Yuan 6th Gear August 15, 2011 Share August 15, 2011 may I ask where did you buy? I got my parts (including engine mountings) from the stockist of Mitsubishi, Min Ghee. They are located at Kallang. ↡ Advertisement Link to post Share on other sites More sharing options...
Fooblack Supercharged August 16, 2011 Share August 16, 2011 I got my parts (including engine mountings) from the stockist of Mitsubishi, Min Ghee. They are located at Kallang. thanks for the info. I took my case with C&C. They changed one of the mounts for me FOC, saying that it has cracked. however, the vibrations has not stopped. usually it is worse when the air-con is running. should i be changing all the mounts? Link to post Share on other sites More sharing options...
Yuan 6th Gear August 16, 2011 Share August 16, 2011 thanks for the info. I took my case with C&C. They changed one of the mounts for me FOC, saying that it has cracked. however, the vibrations has not stopped. usually it is worse when the air-con is running. should i be changing all the mounts? Usually for mounting, it has to be changed in a pair. Cannot be one of the 4 mounts only. Either the front pair or the rear pair. Perhaps that explains the vibrations after the change. Link to post Share on other sites More sharing options...
Fooblack Supercharged August 16, 2011 Share August 16, 2011 Usually for mounting, it has to be changed in a pair. Cannot be one of the 4 mounts only. Either the front pair or the rear pair. Perhaps that explains the vibrations after the change. did you also experience persistent vibrations on the steering wheel before you changed the mounts? i wonder if mine is a serious case enough to bite the bullets and change the mounts... Link to post Share on other sites More sharing options...
Yuan 6th Gear August 16, 2011 Share August 16, 2011 did you also experience persistent vibrations on the steering wheel before you changed the mounts? i wonder if mine is a serious case enough to bite the bullets and change the mounts... There were some form of vibrations and such vibrations are more obvious when you engage in reverse gear. I guess you should either go back to C&C or seek a second opinion from an outside workshop. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear August 16, 2011 Share August 16, 2011 may I ask where did you buy? Fong Tat building Link to post Share on other sites More sharing options...
Yuan 6th Gear August 16, 2011 Share August 16, 2011 Fong Tat building Bro, your car make same manufacturer as mine.... Your stockist is Min Ghee? Link to post Share on other sites More sharing options...
Mivec9 1st Gear August 16, 2011 Author Share August 16, 2011 bro..next fri i got things on...the following week? 26th? sounds good! Link to post Share on other sites More sharing options...
Ceecookie 5th Gear August 18, 2011 Share August 18, 2011 Hi guys, Im an owner of a Lancer EX too. Do anyone knows if V-LED High Power bulbs are sold in Singapore and is LTA approved? Latter is most impt of all. Also, will this V-LED bulb damage the turn signal housing if fitted to the original housing? From what i can see in the above video, his turn signal bulb(V-LED) is flashing like an LED bulb and that is what i want. Ignore the rear light design as I know its not the one fitted to our EX. I've seen LED turn signals on many cars today and I quite like it, hence my qns. Link to post Share on other sites More sharing options...
Fooblack Supercharged August 22, 2011 Share August 22, 2011 There were some form of vibrations and such vibrations are more obvious when you engage in reverse gear. I guess you should either go back to C&C or seek a second opinion from an outside workshop. went back to C&C. Changed my 2 more engine mounts FOC. Funny thing is that only 1 out 4 mounts is unchanged and they said ok one. they also replaced my engine throttle assembly haha... I am thankful that they are true to assist my case... even the engine mounts although technically not covered under warranty, they have changed it foc. for those whose ride is almost 3 yrs, pls resolve any issues before warranty ends... Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear August 22, 2011 Share August 22, 2011 Bro, your car make same manufacturer as mine.... Your stockist is Min Ghee? Min Ghee and Fong Tat are the stockists Link to post Share on other sites More sharing options...
Titanium 4th Gear August 25, 2011 Share August 25, 2011 Hello... I just got back my car from the workshop, now i think the rear lights is not aligned properly. I talked to the workshop ppl and he insist is like that, see another lancer also got slight gap. I removed and tried to fit it back but seem like it never fit in nicely. Can anyone tell me if this is normal??? Thanks... Gap between the bumper and the right rear light. Rear light seem to be slightly protruding... Rear light seem to flush in more... Link to post Share on other sites More sharing options...
Yuan 6th Gear August 25, 2011 Share August 25, 2011 Hello... I just got back my car from the workshop, now i think the rear lights is not aligned properly. I talked to the workshop ppl and he insist is like that, see another lancer also got slight gap. I removed and tried to fit it back but seem like it never fit in nicely. Can anyone tell me if this is normal??? Thanks... Gap between the bumper and the right rear light. Rear light seem to be slightly protruding... Rear light seem to flush in more... I check my car tomorrow and let you know. Link to post Share on other sites More sharing options...
Titanium 4th Gear August 25, 2011 Share August 25, 2011 I check my car tomorrow and let you know. Thanks !!! Link to post Share on other sites More sharing options...
Sky_vinz Clutched August 26, 2011 Share August 26, 2011 Hi bro, this is a picture of my ride. To be honest, I think the gap is too big. Should be something like above pic. Are there any broken clips inside causing this gap? As for your 4th pic (top view), it's normal. The corner of the rear lamp is slightly inside. Link to post Share on other sites More sharing options...
Titanium 4th Gear August 26, 2011 Share August 26, 2011 Hi bro, this is a picture of my ride. To be honest, I think the gap is too big. Should be something like above pic. Are there any broken clips inside causing this gap? As for your 4th pic (top view), it's normal. The corner of the rear lamp is slightly inside. Thanks Bro! Anyone have anymore backside pic? Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear August 27, 2011 Share August 27, 2011 i think it shouldn't be like this. what did you do to your car? Link to post Share on other sites More sharing options...
Yuan 6th Gear August 27, 2011 Share August 27, 2011 (edited) Thanks Bro! Anyone have anymore backside pic? I checked mine today. Does not have such a gap. Edited August 27, 2011 by Yuan ↡ Advertisement Link to post Share on other sites More sharing options...
Mercedes Owners Thread
W212 owners, please check-in
Nissan QashQai 2014 Part 2
