Share June 9, 2009 Hmm... ok, thanks. Is there a reason its the rear calipers and not the front? Is it because of the handbrake mech in that hub at the rear left? I too think its something to do inside or thereabouts.... but I think mech is too lazy to take it apart as it is quite abit of work. If its a simple thing like caliper overhaul.... then its alright. Can always buy the kit which comes with the seals. No need to discard lah...... Just that I hate it when repeated visits to the workshop and I still can't have it solved. The only thing I can think of is that one of the rear brake caliper piston is jammed and that can explain the brake light, abs light on and they on intermittently. If this is the case, the caliper can be overhauled and cleaned of the debris and particles trapped in the piston. If your mech say koyak already dan change the caliper lor. Link to post Share on other sites More sharing options...
B0ss Neutral Newbie June 9, 2009 Share June 9, 2009 Haf u accidentally driven off without fully dis-engaging ur handbrake? I tink urs is a 4WD car right? Link to post Share on other sites More sharing options...
Dwoon 1st Gear June 9, 2009 Author Share June 9, 2009 Yes, its AWD. No, I didn't forget to release the handbrake. Besides, that would not trigger the ABS lights. I did once years ago in Cameron and realised it only after like 10 mins of driving. But even then, the no warning lights were activated then. (of course the handbrake lights were still on lah) Link to post Share on other sites More sharing options...
Eching21 Neutral Newbie June 9, 2009 Share June 9, 2009 There is a chance that the circuitry (or something linked to the circuitry) in the area surrounding your dash board is loose. I had the same problem, and hitting/tapping the base of the steering wheel and/or the plastic covering of the steering column behind the steering wheel would cause the light to go on/off. Meaning that when i hit a bump or an imperfection in the road, the same bump could cause the lights to come on or off. It was also my handbrake light and ABS warning light. After checking, there was nothing wrong with both the systems. Got a mechanic to check the connections and it was fine after that. Not sure if you're facing the same issue. Mine's a Hyundai Sonata. Link to post Share on other sites More sharing options...
Dwoon 1st Gear June 9, 2009 Author Share June 9, 2009 Thanks. But mine doesn't go off on its own. It comes on and the only way to get it off is to pull out the key with handbrake engage. (Can be with engine off or engine still running as I've a timer). Then at times, pulling out the key also won't get it off.... till after travelling for awhile. Wah... if its connection/electrical faults.... that's a major headache that all mechs fear...... ↡ Advertisement Link to post Share on other sites More sharing options...
Christmas lightup 2022!
Are LED lights subject to brightness checks?
How Much Do You Know About ABS?
Traffic junction without traffic lights
Electrician lobang?
Electrician lobang?
Mazda 5 ABS error
Mazda 5 ABS error
